Author Topic: Blades for the new guy  (Read 547 times)
Offline Mispeld
« on: August 05, 2022, 07:04:30 AM »
My wife and I are expecting our first mill in a few weeks – a healthy 14HP HM126 with 6’ extension. She has been asking for one for a year or two. I felt we would never really be completely ready but I couldn’t stall her anymore. We are not getting younger.
For preparation,  what all purpose blades would be recommended for standing dead loblolly pines, some hardwood, and also be conducive in Eastern North Carolina? No frozen logs here. We are looking to build a barn and have fun.
I tried searching and it is very easy to go down the rabbit hole. I know there are too many variables to simply answer with accuracy so I am just looking for a recommendation on good “starter” blades to get us going. I see there are experienced sawyers here and I value experience. We have zero.
Thank you in advance.
Online Nebraska
Re: Blades for the new guy
« Reply #1 on: August 05, 2022, 07:08:33 AM »
4 degree Kascos, my Ez Boardwalk was very similar in hp.  Woodmizer makes a 4 degree profile.  I will keep using them on my Timberking  as well.
Online mapleack
« Reply #2 on: August 05, 2022, 08:43:28 AM »
Congrats on your impending delivery. I have a 14 hp on my norwood and have been using 7 degree ripper 37's on both pine and hardwood with success.
Norwood LM2000
Online firefighter ontheside
  • I like trees.
« Reply #3 on: August 05, 2022, 09:23:59 AM »
When I had 15hp on my mill I used 10 deg and 4 deg from woodmizer.  4 deg cut slower but less likely to get wavy.  I think 10deg would be a good blade for you and your pine and low HP.  I started using 7deg from Kasco when I upgraded to 19hp.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Offline kelLOGg
  • More is better but enough is best
« Reply #4 on: August 05, 2022, 10:33:43 AM »
What Nebraska said. Low HP mills 4deg is a must. Mine is a 20HP and I use them.
Where in eastern NC are you ?
Offline stanwelch
« Reply #5 on: August 05, 2022, 10:41:00 AM »
Welcome to the forum Mispeld.
I have a Woodmizer LT 15 with 15 HP
I cut mostly hardwoods but some white pine.  I use WM 10 degree on everything without many problems. I tried 4degree on white oak worked ok but cut slower and dulled quite fast. I switched back to 10degree and cut faster with better blade life.
I am sticking to 10 degree blades
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
Offline Mispeld
« Reply #6 on: August 05, 2022, 11:23:54 AM »
I was going to get a pack of 10° blades from WM but I see a lot of people using 4°. I appreciate the input. Maybe I'll just get a few of each and go from there. It adds up quick!
Kellogg - I am in Jacksonville, NC.
Offline JoshNZ
« Reply #7 on: August 05, 2022, 04:15:56 PM »
I have a 22hp mill and use only kasco 4 degree bands now. There's nothing a 4 degree won't cut flatter for longer than any other band in my opinion. Maybe not as fast, but you won't be in a rush starting out, so it is a great starting band.
You will find with a manual sawmill there is not much time saved by getting to the end of a cut in 30 seconds instead of 40, it's the few minutes of offbearing, unclamping, lowering back stops, turning, leveling, reclamping, any head scratching when new, etc etc before the next cut that kills the clock.
Offline ladylake
« Reply #8 on: August 05, 2022, 04:20:41 PM »
There's nothing a 4 degree won't cut flatter for longer than any other band in my opinion.)
 That's my opinion too.          Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline scsmith42
    • Whispering Pines Farm
« Reply #9 on: August 06, 2022, 01:14:57 PM »
I too can recommend the Kasco bands.  I buy mine from FF member Richard (Cutting Edge Saw service) and have been very pleased with them.
I just drove through Jacksonville last month.  I'm located about 30 miles SW of Raleigh.
You're on the best forum in the world for sawmillers!  Welcome and enjoy.
Scott
Tom's 3638D Baker band mill
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #10 on: August 06, 2022, 01:21:40 PM »
   I am in the 4* camp. When I bought my mill I bought 10, 7 and 4 degree DH blades from WM and have since tried a couple of turbo 7 and I am phasing out everything but the 4*. Yes, you can saw faster in soft wood with a 10 or 7 degree blade - then you hit a and you have a ripple/wave in your cant that shows up in every board unless you edge it out. A 4* will cut hard or soft wood well, a 10* will not. Good luck on the new mill.
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
Peterson Blades, vs Lucas Blades
Started by Nate Surveyor on Sawmills and Milling
Last post May 07, 2007, 12:26:56 AM
by Firebass
question
Blued blades VS shiny blades
Started by woodbowl on Sawmills and Milling
Last post January 17, 2006, 01:30:17 AM
by woodbowl
question
Sharpening blades vs shipping blades
Started by Deese on Sawmills and Milling
Last post April 10, 2015, 07:39:09 AM
by Chuck White
