Timber Wolf Blades on a Thomas 6013 Mill
Started by leeallen, October 25, 2011, 06:57:40 AM
leeallen
I am using Timber Wolf blades on my 6013 Thomas mill. Does anyone have experience with these blades?? They seem to work very well. Any thoughts on other blades that people are using on their mills?
Lee,timberwolf are as good a band as your going to find I use them.In fact I've had good luck with any of the brands I've tried,its more how you use and sharpen them than brand.Some mills cut a little better with one brand over the outher you just have to try and give them a fair test. Frank C.
Wudman
I've had very good luck with the Timber Wolf blades.  I run both them and Woodmiser on my home built unit.  They had a free demo blade program when I built my mill and I bought a box after that.
Wudman
"You may tear down statues and burn buildings but you can't kill the spirit of patriots and when they've had enough this madness will end."
Charlie Daniels
July 4, 2020 (2 days before his death)
NHHillbilly
That is all I use.  I havent used anything else new.  The Local distributor and welder is only about 20 minutes from me.  Very knowledgeable and great customer service.  If you have any dirty logs try the cobalt a little more expensive but cut unbelievalable.
LT40hdg28
