Author Topic: Diaginal measurements  (Read 3759 times)
Offline beetle
  • maybe some day
Re: Diaginal measurements
« Reply #20 on: October 16, 2004, 05:16:30 PM »
Thats why I am currently building another, yet this one is two story. Its that auction fever   8)
Too many hobbies...not enough time.
Offline leweee
  • Illegitimus non tatem carborundum
« Reply #21 on: October 17, 2004, 11:27:32 AM »
AMEN !!! ;D (to the garage be'en too small) ;D
just another beaver with a chainsaw &  it's never so bad that it couldn't get worse.
Offline Engineer
« Reply #22 on: October 17, 2004, 11:33:38 AM »
I always use the method of equal diagonal measurements to check for square after layout.  Measure opposite diagonals, if they are equal, you're guaranteed square; if not, move things a bit until they are.  The key is to figure out what to move and how far.
I cheat on the layout though.  I use a Topcon total station to get my corners within 0.01' to begin with, and then work from that for more precision.   ;D
Offline OneWithWood
  • I am happy!
« Reply #23 on: October 18, 2004, 10:52:22 AM »
FDH, I still use the tried and true batter boards and builders twine to lay out my buildings.  I guess if I would take the time to learn how to use one I could rent a transit and get it down a few minutes quicker, but deep down I am just a simple ole fart ( that's similar to a G.P.I.T.A. only different :D )
One With Wood
Offline Murf
  • The pitter-patter of little feet..........
« Reply #24 on: October 18, 2004, 12:40:33 PM »
Stupid question of the day time........
One, how do you know if the builders twine that you use for your layout is forming square corners if you don't calulate the corner to corner distances to check them?
Offline OneWithWood
  • I am happy!
« Reply #25 on: October 19, 2004, 09:14:49 AM »
Murf,
You don't which is why I use the calcualtions I mentioned earlier in this post to check for square.
One With Wood
Offline beetle
  • maybe some day
« Reply #26 on: October 20, 2004, 08:30:34 AM »
What to move and how much is relatively simple.
One line or wall of the building or whatever your checking should never be moved ( reference line), measure your diagonal, if the measurement is equal you are square, if not, move the opposite line 1/2 the the differance. Lets say you measure one one diagonal is 100" the other is 101", move the opposite line parallel  1/2". you are square. One two step done.
You will have the post holes dug, posts in place, and dead square by the time the person next door has just set up his batter boards, however, I agree with one of the previous posts, they do have their place, one would be slinging mortar and bricks.
Offline beetle
  • maybe some day
« Reply #27 on: October 20, 2004, 08:50:09 AM »
MooseHunter,
I bet you never thought your simple question would get this many responses  :o  Did you get the answer to your question   ::)
Offline Bruce_A
« Reply #28 on: October 20, 2004, 01:48:25 PM »
The last large job I was on was a co-generation plant in Longview, Wa.  We poured what we called a rat slab for every set of forms to be set.  This was a rough 4" slab below the bottom grade.  Engineers set all the corners in the concrete and forms were set accordingly.  Took  awhile to get used to not trying to set forms in mud or worse and getting your feet wet from the puddles on the rat slab.  Solid footing for bracing etc was also a nice experience.  Made 100 yard pours easy and common and the large pours[600 to 700 yards] go like clockwork no matter what the weather.
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #29 on: October 21, 2004, 05:24:34 AM »
Beetle,
Got my answer and more! I will be laying out my mill shed this weekend ( if it ever stops raining) and the info gathered will be a great help.
Thanks to all,
Moosehunter
"And the days that I keep my gratitude
Higher than my expectations
Well, I have really good days".    Ray Wylie Hubbard
Would someone be able to take a few measurements for me?
Started by WoodenHead on Sawmills and Milling
Last post July 18, 2013, 01:41:41 PM
by WoodenHead
Accurate Measurements
Started by crtreedude on Forestry and Logging
Last post April 02, 2007, 03:11:27 PM
by SwampDonkey
While we are on systems of measurements...
Started by Dave Shepard on General Board
Last post May 26, 2007, 11:51:47 AM
by TexasTimbers
Need a couple of Measurements on the HM126
Started by Menagerie-Manor on Woodland Mills
Last post March 13, 2022, 05:15:36 PM
by Menagerie-Manor
