Author Topic: please critique my solar ideas  (Read 1411 times)
Offline mike_belben
  • Pulp Friction
Re: please critique my solar ideas
« Reply #20 on: March 20, 2021, 02:17:42 PM »
Could a variable frequency drive be added to the existing well pump to cut start load amps? Thats how these super efficient ductless split AC compressors are doing it.  Someone with PLC experience could probably snatch a VFD from a scrapped minisplit and program it to run other things.  Im not that guy but maybe someone here is.
Isaiah 48:10
Offline peakbagger
« Reply #21 on: March 27, 2021, 06:05:16 AM »
You can add variable speed drive to an existing well pump. Franklin Electric sells a "subdrive" for 2 wire pumps and monodrive for 3 wire pumps. A 3 wire pump (actually 3 wires and a ground) has an external capacitor box while a 2 wire does not. Installing one means you switch the house over to constant pressure operation instead of high low. It also gets rid of pump surges on startup which really help it you are running on a generator. The pump rarely if ever runs at full speed so it lasts longer. The only downside is cost. I think the Subdrive is around $700 while the Monodrive is around $1,400. Strongly recommended is a whole house surge suppressor on the main electrical panel to protect the electronics. The surge suppressor that is used in the solar industry is a Midnight Solar SPD as it shunts power to ground at lower level than most of them.
One other comment is that many homes have real crappy grounding systems. If the ground system is not set up correctly, the well pump gets zapped. The well casing needs to be bonded to the house ground rods that the main panel is connected to with a heavy gauge wire located outside the wire conduit in the trench and it should be routed directly to the ground rods without going into the house.
Offline mike_belben
  • Pulp Friction
« Reply #22 on: March 27, 2021, 10:45:11 AM »
 smiley_thumbsup
Isaiah 48:10
Offline tmarch
  • I'm older, maybe not wiser tho
« Reply #23 on: April 19, 2021, 04:03:13 PM »
First I would get and install a solar pump system on preferably a separate well to irrigate your garden and have it coupled to you other uses so at least you would have water available when the power go's out.  This would be a relatively inexpensive project that will give you an Ida about how solar will help your usage.  Keep in mind that water is more important than a lot of things for life.
I installed that configuration on several of my pasture wells, when I saw how that worked I installed my grid tied system in 2012.  It is over half paid for in electric savings since that time so I consider it a good investment.  I can turn a valve and furnish water to homestead if the power does go out.
Retired to the ranch, saw, and sell solar pumps.
Offline 62oliver
« Reply #24 on: June 24, 2021, 03:55:29 PM »
If you want to get into solar you must educate yourself first, google Northern Arizona wind and sun forum. Set up a login and start reading and asking questions.
They have a great forum there.
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
Offline mike_belben
  • Pulp Friction
« Reply #25 on: June 24, 2021, 05:39:25 PM »
Midnight solar and fieldlines were excellent forums a decade ago as well.  Lot of pioneers on fieldlines.
Isaiah 48:10
Offline peakbagger
« Reply #26 on: June 25, 2021, 05:31:47 AM »
If you want education the pretty much universal recommendation is Solar Power your home for Dummies book. There is an older version floating around on the web or you can pick up new one from Amazon or any other bookseller.
solar kiln ideas
Started by Joey Grimes on Drying and Processing
Last post September 05, 2015, 08:10:03 PM
by Joey Grimes
moved
MOVED: solar kiln ideas
Started by chet on Sawmills and Milling
Last post September 06, 2015, 08:24:33 AM
by chet
Solar kiln w/ aux. heat not drying, any ideas?
Started by Kelvin on Drying and Processing
Last post January 28, 2004, 06:41:07 PM
by HORSELOGGER
Started by Kelvin on Sawmills and Milling
Last post January 27, 2004, 04:53:02 AM
by Kelvin
