End Coating Frozen Logs
Started by FarmingSawyer, January 20, 2015, 06:26:10 AM
FarmingSawyer
I'm starting to accumulate several primo saw logs--apple, a highly figured beech, a nice yellow birch. I won't get to sawing them for a while, and I'm behind the 8-ball in getting them end-coated. I've used paint before to seal logs, but don't really want to again...... I'm just about to spend the $$ on clear Anchorseal......but will it work in 0˚ weather?
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
Geoff Miller
I have not used Anchorseal but have used Lee Valley log end sealer in cold weather. It is a water based wax emulsion which I believe is similar to Anchorseal. The only thing I found is that in cold weather the end sealer stays wet longer because it takes longer for the water to evaporate and leave the coating of wax.
4x4American
Could always heat em on with a salamander.  I wonder how the wax would do.  The wax in diesel fuel gels up in the cold, so I wonder how it'll fare in this application.  Wouldn't hurt to give em a call.
Boy, back in my day..
terrifictimbersllc
1-888-ENDCOAT  or www.uccoatings.com
PDF of Anchorseal 2 info attached below.  Doesn't say about low temp application.
steve marek
I use anchorseal they have a winter blend works good
WM LT40HD logrite ach 718 woodmaster timber framing tools 3000 ford tractor 359 395 husky chainsaw woodmizer e50 single blade edger woodmizer 260 moulder 2538 mahindra tractor kd 250 kiln
dean herring
Failure is not an option  3D Lumber
AK Newbie
I have used standard Anchorseal in temps in the single digits with good results.  I think it will work just fine at lower temps!
LT28, Logosol M7, Husky 385XP, Stihl MS 250, Echo
terrifictimbersllc
Quote from: dean herring on January 24, 2015, 09:25:51 PM
Where do you get anchorseal?
I get it from the manufacturer, UC Coatings, at 1-888-ENDCOAT, or www.uccoatings.com online store, in 5 gallon pails.  You can get other sizes there too.
Some other places like Woodcraft Supply, also carry it in gallons.
4x4American
Does it have anything to do with sealing boat anchors?  If so, then I would think you could get buckets of it at any Ford dealership  :D
5quarter
Normally I would take umbrage with that remark, but this afternoon I got my ford truck stuck in a corn field, hauling out a load of erc. My buddy came and pulled me and the trailer load out with a...with a...
Blue Harbor Refinishing
5quarter
WmFritz
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
sandhills
Quote from: 5quarter on January 26, 2015, 12:53:54 AM
chevy.  >:( ::)
Don't worry 5quarter, my Ford has pulled out a few chevys before  ;)
4x4American
 ;D
Ouch!
It's ok, they all get stuck.   Go to a mud bog event, you'll see.  Or if you want to see em all break down, go to the truck pulls.
shinnlinger
I end coat small pieces with a block of paraffin and a plumbers blow torch.
Shinnlinger
FarmingSawyer
I haven't gotten around to ordering any Anchorseal yet. I hit the most critical logs--some 14" & straight apples with some linseed oil thinned with turps. Soaked in nice, was fast and looks like it's done the job. And I can see the grain!
WmFritz
 I'm thinking as long as they are frozen, they won't dry at all and don't need sealing until: either the temperatures warm or the logs are sawn.
Is my thinking wrong?
~Bill
