Flat sawed vs. rift
Started by D6c, November 21, 2019, 01:26:08 PM
D6c
Been finishing red oak window molding for my house and not surprisingly, there is quite a difference between individual pieces of molding.
First pic shows difference in flat sawed and rift.  Personally I prefer the rift piece with straight grain which is consistent on all edges, and it takes stain more evenly.  Flat sawed piece is ok too but some of the pieces can have pretty wild grain.
The 2nd pic is of a REALLY flat sawed piece that has very little grain, and isn't very attractive.  Probably won't use it.
My question is, is there a difference in value between flat and rift sawed material?  If it were fully quarter sawed I can see it being higher value but wasn't sure about rift.
BTW....is it "sawed" or "sawn"?  spell check doesn't recognize sawn, which is what I usually say.
I don't think there is a difference in value, but there certainly is in appearance. If you are quarter-sawing or using a swing blade mill you end up with a bit of rift sawn material as a by product anyway.  It's usual use is for things like table legs, where all 4 faces are visible, and it's nice if they all show similar grain. So you might sort those boards out into a different stack, just based on appearance.
And according to Dictionary.com, sawn is a word
Quoteverb - a past participle of saw
YellowHammer
We get the same price for either flat or rift sawn wood.
In the redneck world, "sawed" is a real word, too.
For example "I sawed that big buck deer run across the holler, did you seed him too?"
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Ljohnsaw
I thought sawn was the past tense of seen...
John Sawicky
terrifictimbersllc
I sawed 1636 bf today. Nothing wrong with my math or grammar.
scsmith42
We sell rift oak for a significant upcharge (same as low fleck quartersawn).  It's pretty much that way across most major resellers.
KD FSWO may start in the $2.50 - $3.00 bd ft range, whereas KD RSWO will start at $4.25 bd ft and go up based upon width.
Tom's 3638D Baker band mill
moodnacreek
Rift and quartered lumber is superior to flat sawn. Very little to no shrinkage in width. Stronger and great bending strength. No tear out when planning.  When doing it intentionally [on the mill] it is alot of extra work and the boards tend to pull from the heart [ they bow]  but is is the best lumber by far.
If I sort it out, I charge a little more for rift sawn.
Percy
Quote from: YellowHammer on November 21, 2019, 03:10:07 PM
In Canuckistan....."It were rainin this mornin but then the sawn came out "
Southside
I sawed where the kews got out at Yellow Hammers a few years back and done git up in the door yard, stove things all up.... ;D
White Oak Meadows
Raym
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Some of this conversation is flat sawed and some of it is riffted.
