Soaking Walnut
Started by Ole CB, December 15, 2009, 01:25:11 PM
Ole CB
Quote from: Den Socling on January 06, 2010, 10:48:24 AM
I am having trouble drying black walnut from South America. North American is as easy as rolling off a log. At any rate, a guy tells me the other day that they soak their walnut in ponds before they dry it. Must be something to it.
I have dried some very hardwood from Australia called jarrah. I read that it is so hard that it was used for pavers only. It said that jarrah pavers still lay under some streets in Europe.
And those are the odd facts for the day.  :D
  They told me at the mill that someone wants like 100K of these 4/4 X 6" square blocks from walnut and that they are similar to what they used as pavers in Europe. Seems like this is a new or coming deal (fad) for driveways and patios.
boardum
The block pavers are an interesting item.  Haven't seen those in use but would like to.
The South American Walnut sounds alot like our Claro Walnut. Best to leave on sticks a couple of years before finish drying to avoid Cell  Collapse.
Here in the NW they used a 4" x12" x 14' plank for the original roads. A friend of mine used to work for the county in the Portland area said they still from time to time find these under the existing roads. It makes a small job a large problem due to the length. Most he reported were in great shape being at or near 150 years old. Most also was Western Red Cedar.
Ole CB
  I have found some pics at flickr com of some wooden pavers. I cannot seem to post the link to them here.
Those pictures shows the alley, "Behind the residence of the archbishop of Chicago. "
  Here are a couple from somewhere in Chicago.
boardum
Are the Pavers all End Grain? Are they always end Grain?
Thanks for the Photos
Boardum
Ole CB
Quote from: boardum on January 11, 2010, 01:42:12 AM
Boardum
  Boardum,
  Yes, the way I understood it, that is what they want. We were talking about making 24/4 cants and cutting the 1" blocks from them then somehow drying. It seems to me that boiling those blocks would keep the splitting to a minimum.
boardum
Ole,
I'd try a couple of things. As you described boiling the cuts may work great.
Also keep in mind that this was old world tech so it may be as simple as cutting everything green and using them before they dry out. In which case cutting green and dipping both ends in wax to keep them till they get to the ground may also do the trick.
I have several friends who travel and buy wood in Europe, I'll ask around for insight.
Best of luck.
Ole CB
Quote from: boardum on January 16, 2010, 06:10:08 PM
Ole,
Best of luck.
  Boardum,
  I had not thought about that at all..  Thanks, and let me know if you find out anything!!
ed
