Ford 540 vs 445... Now 545 D
Started by Ljohnsaw, September 23, 2021, 12:27:42 PM
Andries
John, I'll echo what chevytahoe recommends with the circulation type heater. They do a great job of heating up the whole engine block and cooling system. My 545 is out in the open all winter for snow clearing and I keep insulated tarp handy so that when I plug in, the tarp will keep the heat in around the motor.
Those Ford Thermostart preheaters are such a cool idea, (yikes, a flamethrower in the intake manifold!) but the igniter seems to be the finicky part that sometimes does, or mostly doesn't want to work. I won't get my Ford hooked on diesel crack (ether) and if it's too cold for the block heater and the thermostat and the tarp not to work, then I'll do something else that day. There's always a bit of warmer weather coming.
It seems so odd that cold weather diesel starting advice from us 'glaciated' guys like chevyTahoe and barbender and myself, would be going to a guy that's working in California. I have to remember that you're working at an altitude where there not might be much oxygen.
I'd go with a high wattage tank type recirculating block heater, a full tank of gas in a quiet Honda generator.
Alternately, there's propane pancake heaters that plug into the coolant system on the skidders up here. That works at -35°C but a bit rough'an tough because of a really really fast warmup. Save that no love lost option for the Detroit353 as bbender says.  😬
The elegant and 'need-to-work in-the-cold-all-the-time' solution is a Webasto heater that burns diesel from your main fuel supply and 12 or 24v from the machine's battery. Programmed to start at five am, so that you can turn the key and go at first light. Vevor sells them for much less than the original European prices. IceRoad trucker stuff, works very very well.
Options galore!
LT40G25
Ford 545D loader
Stihl chainsaws
barbender
 Some diesels just do not start well in the cold, unassisted. For instance, the Cummins in my Dodge pickups start awesome in any weather if you cycle the intake grid heater first. Same thing in all of the Ponsse machines I've ran, let that grid heater cycle and they will start cold at -20°F.
 Now my 3.9 Cummins in my Case skid steer? It has no intake heater, and below 40° and it very quickly loses the ability to start without plugging in the block heater. I've thought about finding a junk 5.9 Cummins from a Dodge and stealing the intake grid heater for the 3.9, it makes a world of difference.
chevytaHOE5674
Valve height could change the compression ratio slightly.
Did you put each injector back in the same hole it came out of?
Andries
Burt, are those intake heaters electrical?
 My mind's eye goes to something like a fine mesh that gets really hot which heats up the intake air, helping the diesel to pop off.
A pair of healthy batteries needed for that . .  .
LT40G25
Ford 545D loader
Stihl chainsaws
This thread reminds me of a channel I subscribed to of Mike McCoy (may he rest in peace). While looking for the video of how he pulled a plug out of the intake manifold and used a hand held gas torch in that hole to preheat the intake, I ran across this other video of "mother" (as he affectionately called his wife who was offbearer, forklift driver, and do everything) showing her starting the John Deere front end loader. The trick she was using to relieve load on the system was to move the steering wheel so hyd. fluid wasn't dead-headed in the system. I've used it before and it seems to help to turn the engine over easier with the starter. I'll look some more for the video showing him heating the intake of the Deere.
Cold John Deere 544 - YouTube
barbender
 Andries, yes they are electrical, and they pull enough amps to dim your headlights (the Dodges will continue to cycle the grid even after the engine is started). Probably part of the reason they do run dual batteries in the diesel pickups. But I don't see any reason a battery that can crank a diesel wouldn't have what it takes. The glow plugs on my Lombardini diesel on the Woodmizer draw some amps too, and the single battery is more than up to the task.
 It's a lot less amps drawn overall, let the grid heater cycle (usually 20-30 seconds) and touch the key and it's running, vs my skid steer where I'm afraid I'm going to damage my starter by cranking too long.
 Beenthere, I do believe that wiggling the steering wheel trick is particular to the John Deeres, someone like Kiko would know way better than me but I was told they are designed that way. It causes the pump to bypass somehow.
 Ponsses, which have variable displacement pumps, put the swash plate at the minimum angle/displacement when they are being cranked. I'm sure others are similar.
chevytaHOE5674
Wiggling the steering wheel helps the hydraulic pressure in a closed center system have a place to go instead of using the starter to build hydraulic pressure.
On most tractors lowering the 3pt hitch to the ground can often increase cranking speed. If the hitch settles at all then the starter is spinning the hydraulic pump and trying to lift the hitch and implement.
Ljohnsaw
Yes, the injectors went back in their respective holes.
Thanks for jogging my memory. I have a couple of those Webasto clone heaters I got at auction super cheap. I'll mount one up with a line pointing at the base of the engine to heat it up! I'll need to fab up some sort of cab on the 545D when I get around to having to do snow removal at the cabin.
It was 35° this morning and the "flame thrower" got me started pretty quickly.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Ljohnsaw
I went up the Wednesday before Thanksgiving to retrieve my quick attach off the Ford. I had the bucket slip off one side and tweak it. I straightened it as best I could with the hydraulics but it was difficult to change attachments.
I tried to straighten it better at home with chains and a jack, no joy. I have another tool plate so I set it in that. I sawsall'd one end of the connecting tube. It moved an inch in two directions as it dropped into the plate!  So I cut the other side. I slipped in a short piece of 2" square in each end to align it for welding back in place. I was already planning on adding a piece of 3" sch 40 pipe as a cross piece. After seeing the square tube was at best 1/8", I added a second pipe and you see both here.
Slapped some paint on it and back up the hill Wednesday day to install.
Works great. Should hold up now.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
stavebuyer
Great job. The "standard" SSQA really isn't up to handling the load larger machines dish out. The euro-global style works out much better on heavier machines.
chevytaHOE5674
I have standard ssqa on a couple 200 horsepower tractors and a 100hp skid steer and have never had any issues. Good heavy duty quick attaches that are properly braced and your good to go.
Andries
John, clever repair - using a spare mounting plate to register the new cross tubes. I'm thinking the same thing, your 1/8" wall thickness on that square cross tube won't handle the loads that a 5000 lb. rated fel will generate.
Do you have a high amp rated welder for working with really thick metal?
I've been abusing my loader and grapple with some big rocks.
So far, the ATI brand of ssqa has held up with no problems.
I do need a bigger ballast box though - I'm up on the front tires too often. 😉
LT40G25
Ford 545D loader
Stihl chainsaws
Ljohnsaw
I have a 50amp Lincoln tombstone welder. I was running 105 or 120 burning 1/8" 7018.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Ljohnsaw
Andries,
I'm having issues priming my pump and hoping you have some insight. When I first got my tractor, I had issues running around the hills here. Turned out to be the water filter was full! Dumped it out, cleaned it and let it refill with fuel, IIRC, and it started and ran fine.
Well, today I did something dumb and ran it out of fuel.🫤 Added fuel and it would run for a few seconds a few times. Then it ran for 30 seconds or so an started faltering and quit. Figured air in the line. The little manual pump thing doesn't seem to do anything. I loosened most of the fitting and get no flow.
So I decided i might as well change the fuel filter. Got fuel dribbling out the Out line and hooked back up to the pump. Manual pump does nothing. Cranking gets a little wetness at the loose injector fittings. Not a squirt like I'm expecting.
Did I ruin my pump? I even loosened the injector line that's accessible where the wrench is and get no flow there at all now.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Andries
John, the only time I had to bleed air out of the fuel lines was when I changed the fuel filter and cleaned out water separator. That separator seems to work out pretty well, and keeps the fuel filter water free.
The fuel system on mine does not have a manual pump w. lever for priming the injector. The fuel runs from the shut off valve under the tank, straight to the pump supply fitting that you show just above the wrench on your set up.
I loosened up most of the fittings to the injector pump and from there up to the injectors when I had to bleed my system. The fuel ran pretty freely right up to the injector pump. The CAV injector pump on mine has a very small bung that can be loosened up to bleed air out of the injector pump. When cranking the motor, the bung showed air bubbles then fuel only.
Trying to fine photos of my setup so that you can see if there's a similar air bleed bung on yours.
My loader is out at the lake camp and I'm in Winnipeg chasing chores. Im on my phone, and if there aren't any photos on my 'puter, the pics will come your way in one or two days from Kenora.
These machines are mostly abuse tolerant, you and I would have to really focus on intentional carnage to break them.
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
HHere's a picture of the pump on my 545, John.
Just above the yellow, silver and blue speck tag on the main body of the pump is the small (maybe quarter inch) bung that I was talking about.
LT40G25
Ford 545D loader
Stihl chainsaws
Ljohnsaw
Ok, mine has that, too. I was tempted but didn't want to make things worse. I'll try that in the morning.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
newoodguy78
John FWIW when bleeding lines I've got a remote starter button that is my go to. Wrench in one hand button in the other. Very handy being able to crank it over and see just what's coming out of the line.
Once the fuel is a steady stream I'll tighten the fitting while it's still cranking. My method is to do one injector at a time.
Goes with out saying but check check and recheck that everything is in neutral if you do use a starter button. Very easy to get complacent or knock it into gear working on it.
Andries that's interesting to know about the bleed screw on the pump itself. Fortunately on all our Fords I've been able to bleed them at the injectors with success every time but good to know if one decides to be difficult.
Ljohnsaw
No need for my remote start button, which is at home. I can reach the key and a wrench at the same time. No cab in the way.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Ljohnsaw
I pulled the little plug. Took a 8 mm wrench. Nothing for about 10 seconds, then a little dribble. More of an oozing. So gave it a crank and started gushing. Replaced the plug and loosened one injector line. Crank and a little fuel appears but the engine wants to start. Tightened back up and off to the races! Thank, guys!
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Andries
You're welcome - glad I could help out.
Next time I'll be looking for a hint and a tip from you.
LT40G25
Ford 545D loader
Stihl chainsaws
Ljohnsaw
Ok, now the rest of the story...
When I ran out of fuel and decided to change the filter, I had one other issue. I turned the fuel off but it continued to trickle when I removed the filter.
So I turned it off harder. Now a steady fast drip. Cranked it off, slight dripping.
So then I am back to my story above trying to get it to prime and start. It did and I ran it for about a half hour. Went back later and ran for 10-15 minutes before it sputtered and died. What now...
Pulled the priming plug and couldn't get much flow. This morning I vowed to get it running again. Pulled the new filter, seemed ok. Pulled the sediment/water trap. Had some crud but no water.
Thinking maybe the dry tank I dislodged crud filling it up? Open the valve and nothing comes out. Huh?
So now I have to use an oil sump pump to drain the 5 gallons I just put in the tank. That was fun.
I pull the hard fuel line off ( lots of silicone used, morons) and try to figure out how to get the valve off the tank. Can barely get my fingers to it.
As luck would have it, it wasn't froze up, actually almost loose. More silicone. Cleaned all that off. It is a tapered pipe thread into the tank so *should* self seal. There probably was a thin gasket at one time.
Pull the valve apart. It's a needle like valve. On the stem are two grooves for O rings. One there, forward one missing. Well, misplaced. It was hardened and me cranking down to shut off the fuel forced all the bits into the elbow, only allowing a drip of fuel at a time.
I used Teflon tape on the pipe treads and it was a snug fit getting it rotated to be able to hook the fuel lines up. Not a drip. Had to pressurize the tank to get the water trap and filter to fill. Primed all the way to the injectors but still wouldn't start. Gave it a whiff of ether and running again.
The fuel lines have a 5/8" nut on the 1/4" hard lines. The lines have a slight flare. Between the flare and the inside of the nut is a flat ~1/8" thick rubber seal. What are those called? Where can I find them? Nothing is leaking at the moment but there are quite a few on this system as well as my skytrac that are old and hard. I'd like to replace or at least have some on hand. I asked at NAPA and he didn't know what I was talking about.
Speaking of the Skytrac, it decided to derail one of the hydraulic hoses in the boom for the fork tilt. Seems like it smashed it as the forks no longer move and the self leveling system is straining when I raise or lower the boom. I replaced this hose a few years ago...
On the plus side, it is 15° cooler today with a nice breeze. And I was working on the shady side of the Ford.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Ljohnsaw
Well, better lucky than smart!
I was able to use a rubber bungee cord to coax the hose back to where it belonged as I moved the boom in and out. It was squished between a wear pad and the boom.
The hose had just a little too much slack to stay out of trouble. I figured it was toast but once it was free, no leaks and the forks operate once again!
So I added a spacer to the adjustment pipe that all four hoses make a 180° turn around. Nice and snug so back in business.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Andries
Well, good on both machines then, right?
I don't know what those flat washers are called either, which puts me in the same class as the NAPA guy. "I asked at NAPA and he didn't know what I was talking about." 🤷�♂️
The next time I have to wander into fuel line territory on my loader, I'll check in beforehand with a diesel shop. My lines have be tinkered with by guys that may have been well-intended gorillas.
John, didn't you say that the motor on your tele-handler was leaking coolant into the crankcase? Bad sleeve seals or something. And here you are working on a puzzle of crimped hydraulic lines. Did you swap in a reman?
LT40G25
Ford 545D loader
Stihl chainsaws
newoodguy78
I'll check my parts book for that machine when I get back around it.
Can't say I remember any rubber between the fuel line and injector on any of the fords in that vintage I've worked on. They've all been flared lines like you said and they seal directly to the top of the injector.
After you mentioning the silicone makes me wonder if someone put something in there that doesn't belong.
