Author Topic: New Winter Sport - Dozer Skating  (Read 4084 times)
Offline JV
  • Live - love - laugh a lot today.
« on: December 26, 2008, 05:56:14 PM »
We still have sheets of ice covering everthing including our long driveway.  My brother-in-law called and asked if I could spread some gravel over their new driveway as one delivery truck was stuck going uphill.  It's a simple drive through our barnlot and across a field, so I thought.  I fired up the track loader and started out across the lot and started up a sidehill.  Street track doesn't have a lot of grip on ice especially sideways.  It's suprising how fast a dozer can move sideways.  After recovering, I spread some #9 stone and got the truck out.  Hmmm, this might be fun out in the clear, no one close.  Figure 8's, doughnuts, might start a new sport.   :D
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline Don_Papenburg
  • I need money
Re: New Winter Sport - Dozer Skating
« Reply #1 on: December 26, 2008, 09:26:24 PM »
Ice and street pads ..........slipand slide .  I have pulled my crawler up a lot of slopes where  I had no intention of going..    But it was a fun ride .  An articulated four wheel drive  tractor sliding sideways  on ice while trying to make a turn is fun also.
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #2 on: December 26, 2008, 10:34:59 PM »
It always seems like what ever you are driving when breaking loose on ice accelerates when it breaks loose.  It must just be the adrenline. :)
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline JV
« Reply #3 on: December 27, 2008, 09:04:24 AM »
I don't mind it so much on the track loader, but the excavator is a different story.  That higher center of gravity has a tendency to increase your pucker power on the seat.  Several years ago I was cleaning out a deep V-ditch and from the edge of the bank to the bottom was a least 7 or 8 feet.  The bank was a long slope 25 to 30 degrees and was heavily grassed making it slippery with the style of track on the excavator.  While digging, the machine decided to suddenly head sideways for the ditch  I dropped the bucket and boom and pushed with the dipper while cranking the track at 45 degrees to the ditch.  Walked her up the bank and had a cup of coffee while my adrenaline level subsided.   :o
John
Offline sprucebunny
  • Gender: Female
« Reply #4 on: December 27, 2008, 09:50:17 AM »
We had some ice last winter ... not as much as this year, but plenty of ice with the record breaking snow.
My 17,000 ? pound backhoe did more than one 180 spin and it certainly did seem to accelerate when it lost it's grip  :o At least with a rubber tired machine you can put chains on . Maybe one could weld bolts to every third cleat on a steel track machine ???
It would be lovely to see a synchronized skidding performance with heavy equipment  ;D Maybe a new winter Olympic sport ???
Offline JV
« Reply #5 on: December 27, 2008, 10:41:04 AM »
Yep, pairs skating with excavators, curling with D8's, and speed skating with pan scrapers.  I'd pay to see that.   :D
John
Offline Ron Scott
« Reply #6 on: December 27, 2008, 11:05:29 AM »
Be sure that the dozers are chained down good when moving them on the lowboy. I've seen a few of them skate right off the lowboy. Not a good situation, especially if on a busy highway.
~Ron
Offline pigman
« Reply #7 on: December 27, 2008, 11:36:12 AM »
It is not adrenline. It is because in almost all cases the coefficient of static friction is greater than the coefficient of kinetic friction.
Several years back I was using my old TD 15 to clear a heavy snow here on the farm. We had a thick layer of ice under the snow. After shutting of the dozer off on a slight grade sideways, it slid sideways about 100 ft to the bottom of the grade. One of the best  sled rides I have ever had. ::)
  • I need money
« Reply #8 on: December 27, 2008, 10:00:04 PM »
Most street pads have holes for caulks . I just put 5/8 " bolts in my pads for caulks . It does not slip as much on ice now.
Offline Paul_H
« Reply #9 on: December 27, 2008, 10:23:02 PM »
We lost a friend that we grew up with in early 93, when the D8 he was plowing snow with,shot sideways off the icey logging road  and plunged hundreds of feet down towards the lake.The D8 scattered pieces all the way down but he was thrown from the machine and crushed to death just below the road.
A sack of ice lugs and a hour and a half's welding would have saved a lot of sorrow.
If you type these coordinates into google earth,it should give a good idea of the country there.It's 40 minutes NE of my place here.
  5033'57.70"N   12229'0.56"W
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #10 on: December 27, 2008, 10:53:00 PM »
 Paul , I feel for you , I have lost a friend on the high steel to stupidity also , rushing a job never got no one ahead . I lost part of a shoulder to a bosses lack of sense .   >:(
  We had every thing there to set up the job properly , he came around and put a stop to the instalation of the trolly beam that would of allowed us to bring the steel plates to the work table from where the crane could let um go . He had us carry the plates in . Was ok at the time , they where heavy but not too heavy that two men could not carry them ... but Murphy stepped up to bat and had me doing physiotherapy for five years to regain use of my left arm .
   I took the google trip there Paul ..  nice mountains to work out of . One needs to have respect for those types of jobs . I am able to see the logging show on history channel.
 I lift my hat to you, mon ami, thats hard work .  :) ;) :)
   Marcel
Offline Paul_H
« Reply #11 on: December 27, 2008, 11:09:12 PM »
That lake is Anderson and it's getting into the drier interior of BC towards Lillooet.My family had a cabin on the East side of the lake when I was growing up.It's pretty country for sure.
When you come out here we'll take a long day trip around that area.Pemberton,over Bralorne,Lillooet and back to Pemberton. :)
Offline OneWithWood
  • I am happy!
« Reply #12 on: December 29, 2008, 10:11:17 AM »
Early on in my learning curve with the JD450 craler/loader I discovered that grouser tracks slide perfectly well on frozen soils.  After doing the tobagon thing on a steep slope littered with stumps I found a seat belt for the machine.  Now if the ground is frozen I don't venture far.
One With Wood
Offline twobears
  • sawdust runs in my veins..
« Reply #13 on: December 29, 2008, 07:20:31 PM »
 PAUL:I,AM sorry to hear about your friend.
 i,ve taken a few sliding rides..dozers and log skidders.the worst one was on a skidder.we had a trail that crossed a mountain stream.the banks where very steep on both sides and on the uphill side there was a springhole.there was a old skidder trail and the ruts from it.each trip it got icier until one trip i couldn,t make it.i got right to the top and lost it.the skidder slid back down the bank and when it was all over the skidder was standing on the back tires and top of the arch.i was still in the seat looking straight up at god.
 ever try getting off a skidder standing on it,s tail??? i got off and walked out to the landing.my boss was picking on me the whole time.."just get on it and drive it out of there"
 we went back with another skidder and he wouldn,t even get near it to hook a chain on the blade to pull it out of there..lol oooooooo,yyyyaaaaaaaa.i picked on him about "get on it and drive it out of there.."show me how it,s done".
 the same winter i spunout on a mountain trail and went backwards for a good 300 yards.we had chains on the front of the skidder and once i spun out they turned into skates.
 there was a good 4 feet of snow and i didn,t darn to go off the trail..i figured the trail was so steep the skidder would turn sideways on the trail and trip over then keep on sliding down the hill on it,s side.it was atleast a 60 degree slope.we had to use two skidder to open the trail.we had them hooked together and would go until one of us got stuck.we had a 640 in the front and i was on a 540.the 640 would go until he got stuck and i,de push him or he would winch me if i got stuck...fun,fun,fun!!
  delbert
Offline fishpharmer
« Reply #14 on: December 29, 2008, 10:18:15 PM »
I am sorry to hear about a tragedy.  Just don't ever know when the Good Lord is going to take you.
Makes me recall the American Chopper show that had the big daddy guy slide a backhoe in a pond. Then a dozer almost did the same pulling it out.  It was funny to watch afterward but there were many levels of tragedy that could have happened.
I hate to preach but those big machines are super useful, often fun, but, never a toy.
Hope you don't mind me chiming in I work alot with tractors, backhoes, dozers and trackhoes.
The new guy,
James
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline JV
« Reply #15 on: December 29, 2008, 10:46:44 PM »
My original posts were meant to be a light-hearted jest, not to suggest that anyone should seriously do this on purpose.  I have operated equipment for many years without anything but the usual bumps and scrapes.  I do take safety seriously and have stopped a job more than once for safety concerns.  I had a crusty old superintendent and a safety officer who wouldn't hesitate to stop work if safety were an issue.  Hope no one thought I actually suggested to do anything unsafe.   ;)
John
Offline DanG
« Reply #16 on: December 29, 2008, 11:56:52 PM »
Not to worry, JV.  We all enjoy the stories about the occasional dodged bullet, and the joy that comes from having dodged it.  At the same time, it is a good thing that others voice cautions to those that might not be aware of the dangers involved. ;)
Offline twobears
« Reply #17 on: December 30, 2008, 10:07:34 AM »
 yep:it,s a good thing to talk about close calls and accidents it just might save a life someday.
 i,de much rather offend somebody on here then hear somebody went to the woods or sawmill and died because they just didn,t know how deadly something can be.
 we work in a industry that has taken alot of lives over the years and saddly it,ll take alot more.
 the northern logger mag had a article in it this month about a new hire.the boss took him back in the woods and showed him where to cut.he left and 20 minutes later he came back and found the guy dead. no hard hat and a four inch tree limb hit him in the head.they sure could have used some safety training or atleast some good reading on it.
 delbert
Offline Sprucegum
« Reply #18 on: December 30, 2008, 10:20:36 AM »
Grow'n up I did lots of side-slipin, doughnout burn'n and 4-wheel skid'n just for fun  8)   ::)  ::)
But that first skid sideways in a Cat was a whole different feeling  :o  :o
Keep Yer Stick On The Ice
Offline bck
« Reply #19 on: December 30, 2008, 02:49:44 PM »
Saw on the news today a city employee somewhere fell through the ice on the city's $200,000 piece of equipment . They had to get scuba divers to hook chains to pull it out. Thing is he was not supposed to be there, he was on the was to his house to clear his driveway  :)
Anyone want to go Ice Skating? Winter storm of 09!
Started by semologger on General Board
Last post May 11, 2009, 01:05:59 AM
by rowerwet
653 Allis dozer Torque found, dozer running again!!!!!!!!!!!!!!!!!!!
Started by Striker on Wanted
Last post December 01, 2005, 03:27:05 PM
by tnlogger
Baddest Sport around?
Started by 4x4American on General Board
Last post May 20, 2016, 08:09:22 AM
by r.man
New to the "sport"
Started by dbuck1985 on Sawmills and Milling
Last post June 06, 2013, 07:46:23 PM
by redbeard
