Author Topic: Update on the barn  (Read 2404 times)
Offline sgtmaconga
  • Still Sweating on the barn
Update on the barn
« on: November 22, 2007, 08:58:38 PM »
Well i finely got time to update the photos on the barn i'm building. as some of you know the size is 42'by 36' so here we go.
this is the center loft and the start of one outside wall
this is with the siding on the wall.
this is the rafters and cutting in the top windows. my shop is now going in the loft.
Measure twice cut once
Offline brdmkr
  • I need to slow down...
Re: Update on the barn
« Reply #1 on: November 22, 2007, 09:13:14 PM »
Looking good.  What are you using for siding?  How much reveal on the laps?
Lucas 618  Mahindra 4110, FEL and pallet forks, some cant hooks, and a dose of want-to
Offline Handy Andy
  • Location: right on the edge of the great american desert
  • I'm not new anymore
« Reply #2 on: November 22, 2007, 09:55:57 PM »
  The plan looks cool.  Set your mill on the ground floor, and stack your lumber to dry there, then take it upstairs and build things.  Fun.
My name's Jim, I like wood.
Online Gary_C
  • Sunrise on the Prairie
« Reply #3 on: November 22, 2007, 10:02:22 PM »
I do not know if I am missing something, but I wonder if you have adequate cross bracing on those walls. I see you have temporary cross bracing, but not seeing any permanent bracing. Just the board siding is not enough. If you had plywood sheets under the siding, that would work, but not just the narrow board siding.
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #4 on: November 22, 2007, 10:12:54 PM »
Sgt,
What are you using for floor joists and what are they bearing on between posts?  Just curious........ the floor looks mighty light to support any equipment let alone a 40# per square foot live load.     For a shop a 100# live load would be a better design parameter.    Hope the beams between posts are adequate also.   Don't want to risk a colapse from the second floor level or any level. ::) :)
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline sgtmaconga
« Reply #5 on: November 22, 2007, 11:22:33 PM »
this is pine we cut on the mill. 7"x1" which ends up around 3/4" when dried. over lap is around 1 inch.
Offline sgtmaconga
« Reply #6 on: November 22, 2007, 11:23:40 PM »
most of that bracing will come when i close in the tack and feed rooms.
Offline sgtmaconga
« Reply #7 on: November 22, 2007, 11:27:25 PM »
Sgt,
the cross beams between the metal post are 2x8 spliced so i ended up with a 4x8. each was 12' long before joining. joist are 2x8 on 16" centers. floor decking is 5/4 in withs ranging from 8" to 14"
Offline sgtmaconga
« Reply #8 on: December 30, 2007, 04:00:25 PM »
latest photos of the barn.
Please modifiy this post using the forum gallery.
and the new used window for the tack room
Offline thecfarm
« Reply #9 on: December 30, 2007, 04:25:37 PM »
Looks good.Keep the pictures coming.Like that NH tractor you have.
Offline sgtmaconga
« Reply #10 on: December 30, 2007, 05:46:06 PM »
sorry about the pics i'm trying to upload them now to the gallery.
that tractor is a farmtrac 535. it's just like the old ford 3000
Offline sgtmaconga
« Reply #11 on: December 30, 2007, 06:01:11 PM »
ok new pics the right way this time.
and the west side with the windows cut in.
Offline woodmills1
  • the truth shall set you free
« Reply #12 on: December 31, 2007, 08:06:16 AM »
I also am wondering about your open overhang to the left in your pictures.  Looks like 2x6 floor joists with posts only on the outside.  Did you get some engineering on the structure?  Do you plan on storing lumber up there? Seems light to me.
Offline DanG
  • DanG, The Official ForestryForum Cussword
« Reply #13 on: December 31, 2007, 12:02:32 PM »
Well, I wouldn't put a 5,000# cast iron planer up there, but it should be adequate for most home shop tools.  I've seen lots of floors with 2x6 SYP joists and never saw one collapse.  Good fasteners at the ends are critical though, and some knee braces would shorten the span somewhat.
Offline sgtmaconga
« Reply #14 on: December 31, 2007, 07:16:48 PM »
lol.
the post are on both sides spaced 14' apart. what your seeing is only 1/3rd of the barn. i had to build it like this because i needed a place to store hay. i don't think i'm going to have a problem with the shop floor. i'll start the eastern side of the barn as soon as i get thru landscaping it for level.
