Lucas Dedicated Slabber Question
Started by DR Buck, September 18, 2017, 10:54:08 PM
DR Buck
What is the overall width of the power head frame for the 60" dedicated slabber.
Savannahdan
Good question.  Here's what I found:
Sawmill Specifications
Engine: Briggs 23HP Electric/Manual Start Gas Engine
Transmission: 5" Centrifugal Clutch with 40mm Shaft (2 Belt Drive)
Sawchain: .404" pitch with .335" Kerf (8.5mm)
Maximum Width Cut: Up to 60" (1.5m)
Maximum Depth Cut: Up to 19.7" (500mm)
Maximum Log Cutting Length: Up to 20' (6.3m)*
Powerhead Weight: 300 lbs (135kg)
Overall Weight: 610 lbs (277kg)
Log Size Note*: The Lucas Dedicated Slabber can cut virtually any length log by adding end-frames and rail extensions. Many customers have cut timbers over 40' (13m) long.
I measured my carriage and it is 100" wide.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
