Echo problem
Started by petefrom bearswamp, May 29, 2021, 08:26:06 AM
petefrom bearswamp
My cs600p is giving me fits.
Starts and run OK for a few minutes then wont idle.
I have had my local guy a logger who runs a repair shop on the side, test it for crankcase leak and try to diagnose the problem but he cant figure it out.
Told me I have a boat anchor.
It has been a good saw and plenty of zip for a 60cc.
I am reluctant to to scrap it.
Nearest Echo dealer is about 40 miles away.
Any suggestions.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
I was all set to help by saying don't holler so loud.
doc henderson
Pete is it old and or well used?.  if it sat a while, sounds like it could be a carb issue.  have you tried seafoam, or cleaned the carb?
Real1shepherd
Again the obvious first;clogged spark arrestor and/or clogged air filter. Then check fuel filter and fuel filter lines...then vent system.
If it runs a few minutes normally and then won't idle, sounds like it starved for gas. BUT.....if you're not getting anywhere(you should do this anyway as a matter of course), with the above suggestions, take off your muffler and examine the piston.
Lots of owners have spent much time on everything else only to find out that the piston/rings are trashed with transfers. Some engine will even have 90lbs or so compression and will show transfers with the muffler off. They will start and run OK but as the saws warm up, they will do exactly what you're describing.
Kevin
axeman2021
If you try the items that the forum has posted and it has not solved the problem i would drive that 40 miles to the dealer.
welderskelter
Then dont let it idle. Use seafoam and maybe it will clean up on its own.
petefrom bearswamp
Perhaps I wasn t clear enough on my problem.
The saw will not return to idle, stays at full throttle after a few minutes.
I put a new carb on it, but no change.
Have been told good things about wiemedogs work and have PMed him.
Sounds like he is fairly close to me.
Kubota 900 RTV
doc henderson
yes, I thought or interpreted your comment to mean that when you let go the trigger, it would die, and not idle.  does the linkage feel right?  although that should be constant I think.
ladylake
 Check the intake boot between the carb and cylinder, I've had one get a tear in it on a CS600, .  It idled fast. Sounds like your logger friend has a bad attitude about Echo saws.  They're great saws and easy to work on.  Steve
lxskllr
Yea, I was thinking that. "fast idle" doesn't sound like any kind of fatal error to me. Just a matter of finding what it is. I wouldn't abandon a good saw over that, and I'm not particularly inclined to spend a lot of time working on saws.
doc henderson
can you take off the bar and chain, take off the air cleaner so you can see the linkage.  throttle up and when it lags going to idle, see if the link is stuck.  if so, spray the outside with carb cleaner.  or with it off, trigger to see if the butterfly lags going closed.
petefrom bearswamp
Thanks for all of your suggestions.
I have contacted weimedog who says he can help me.
Kubota 900 RTV
