Hot rod
Started by Peter Drouin, June 08, 2019, 12:39:12 PM
Peter Drouin
A roof yes. But first I'll put the GMC 3500 dump truck on the lift run the thing all the way up then figure the garage door in over the truck.
Then see how high the roof has to be. I like to build things from the ground up. ;D
Peter Drouin
Ten yards of flat work kicked my butt. Pixs latter got to cut the rest of an order.
running-doggy
78NHTFY
Nice going Peter!!  Have wanted a lift for years, but you are DOING it!  Now you can rest cutting your order on that comfortable new seat on your mill :D :D.  Looking forward to the pics....All the best, Rob.
If you have time, you win....
Peter Drouin
Put burlap down then the plastic. then flood the thing
Will dry slow that way. I should wait 7 days Going to do just 5. :D 8)
More,
Jenset going there.
Setup fast with it being 90° today, Ten yards with help from a 70-year-old and a 55-year-old
 ;D
Only had a wheelbarrow full left over. I still got it. 8)
Cut 80 2x4x16' and had a HOT ROD stop in to for a price list.
43 ford. With a 350 GM engine in it. So you guys want a fast car/truck. Power it with a GM plant
Sorry, Jeff. :D :D ;D
Long day for a 64-year-old in the 90s ;)
Bruno of NH
sawguy21
Every time somebody mentions pouring concrete my back starts to hurt. :D That is hard work! That is one sweet Ford pickup 8)
And another sickness has been taken upon. ;D
Peter Drouin
Quote from: thecfarm on July 10, 2019, 09:25:40 PM
smiley_thumbsup smiley_wavy, Hi, cfarm hows things up there north of me?
Lonely. I need some company. Like someone with a Hotrod to keep me company. ;D
crowhill
For you Ford guys that want a bit more speed go to   Racing Junk Find "Silent Thunder" T-Bird  on Google. Friend of mine built this little Thunderbird up which did ok on the drag strip.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Peter Drouin
All morning, but I got the 1968 Impala off the lift, Took it all apart and now it's home. [the lift]
I did try to buy the ss but he wanted too much for it.
Just a little more work and the 10,000 lb lift will pick up an 1800 lb Hot Rod just find.  :D :D :D 8) 8) 8) 8)
Happy days,
btulloh
Sweet. That's gonna be mighty handy.
HM126
Bruno of NH
Southside
Sure would be a lot easier to clean out from under a mill if you could lift it in the air... :D
I'm extremely jealous.
Peter Drouin
Quote from: Jeff on July 15, 2019, 09:55:15 AM
I been jealous of that new barn you just put up too, With heat lights, a kitchen a fridge, stove.
:D :D ;)
  But now It will need a roof, Wonder where I can get some lumber? ;D
Jim_Rogers
Quote from: Peter Drouin on July 15, 2019, 07:01:36 PM
:D :D ;)
I think there is a sawmill near by you. I can get you his number if you need it. :D
Peter Drouin
8) 8) dancing-jack usflag smiley_fiddler smiley_thumbsup
Looks good.
I would be using that for my tractors.  ;D
To quote an extremely close acquaintance.  :D :D
Bruno of NH
Dave Shepard
Looks like a good anti theft device,  too. :D
Winter storage! Should be just above the snow.
Peter Drouin
Quote from: Jeff on July 20, 2019, 09:26:37 PM
There's going to be another bay on the right side of the lift facing the back of the hot rod. I want to free up the lift for my trucks to be worked on.
I'm going to have big windows to let a lot of sunlight in.
A steel bench bolted to the cement floor with a vice on it.
Then I can set up my wire feed welder air tools and torches at the lift bay.
Lumber sales are down from last year. can't sell wood might as well set up a nice garage.
I have a ton of band mills around me now selling lumber at all most what I pay for logs. I know they won't last long, but, It hurts me. have 3 or 4 guys going around on the road sawing too now. Years ago it was just me. And everybody has a small WM in there back yard now. Ross in Maine is doing a good job selling them.
I think it's time to find something else to do. Will see.
Too much work without Ann.
sawguy21
I understand how you feel. :( That is going to be a great shop to play er work on your new toy.
