Author Topic: 361 carb limiter caps  (Read 1342 times)
Offline boboak
« on: February 25, 2007, 07:45:17 PM »
  What's the best way to get to the 361 limiter caps and what's the procedure after that? I'd like to be able to fine tune the carb a little better than I can now. Will the carb stay in ajustment with the caps removed or is this going to be an on-going hassle every time I need to re-tune?   Thanks....Bob
Sometimes you get things done faster if you do them slower
Offline sawguy21
Re: 361 carb limiter caps
« Reply #1 on: February 25, 2007, 09:43:56 PM »
I am not going to tell you to do it but lots of people carefully grind the ears off the caps. The screws won't stay in place with the caps removed.
Carburetor Limiter Caps - Keep or Discard?
Started by lxskllr on Chainsaws
Last post November 06, 2018, 08:34:12 AM
by Inaotherlife
390XP Limiter Caps...Just the facts...
Started by double clutchin weasel on Chainsaws
Last post December 28, 2013, 07:37:36 PM
by Andyshine77
I removed my carb limiter tabs!
Started by RSteiner on Chainsaws
Last post March 09, 2010, 01:50:50 PM
by HolmenTree
Jonsered cs2255 carb adjust limiter?
Started by AndyVT on Chainsaws
Last post September 25, 2021, 09:43:58 PM
by AndyVT
