General Forestry => Drying and Processing => Topic started by: Crusarius on February 06, 2019, 01:04:25 PM
Title: Router sled for surfacing slabs
Post by: Crusarius on February 06, 2019, 01:04:25 PM
Lets see what you got.
I made one out of minitec extruded aluminum I scored from the scrap bin at work. It worked ok but the amount of friction was to much for my liking. Great thing about it is how forgiving the alumiunm is when you hit it with your brand new carbide router bit :)
I am now wondering if buying a 1200mm linear bearing and using that for the bottom rails would work well. Could still use the minitec for the cross pieces.
Part of the reason I ask this is because I am contemplating trying the linear bearing on my mill mast. If it does not work the way I want it to there I would like to be able to use it elsewhere.
My setup was a quick and dirty one trying to make slabs for my wife's Christmas present creations.
(https://forestryforum.com/gallery/albums/userpics/45059/IMG_20181219_183952329.jpg?easyrotate_cache=1549476076)
Here is the router sled I slapped together.
(https://forestryforum.com/gallery/albums/userpics/45059/IMG_20181219_181619567.jpg?easyrotate_cache=1549476084)
This section is a closeup of the board with cleaned up and untouched areas.
(https://forestryforum.com/gallery/albums/userpics/45059/IMG_20181219_181602537.jpg?easyrotate_cache=1549476088)
Here is the complete slab I was finishing. If you look closely you can see what a 2" carbide router bit does to aluminum when you slip :)
Title: Re: Router sled for surfacing slabs
Post by: DWyatt on February 06, 2019, 04:01:40 PM
I just talked to dad about us building one of these out of that 80/20 material. The stuff is kind of pricey buy I like the idea of it being cut right, and square when you get it. I'll be interested what other people come up with.
Post by: Crusarius on February 06, 2019, 04:07:47 PM
the 80/20 worked great. If I took a little more time and came up with some better bearing materials it would probably work just fine. currently the plan may be to stick with it if the linear bearing works on my mast. Otherwise it will become really smooth router sled.
Post by: Ianab on February 06, 2019, 04:55:45 PM
I cheated and just mounted my big router on an old Peterson sawmill frame.  ;D
(https://forestryforum.com/gallery/albums/userpics/10460/ianab_slab_surfacer05.jpg?easyrotate_cache=1192060635)
(https://forestryforum.com/gallery/albums/userpics/10460/ianab_slab_surfacer01.jpg?easyrotate_cache=1192060633)
(https://forestryforum.com/gallery/albums/userpics/10460/ianab_slab_surfacer04.jpg?easyrotate_cache=1192060634)
Post by: Crusarius on February 06, 2019, 06:00:11 PM
Thats nice. I keep thinking about putting it on my mill bed to.
I see you do lengthwise to. I watched so many videos of ppl going across the grain instead of with it. I liked going with it alot better.
Post by: doc henderson on February 06, 2019, 07:35:12 PM
Made mine with scraps, 5 mm plywood bottom, 3/8th plywood side that traps (fences) the router in between, 2x4 frame on sides.
(https://forestryforum.com/gallery/albums/userpics/51041/AB390CAB-67C8-4EB6-B38A-90E61E5DDA75.jpeg?easyrotate_cache=1549494622)
(https://forestryforum.com/gallery/albums/userpics/51041/0BBCBC4D-F0F3-4EF7-9744-32733EC6B7DB.jpeg?easyrotate_cache=1549494622)
Post by: Crusarius on February 06, 2019, 08:08:57 PM
Thanks for the pics doc. that looks sweet. I keep wondering about making it height adjustable. the last piece I was surfacing started out tall enough it worked but I ran out of cutter depth before I was at the desired thickness. I had to reshim under the board to bring it up high enough to finish it.
If I had height adjustable life would have been much easier.
Post by: doc henderson on February 06, 2019, 10:22:48 PM
i had the stump on a pallet, took 5 minutes to drop the 2 x 4s to a lower level.  only took about 1/4 inch at a time, and tried to keep less than half the bit in the wood
Post by: charles mann on February 07, 2019, 12:02:57 AM
when eventually get to that point, I'm going to use my sawmill rails for fore/aft movement, and get some extrusion for the frame and cross slide, with some aluminum plating for the router base and sq tubing for horizontal movement. i figure why build some other rail sys, when the mill rails and frame are already built and cut the same slabs i will be flattening. kinda like ianab did.
Post by: ESFted on February 07, 2019, 12:07:49 AM
Here's mine using 80/20 and some skate wheels.
Router Planer Sled in General Woodworking (http://forestryforum.com/board/index.php?topic=80966.msg1232193#msg1232193)
Post by: kelLOGg on February 07, 2019, 06:16:54 AM
Quote from: charles mann on February 07, 2019, 12:02:57 AM
I have considered doing that with my mill but I don't have a compelling need for it, although it would be fun to do and nice to have.
Bob
Post by: Bruno of NH on February 07, 2019, 07:03:15 AM
I would like a carriage built for my to flatten slabs
Post by: Crusarius on February 07, 2019, 07:21:05 AM
My dilemma with making one exclusively for the mill bed is the problem with my mill being portable and not setup in a building or under cover. May not even be near electric. Usually wood working is a rainy day or winter project.
But if you made one for the mill and had a set of rails you could just bolt to the table its a win win.
Post by: Crusarius on February 07, 2019, 07:25:57 AM
Quote from: ESFted on February 07, 2019, 12:07:49 AM
Perfect. I like the wheel idea you did. thats a great idea.
Post by: Crusarius on February 07, 2019, 07:27:23 AM
So here is a question for everyone who has used a router sled to surface boards.
Why is it I always see ppl routing across the narrow part of the board, usually across the grain? I found with my setup running with the grain produced better results and was quite a bit easier and faster.
Post by: doc henderson on February 07, 2019, 08:17:24 AM
I would say it is because you need a well engineered sled to go across, and it is easier to make long solid rails, as your actual sled may sag in the middle if the span is long.  All about materials and engineering.  I made mine in less than an hour and that seemed to be the easy design.  Lots of great other ideas on this thread.  If I did lots, I would consider a more industrial design.  I also made a sled that could suspend a chunk of wood like a lathe, and rotate it slowly to carve it down with a router prior to putting it on a lathe.  It uses the same sled part.
Post by: mike_belben on February 07, 2019, 08:41:41 AM
1" round linear bearings on new 1" ground shafting will slide like its on ice.  The shafting is hot roll mild steel with a ground and oiled finish and is used for sheave shafts and so forth.  Industrial distributors like grainger or maybe MSC should sell it by the 8ft length in a waxed paper tube. Itll look chromed but is just ground.  Perhaps some of the better metal retailers too, such as yarde metals or speedy metals.
Ebay chinesium linear bearings should be about $15ea
Post by: Crusarius on February 07, 2019, 08:58:01 AM
I actually just ordered a set of 20mm x 1500mm linear bearings yesterday off ebay cost $83. Free shipping. That is going to get used on the mill. If it doesn't work there it will become my router sled.
I also ordered 6 cam followers for V2.0 sawmill playing.
Maybe the cam followers will work for router sled. I have wondered about just a nice flat table and rollers under the cross sled.
Post by: doc henderson on February 07, 2019, 09:03:07 AM
I do not mind the little bit of friction as I push the router by hand.  gives some control so router does not run away or go too fast.  I think if the router is well secured to the frame, then less friction would be nice
Post by: Crusarius on February 07, 2019, 10:12:31 AM
I do keep wondering if I should be making a full on cnc bed with lead screws and all. Then I can just program the size and let it go :)
Post by: DWyatt on February 07, 2019, 01:05:51 PM
Quote from: Crusarius on February 06, 2019, 04:07:47 PM
Have you seen the linear bearings offered by 80/20 that fit right on their extrusions? I believe I am going to use 1"x2" extrusions for the main rails with the linear bearings on top of those and have the sled portion made like what most people do with a box made from lumber. This would allow me to have 2 or 3 different boxes for different widths of materials being planed and not break the bank. Hopefully I'll have a better idea and maybe some pictures in the next couple weeks.
Post by: Crusarius on February 07, 2019, 01:12:45 PM
are you talking about the white HDPE linear bearing or do they have another style?
I have thought about putting a set of wheels on the cross slide that drop into the groove on the 80/20. Then maybe just a wheel on the other side that rolls on the table.
When I start surfacing the big boy slabs I have cut then I will probably put alot more time and effort into this. Right now, I am really looking forward to seeing other ppl's setups.
Thanks everyone for participating.
Post by: DWyatt on February 07, 2019, 01:28:04 PM
Yes, just the ones with the HDPE pads. I originally thought about using wheels, then I watched one run and the amount of saw dust (chips really) is incredible. I would fear that with wheels that fit in the T-slots of the 80/20 you could possibly fill the slots with sawdust and your wheels could ride up on the sawdust causing issues with the finish.
Then again, I could just be dreaming up problems that don't happen in practice. I feel much more comfortable with a sliding motion that is constrained in two directions (as the 80/20 linear "bearings" are) that will cause you to either push dust out of the grooves or be come hung up on the dust in the grooves. Either of which would be better than rolling over the sawdust and it impacting your z-axis.
Post by: Crusarius on February 07, 2019, 02:17:26 PM
That may work nice on the cross slide. slide the router to where you want and there should be enough friction to hold it in place then just slide the rails on top of the other rails.
Post by: charles mann on February 07, 2019, 09:11:43 PM
Quote from: Crusarius on February 07, 2019, 07:21:05 AM
that is kinda my plan too. have a section or track, same width as my mill, say, 3-4 4' sections of frame/track extensions. for mine, it will require the tractor and forks to move my ext sections, but it will require the tractor and forks to move the slabs too.
Post by: mike_belben on February 08, 2019, 08:10:35 AM
They do make sticky back UHMW that comes in rolls as if it were a a teflon tape.  One could build friction slides and then plastic them up for low drag.
A simple Z axis height control could be to make a few bushing plates of different thickness so that your router sits on an adjustable height standoff.  For more plunge you just pull one out and wack another pass.
I like cam followers, but much care would be needed to brush the tracks ahead of each roller so the sled doesnt bump up over a chip and transfer the Z axis flaw into the cutter point. Maybe mounted paintbrush heads or constant air via some perforated pex tubing along the sled frame.
Post by: Hilltop366 on February 08, 2019, 09:25:30 AM
Wood waste on the rails would be a problem, ways to reduce the amount of wood that gets on the rail would be best.
Some possible ideas?
The router set lower (lower cross sled) so the cutting was done below the length wise rails.
Some shielding to guide the waste away (think lawnmower).
A flexible curtain or brushes with dust collector to remove waste.
Post by: Crusarius on February 08, 2019, 10:04:03 AM
Quote from: mike_belben on February 08, 2019, 08:10:35 AM
Mike, you always have some of the simplest ideas. a pile of C washers that can be removed as necessary. That would be nice not have to constantly fight with the router height adjust.
A single layer of uhmw will definitely fix the friction issue.
If I did a roller that rolled on anything there would be some type of a wiper. that is critical. even on my sawmill the one time I ran it without I regretted it.
Post by: mike_belben on February 08, 2019, 02:25:02 PM
Well, i try to be a simple guy
High mount gantry rail would help reduce the trash on the rail but then you cant forkload your slabs onto the bed unless using a set of slings.
If the cam followers rode on turned up flat stock there wouldnt be too much of a shelf to sweep off atleast, a simple track brush should suffice.  Think of a flatbed rub rail, not much bark laying ontop of it.
Post by: DWyatt on February 08, 2019, 04:19:51 PM
Got the parts ordered last night for the router sled I want to build. I'll post some pictures once I get the material and get the router box made :)
Post by: Crusarius on February 08, 2019, 07:05:11 PM
DWyatt, that would be great. I know there is only so many ways to build one but everyone has their own little twist that makes them unique.
Post by: Al_Smith on February 08, 2019, 08:28:13 PM
I had to smile at the first post and the minitech .I used tons of it at work, it's kind of like high tech unistrut .Problem is there are so many making it there is no standardization at this time .It's pretty much industrial stuff ,easy fast fabrication but the average DIY person couldn't afford to buy it .
Post by: Crusarius on February 08, 2019, 08:34:30 PM
so true. If it was not thrown away I would not have it. But it does work extremely well. it still surprises me for the cost of that vs the cost of a welder that more benches are not just welded 1" steel.
Its not like they ever reuse it if they need to modify the bench. be cheaper to throw away 3 fabricated benches than build 1 out of minitec.
Post by: Al_Smith on February 09, 2019, 07:16:57 AM
Because automotive assembly lines change so much it was a viable option to use the stuff .It was ordered in 20 foot lengths or rather what ever that was in metric by the multiple bundles .I likened the stuff as saying it was an industrial version of the old erector sets of years ago replaced by Legos .
The stuff I assume was the brain child of some European design because I first saw it on German made machinery .
The types of fasteners are almost unlimited,angle braces and so forth .It doesn't do you much good to have the basic channel without the fasteners .In that aspect it's about like unistrut .The cost savings are basically made up due to the fact of ease and speed of assembly as opposed to welded steel which requires a higher skill set .
Post by: mike_belben on February 09, 2019, 08:15:42 AM
S&W stocked unistrut, 80/20 and creform.  There was way too much workload for the welders and a simple bench may take a week to have made.  The cut and clamp systems only took.a bandsaw and some basic tools.  The welder got $20+ pet hour and the temp making creform carts probably $11.  It was chinsy throw away chinese garbage but assembly lines change weekly so who cares, it got tossed all the time.
Post by: Crusarius on February 09, 2019, 08:29:57 AM
Guess I just take it for granted I could grab a welder and build a bench. I forget not many ppl I work with have that skill.
Post by: DR Buck on February 09, 2019, 10:28:18 AM
I built a wood/plywood sled that does about 24" wide stuff using my big 3.5HP Porter Cable router.  It works OK but the friction wears you out when doing longer slabs.   Then I took some of my milling profit and bought a wide prebuilt all aluminum one what has almost now friction as it used wheels.
https://youtu.be/990076Ob9P4
The wood jig is now hanging on the shop wall.
Post by: Crusarius on February 09, 2019, 11:22:07 AM
thanks dr buck. I been wanting to know how to do epoxy for a long time. that was great. the router sled is nice to.
Now I may be tempted to try this. Wonder what it would be like adding led's to the epoxy coat? bet it could look pretty amazing.
Post by: Al_Smith on February 09, 2019, 11:45:37 AM
Creform is another option .Again it wasn't heavy duty stuff but it worked and was fast .Fact I've used the discarded roller casters on my tool boxes which has worked out very well and the best part they were free .
After 29 years I amassed  great quantity of discarded Kennedy tool boxes .It took me at least 6 trips using a Ford Ranger to haul them out .Some of them must have had 500 pounds of stuff in them and gave the little truck quite a load .
As for the subject I use a portable power planner which does a pretty fair job .Going cross grain it does get a little noisy though but it works for a job seldom done on the stuff I do .
Post by: Crusarius on February 09, 2019, 01:19:41 PM
Had to look up creform. yup we use that to. I almost got a bunch of the rollers but they emptied the bin just before I got there. TO bad I kept thinking those would be great at the sawmill for moving slabs.
Post by: tule peak timber on February 09, 2019, 04:51:24 PM
My latest rendition of the router sled uses Bishop-Wisecarver grooved wheel/bearings. This setup will have dust collection, 5 1/2 foot width and 40 foot length, more than enough for the average table top. It will be up and running in a few weeks and I will post pics.
(https://forestryforum.com/gallery/albums/userpics/35190/DSCN2032.JPG?easyrotate_cache=1549749044)
Post by: Crusarius on February 09, 2019, 09:34:40 PM
Talk about going above and beyond. Looks sweet. are you just using a 3" router bit? what is your plan for that?
Going to power the drive or keep it manual?
Post by: tule peak timber on February 09, 2019, 10:36:01 PM
No power on the drive and we will be using an Amana insert bit . I came up with a clever set of rails I will show later. KISS,,,, keep it simple stupid. (referring to my thought process) :)
Post by: Al_Smith on February 10, 2019, 05:46:50 AM
Vee groove rollers are the cats' meow I've used larger ones on my DIY band saw mill .They are 4 or 5 inch ,1" axles freebies,scrap pass . ;) Originally spare parts for a  robotic type loader for cast iron automotive V8 engine blocks .Engine was obsoleted as were all the machinery to make it .My name is on the last 3 or 4 Ford 460's ever made .
Post by: tule peak timber on February 10, 2019, 06:53:26 AM
Cool,,,I've owned a lot of 460's in various vehicles.Years ago I would buy rich peoples used Lincolns, detail them and then  resell the shiny cars  at a profit .These wheels are tiny because I don't have the room.I picked them because they will ride on angle iron or barstock. In the picture notice the carriage is steel tube with barstock pop-riveted to the side , a simple copy of the Lucas mill side rails with materials I had on hand.The ends are bolted on and slightly adjustable to take out any welding distortion.The assembly came out pretty flat........
Post by: Crusarius on February 10, 2019, 09:31:32 AM
I see adjustable holes. that mean the cross slide will be adjustable? how are you going to do up and down? Just use the router?
I would love to do something other than the router since mine is a royal pain to adjust.
Post by: Al_Smith on February 10, 2019, 09:54:41 AM
I've got a 3.5 HP plunge router .Ryobi which is just like Craftsman and Freud except for the color of the handle .That thing scares me to death and I will not run it freehand .That thing could gnaw your hand off in a millisecond so it's only used table mounted .Were I to build something like this I would prefer it to be very sturdy made using a tool like this with that much power .
Using a 3" panel raiser I don't take full depth but do it in multiple passes .That thing with that large of a tool could kick a piece of oak out with such force it could really hurt a person .I've got all my fingers and both eyes and would prefer to keep it that way .
Post by: mike_belben on February 11, 2019, 12:40:24 PM
QuoteScrap Pass
My favorite phrase during the smith and wesson years. A lot of my paychecks went right back into their account.
And its a good thing because all those paychecks i brought home just slipped through my fingers.  still got all my junk though!  :D
Post by: DWyatt on February 13, 2019, 07:08:38 AM
Got some goodies in the mail last night 8) I'll add more pictures when I get the router box portion made. I ended up going with a 1 1/4" straight bit, we will see how it goes but with a 1 3/4 hp router I didn't want it to be overloaded. The rails are 8' long so that should get us in the neighborhood of 7'-6" length in one set-up.
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-735723069.jpg?easyrotate_cache=1550059619)
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-457598150.jpg?easyrotate_cache=1550059619)
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-805763969.jpg?easyrotate_cache=1550059619)
Post by: Crusarius on February 13, 2019, 07:33:58 AM
I bought a 2" and 2 1/4" straight 2 flute carbide cutter. I think my router is a 1hp. it works good I have taken a heavy 1/16" off in one pass with no problem.
I got my cam followers I ordered yesterday. Should be getting my linear bearings on friday. Of course those parts are supposed to be for the mill but if they do not work there they will work great for router sled.
Post by: mike_belben on February 13, 2019, 07:48:25 AM
I wonder how big of a cutter a lawn mower engine could turn ?
;D
Post by: Crusarius on February 13, 2019, 07:59:28 AM
hmmmm. Mike you are a baaaaad man!!!!
Post by: doc henderson on February 13, 2019, 09:14:19 AM
that is a cool idea, could flatten a slab anywhere.  Not the same rpms but with a big cutter the outside edge is moving pretty fast.  I think routers turn about 15 to 22 thousand rpms.   :)  smiley about 29 rpms
(https://forestryforum.com/board/Themes/default/images/post/xx.gif)
Re: Router sled for surfacing slabs (http://forestryforum.com/board/index.php?topic=105001.msg1635838#msg1635838)
« Reply #51 on: Today at 07:48:25 AM »
Post by: Hilltop366 on February 13, 2019, 10:08:13 AM
LUCAS MILL - Planing & Sanding Discs - YouTube (https://www.youtube.com/watch?time_continue=37&v=aZ-Ubkwsl4Y)
I looked on the Lucas web site but I did not find the diameter of the disc, there are two sizes for different size mills.
The smaller disc is for the 6" mill that uses a 16 or 18 hp, the larger disc goes on the 30hp mill
From the planer disc instructions
Post by: Crusarius on February 13, 2019, 10:32:52 AM
but that is 900+ for a spiral head. If I am going to spend that kind of money I would just buy a nice planer. Problem is i want 25" width.
Post by: Hilltop366 on February 13, 2019, 10:49:58 AM
The bargain seems to be the 12" for a Delta planer $426.00 https://shelixheads.com/SHELIX-heads_for_Planers/SHELIX_Heads_for_Planers_by_DELTA (https://shelixheads.com/SHELIX-heads_for_Planers/SHELIX_Heads_for_Planers_by_DELTA) not sure of the diameter of the planer head so the issue may be getting the bearings and drive pulley set up so they don't interfere with multi passes on a wide plank.
Another more costly option could be spiral cutters for shapers and molders https://shelixheads.com/SHELIX-heads_for_Shapers_and_Moulders/shelix_for_shapers_straight_bore_112 (https://shelixheads.com/SHELIX-heads_for_Shapers_and_Moulders/shelix_for_shapers_straight_bore_112), they are not 12" but wider than you can cut with a router bit.
A guys aloud to dream, right? :D
Post by: Crusarius on February 13, 2019, 10:53:10 AM
So true. I was actually thinking of building my own super wide planer. But for just the shelix heads it made the cost a little high for me to swallow. Maybe one day. But till then a router sled will work perfectly.
Post by: Hilltop366 on February 13, 2019, 11:19:47 AM
Yep, if you had a lot to do or had lots of opportunity to flatten slabs for hire it might be worth it otherwise the router is probably the way to go.
Now if there was a way to make the router travel back and forth and advance in the cut on it"s own.......perhaps up one side of the slab and down the other.....
I'm always dreaming.
Post by: hopm on February 13, 2019, 11:52:02 AM
Dreamer = progress
Post by: doc henderson on February 13, 2019, 12:12:15 PM
Mike maybe you can lay all the slabs in the yard and mount the cutter to a mowing deck, can use pulley to get rpms.  then just drive over all the slabs.  Sadly someone is bound to try this.  lol.  turned your dream into a nightmare.
smiley_beertoast
Post by: Crusarius on February 13, 2019, 12:18:11 PM
Setting up limit switches and stepper motors to automate the process would be pretty easy and relatively inexpensive.
could set the slab then place your rails and have clip on limit switches that clip to the rails then simple program for offset and hit run. It will run until it contacts a limit switch shutting it off.
Depending on what happens with all this I am working on it may be something worth doing. But in the grand scheme of things how often will I need to surface anything over 12". a dewalt or porter cable 13" planer from any of the big box stores is about $600. Would be a worthwhile investment for my level or surfacing.
Or I sell surfacing services? Dunno, lots of options. Maybe that is a good idea.
Post by: tule peak timber on February 13, 2019, 12:35:20 PM
The insert cutterhead that is in the current version of the surfacer I'm working on.
(https://forestryforum.com/gallery/albums/userpics/35190/DSCN2034.JPG?easyrotate_cache=1550078955)
 The next generation will have a slower speed motor (electric) and more HP to drive something like this-
(https://forestryforum.com/gallery/albums/userpics/35190/DSCN2035~0.JPG?easyrotate_cache=1550079158)
 Beyond this diameter of end tooling I think the next step is horizontal and belt drive -like an open planer head.  Rob
Post by: Crusarius on February 13, 2019, 12:59:44 PM
tule peak is that a 3" cutter? I like the bristle idea.
Could always make a chain drive series of spindles or even gear drive that runs 4 2" router bits. Aligning would be a PITA but could be done pretty easily. be setup just like gang drills are.
Post by: tule peak timber on February 13, 2019, 01:06:34 PM
7 inch - so it will need to slow down !
Post by: Crusarius on February 13, 2019, 01:31:32 PM
I meant the cutter diameter. looks like 3"
What is the spikey? will that actually take stock off?
Post by: tule peak timber on February 13, 2019, 02:41:30 PM
The Amana cutter is about 2.25 inches in diameter. The 7 inch disc from Kutzall, has carbide spikes that work very well at material removal. Rob
Post by: alan gage on February 13, 2019, 02:43:55 PM
Quote from: Hilltop366 on February 13, 2019, 11:19:47 AM
Kbeitz made one last year: Band mill Router Plane in General Woodworking (http://forestryforum.com/board/index.php?topic=99774.0)
Alan
Post by: Crusarius on February 13, 2019, 03:09:34 PM
What kind of a surface finish does that leave? I would expect some crazy swirl marks?
Post by: tule peak timber on February 13, 2019, 03:58:58 PM
It can , and does.....Still our number one way of surfacing slabs is with a hand router. This pic is from  5 minutes ago......
(https://forestryforum.com/gallery/albums/userpics/35190/DSCN2037.JPG?easyrotate_cache=1550091496)
Post by: Crusarius on February 13, 2019, 04:03:38 PM
I think you mean hand planer :)
you know how easy it would be to put rails on the walls and use those for some surfacing thing?
Post by: tule peak timber on February 13, 2019, 06:55:01 PM
Yes I meant hand planers. Your suggestion for rails on the walls is good-look a little further down the photo :)
Post by: doc henderson on February 13, 2019, 07:21:49 PM
nice tule.  looks like that room was made for doing live edge slabs.
Post by: WLC on February 13, 2019, 11:44:31 PM
Doc, you need to look through some of Tule peaks photo's.  They do amazing work in his shop.
Post by: Crusarius on February 14, 2019, 07:37:39 AM
Quote from: tule peak timber on February 13, 2019, 06:55:01 PM
aha. thought that was a tool holder :)
Post by: tule peak timber on February 14, 2019, 09:06:16 AM
The notched boards were the last generation sled mounts .
(https://forestryforum.com/gallery/albums/userpics/35190/DSCN1593.JPG?easyrotate_cache=1550153131)
Post by: Crusarius on February 14, 2019, 09:39:56 AM
you definitely optimized your space very well. are those kinda separate from the shop and vented outside to keep dust down?
Post by: tule peak timber on February 14, 2019, 10:18:27 AM
Yes, like a low volume wind tunnel.
Post by: Crusarius on February 14, 2019, 10:26:09 AM
you have fans or does it just act like a chimney and pull the air out? That looks like a perfect dust less setup.
Post by: tule peak timber on February 14, 2019, 10:46:17 AM
Yes on the fans and heat, yes the room naturally ducts air flow ( lucky !)
Post by: mike_belben on February 15, 2019, 07:09:53 AM
Quote from: doc henderson on February 13, 2019, 09:14:19 AM
Yeah but look at the torque!  We will just have to gear it up a few notches wont we?
I always wondered what a floor buffer with a sanding disk would do to a piece of rough lumber.
Post by: Crusarius on February 15, 2019, 07:19:57 AM
I would expect sawdust :)
Post by: doc henderson on February 15, 2019, 01:34:24 PM
or the square buff type?  floor sander
Post by: DWyatt on February 18, 2019, 07:58:57 AM
I got it all put together this weekend and did a test run on a slab 8) overall I am pretty happy with how it works, one thing I will be changing is adding extensions to get the 80/20 bearings further apart from each other. Currently the bearings are mounted about 6" from each other which made the sled bind every once in awhile. making them about 12" apart should remedy this problem. The main rails are 96" long and should be able to process 7' material easily and about 45" wide. We also added the option to make it narrower in 6" steps as well (set at the middle set of holes in the picture below.
(https://forestryforum.com/gallery/albums/userpics/49164/IMG_20190217_130313530.jpg?easyrotate_cache=1550493847)
You can see the bolts in this picture where the bearings are mounted to the box. I need to space them out more to make it less temperamental.
(https://forestryforum.com/gallery/albums/userpics/49164/IMG_20190217_130321040.jpg?easyrotate_cache=1550493846)
And here's a few picture of the slab. Since it was a tree crotch with 3 branches it moved a lot during drying so I took 2 passes at 1/4" each. to get one side flat. We shimmed the slab and I shot screws through the sides that I know will get removed during further processing.
Here's pictures of what I got done yesterday, one side flat.
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-1177205093.jpg?easyrotate_cache=1550493711)
Wear a good mask, hearing protection, and safety glasses. Nothing can prepare you for the mess it makes :D
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-681977861.jpg?easyrotate_cache=1550493718)
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-2070184716.jpg?easyrotate_cache=1550493711)
In the last picture you can see I tested going back and forth across the grain. I much preferred to go with the length of the slab. It definitely doesn't leave a perfect surface but everything should clean up nicely with 80 grit.
Post by: Crusarius on February 18, 2019, 09:50:11 AM
Looks good. you are 100% correct about the dust and the mess. I also found going with the grain was much preferred. It left a smoother finish and was less work. With the setup I have played with going with the grain left me less to clean up as well. What I found works best for me was to make a full pass in the normal cut direction then shift the router towards the smooth side about a 1/4" then return to beginning making a climb cut then move to the uncut side and make your next path. this left me very little uneven if any. I will have to post come pictures of my latest Frankenstein creation. I have one more slab I need to smooth for my drill index part of my machining tools cabinet build.
Post by: DWyatt on February 18, 2019, 10:05:52 AM
One thing I will note is that the D-Handle on the router is a big nuisance here's a picture dad sent me that he took while I was running the router. One hand on the body of the router, one hand on the other side of the sled. I tried to run it with a lighter grip on the router, NOT advised. I was taking nearly 1" wide cuts x 1/4" deep in both directions. While the surface isn't perfect, its flat and sandable.
(https://forestryforum.com/gallery/albums/userpics/49164/60455.jpeg?easyrotate_cache=1550502230)
Post by: Crusarius on February 18, 2019, 10:08:31 AM
I had to remove the handles from my router to fit in my track.
Post by: doc henderson on February 18, 2019, 10:19:55 AM
I use my big porter cable plunge router.  You could also make a base for the router that is a sled inside the sled, but if every thing gets thicker, you have to extend the bit further and it becomes less stable.  I still only cut in one direction so the cut is pulling router in.  If you wanted to could move to each end and cut in both directions, but easier in my opinion to just pull it back across not cutting. If you can lock the cross sled in position for a cut, there is less to hold.  If the sides of you cross sled were shorter it would make your handle work better.  but you may need the c-channel effect to support weight going across a wide slab.  the bottom of my cross sled is only 3/8th inch thick so I can extend down a ways.  My plunge router has steps to drop by about 1/4 inch at a time.
Post by: doc henderson on February 18, 2019, 10:26:05 AM
my set up made to fit my router, designed for this one project.  your sled looks great.
Post by: doc henderson on February 18, 2019, 10:29:55 AM
It looks like you could set it up on a lower bench or the ground.  That will be good for thicker, wider, longer stuff so you can reach all the way across and still control the router.  My project was end grain so direction made no difference
Post by: doc henderson on February 18, 2019, 10:35:14 AM
If you will be doing slabs with the grain and can surface the long way, I would make a router base that can lock in place, then you just can push the whole sled down the track.  keep the router base and sled base thin so the shank of the huge router bit does not get too much stress. i.e. the thicker all of the bases are, the further you have to extend the bit and or have less of the shank in the collet.
Post by: doc henderson on February 18, 2019, 10:43:25 AM
maybe you could rig double screws or cables to pull your sled equally on each side.  this would decrease binding from torqueing the sled inside the rails and could operate with one hand and drink coffee with the other!!!   smiley_beertoast  .  sorry could not find a cup of coffee.  We will have you thinking like an old man soon enough. 8) Might even want a remote on/off switch to start and stop, esp. if the stuff hit the fan.
Post by: mike_belben on February 18, 2019, 10:44:36 AM
I dont know if metal work carries over at all here but if i was mowing a quarter inch off an aluminum billet and wanted it fairly clean in a single pass it would be a pretty stout two flute end mill and only climb milling.. In the case of wood id be trying to climb with the grain.  If its browning the wood the feed rate is too slow. If its tearing and peeling the wood grain then spindle speed is probably two slow gi en a sharp endmill.  Should be big crescent chips flying off with no heat coloring.
  Ive only milled woodblocks a few times in the bridgeport (which is what a router sled is sort of trying to mimic except in flying gantry format rather than fixed head cutter) but that feedrate and chip output is what youre looking for when doing it on a vertical mill.
Post by: doc henderson on February 18, 2019, 10:48:02 AM
I agree with mike and your final pass after all is flat, might be a thin pass to get better finish, less sanding.
Post by: Crusarius on February 18, 2019, 11:37:07 AM
Definitely agree with mike. and all of doc's rambling :) I guess since fixing my mast issue is not working the way I want I will setup my router sled and get some good pictures and show everyone what I am working on.
Post by: Crusarius on February 18, 2019, 11:24:27 PM
Finally 12 hours later the video is done uploading. I hate frontier!
Router sled surfacing spruce slab - YouTube (https://youtu.be/KdErZaL5yas)
I will have more later. not trying to upload from home again.
Post by: Crusarius on February 19, 2019, 08:39:18 AM
here is another video.
Router surface 1 - YouTube (https://youtu.be/km6eMz_YS9A)
Post by: DWyatt on February 19, 2019, 11:04:06 AM
Yours is much smoother than the one I made. :o Some of which may be a function of the depth of cut, but I definitely think the actual linear bearings you're using are the ticket. A couple questions.What size of bit are you using and with what router size? What is the base that your router is on that fits in the groove of the extruded pieces? What is your depth of cut your taking and how wide are you in between the rails?
Post by: Crusarius on February 19, 2019, 11:15:55 AM
That slab is about 14" wide I think I was 18" between the linear bearings. The plate on the router just happened to be the plate for my router table. It fit perfectly in the grooves.
The bit is either a 2" or 2 1/4" 1/2" shank carbide 2 flute cutter. I don't remember which one I had in it.
At the deepest cut I was probably taking 1/16" off. I have done quite a bit more than that but (around 1/4" maybe?) was trying to keep that slab as thick as I could for the project I am using it for.
I think the router is a 1hp. I wasn't even using the big porter cable I have.
What I do have sometimes is the router chatters because the plate is not tight in the grooves. But my technique / pattern that I use seems to take care of any issues. The slabs come out smooth enough I could get away without sanding but usually just do a quick 80 grit rub down on my DA.
Post by: Tom the Sawyer on February 19, 2019, 04:15:04 PM
Crusarius,
We, too, have very slow internet service.  I have found that when I need to upload a large file, like an HD video, it is much easier to save it to a laptop, or tablet, and then drive to our local branch of the county library.  They have free Wi-Fi that works not only in the building, but out in to the parking lot and you can even park in the lot near the building, after hours, and upload large files in minutes instead of hours.
Post by: Crusarius on February 19, 2019, 04:18:28 PM
thats not a bad idea. I doubt I have anything like that around me but maybe. I just bring it to work and upload from here. the second video I uploaded to less than 2 minutes the first one took 7 hours.
Post by: Tom the Sawyer on February 19, 2019, 04:46:03 PM
Around here, the McDonalds also have free wi-fi, although it isn't as quick as the library and it bombards you with ads.
Post by: Crusarius on February 19, 2019, 04:50:25 PM
the nearest mcdonalds to me is 30 minutes. I am pretty sure the public library is on the same crappy frontier service I am on.
I live in the middle of nowhere. It takes a while to get to everywhere.
Post by: xlogger on February 19, 2019, 06:36:42 PM
I have Frontier also, just lucky now I can get on. They suppose to come out tomorrow for repairing. I hate them also, they have to come out way to often.
Post by: Crusarius on February 19, 2019, 07:25:29 PM
they offered me 3 upgrade packages. and each one requires a new junction box to be installed down the road cause the box is maxed out. Each package would have been cheaper than what I am paying now but they still couldn't just give me the price even though they can't give me the service.
crock of poopy. They keep selling me pkg's that I can't get. The service is spotty at best. I hate frontier.
Post by: charles mann on February 19, 2019, 10:59:40 PM
Quote from: Crusarius on February 19, 2019, 07:25:29 PM
what about cellular service? which cell provider offers service in your area? do they offer a plan for hot spotting? we were working a fire in napa valley 2 yrs ago and the fire had burned the at&t towers down, but verizon towers were up and running. luckily, i buy my phone out right from apple, and always get the unlocked phones. i went to verizon and after a few of arguing with the guy, he learned something new, that an unlocked, using at&t would also run a verizon sim card. i purchased a 10 gb data plan for around $60 a month, which lasted me over a month, but bc i didn't reload the plan, i lost 3 gb of data usage. basically what I'm saying is, see if a cell provider has a plan that you can buy a data plan, and hotspot to your computer and use the cell service to upload.
Post by: Crusarius on February 20, 2019, 07:15:10 AM
Charles, great idea. but the cell service is worse than the DSL. I have verizon, it is the only one that works there. and the service is spotty at best. They continue to "upgrade" the infrastructure around me. It seems that everytime they "upgrade" something my service gets worse. I am pretty sure its a planned obsolescence program... Especially since I used to have pretty good coverage at the house.
Post by: DWyatt on February 20, 2019, 07:28:31 AM
I feel all your pain with the internet service, we have a Verizon hot spot. It's our only option other than some kind of satellite service and I know better than to ever try that. I listened to Dad complain about the service and Mom complain about the bill for too long :D
On a different note, I surfaced the other side of the slab yesterday evening. I had to take about 5/8" off to get it flat. I did so in 3 passed (1/4", 1/4", 1/8") I used the method Crusarius talked about, taking a cut then backing off ~1/4" on the return. Much nicer surface! Now after spending some personal time with this unit, I would never consider it a primary tool in the shop but it will definitely be a nice one to have in the arsenal.
Here's a picture of the slab, almost no marks from the router. This thing is purdy  8)
(https://forestryforum.com/gallery/albums/userpics/49164/Snapchat-248082697.jpg?easyrotate_cache=1550665683)
Post by: Crusarius on February 20, 2019, 07:32:11 AM
That came out great. I am glad to know that my technique worked. I have only tried it on spruce. Was that sanded at all? that is ash right?
Post by: tawilson on February 20, 2019, 07:57:29 AM
Quote from: DWyatt on February 20, 2019, 07:28:31 AM
I had a Verizon hotspot device and wasn't happy with it so swapped it in for a Mifi which replaces a landline with cell. It got a much better signal than the hotspot . I now have Spectrum internet but kept the Mifis because I can put them anywhere with power and connect a surveillance system and access the cameras on the internet. Verizon seemed like they didn't want to push the Mifis but they were much better than the hotspot.
Post by: DWyatt on February 20, 2019, 08:26:54 AM
Quote from: Crusarius on February 20, 2019, 07:32:11 AM
That is not sanded at all, I blew the dust off and snapped a picture. It is white oak. Cut about a year ago and dried in the kiln about a month ago. The areas where the branches are "braided" together was Hard! The 1 3/4 hp router didn't like taking 1/4" bites at 3/4" wide through those parts.
Post by: DWyatt on February 20, 2019, 08:32:23 AM
Quote from: tule peak timber on February 13, 2019, 12:35:20 PM
Are you running that Amana surfacing bit on a variable speed router? I looked it up and they say 18,000 max RPMs and the router I have is running at 27,500 RPM. I'm not sure of the implications if you run a bit like that too fast other than my mind tells me it could be bad.
Post by: Crusarius on February 20, 2019, 08:36:19 AM
typically if you spin them to fast they have a tendency to come apart. It could be very bad :)
I would be mostly concerned about the carbide inserts breaking and turning into projectiles.
Post by: doc henderson on February 20, 2019, 08:41:50 AM
I agree, it may also be hard on your router.  may bend or break the shaft.  may just make more heat.  I have a big PC plunge with variable speed, but they make pedal switches that are also variable speed.  at that diameter, the cutters are traveling fast on the outer edge.  looks great.
Post by: DWyatt on February 20, 2019, 08:48:07 AM
That was my thought. Nothing would be better than taking a chunk of carbide in the gut.
Post by: Crusarius on February 20, 2019, 08:57:54 AM
Done that plenty of times with wire brush pieces :) 12000 rpm's kinda hurt
Post by: tule peak timber on February 20, 2019, 10:11:27 AM
Yes on the variable speed, large motor.
Post by: mike_belben on February 21, 2019, 09:12:43 AM
Awesome work but probably oughta put that router on a speed controller before you grenade something and get a not so free ambalamps ride.
Post by: Crusarius on February 21, 2019, 09:31:07 AM
I don't think that is going to be a problem since it is a router bit. its reasonably high quality for the price I paid.
Besides I am member of the VFD I get free rides :)
Post by: mike_belben on February 21, 2019, 01:40:00 PM
Well a variable frequency drive beats calling the volunteer fire department in this case.  If were comparing VFDs   ;D
Post by: Crusarius on February 21, 2019, 01:41:09 PM
lol mike. thats pretty good.
Post by: sam-tip on February 27, 2019, 03:18:57 PM
(https://forestryforum.com/gallery/albums/userpics/28038/20181004_181827.jpg?easyrotate_cache=1551298345)
My plan is to use a 9 inch insert planner blade on the swingblade/slabber mill.  Will need to adjust the blade offset so the blade is flat.  35 hp should make quick work of the slabs.  I have a garage and barn full of slabs.  Then use the sanding pad to finish the wood off.
Post by: Crusarius on February 27, 2019, 04:05:40 PM
That would definitely be pretty slick. And make short work of it. It doesn't really take all that long with my setup but could definitely be faster.
Post by: aigheadish on December 30, 2020, 01:09:50 PM
Thanks for this thread! Lots of good info as I've contemplated building a router sled for a while now.
@Crusarius (https://forestryforum.com/board/index.php?action=profile;u=35059) Your sled looks smooth as butter, well done!
@doc henderson (https://forestryforum.com/board/index.php?action=profile;u=41041) Your version looks more my speed and budget
@tule peak timber (https://forestryforum.com/board/index.php?action=profile;u=25190) That setup and slab are incredible!
Post by: doc henderson on December 30, 2020, 01:16:07 PM
great.  I made it and used it the same day.  let me know if you need more details.
Post by: aigheadish on December 30, 2020, 02:17:16 PM
I will, thanks! I've likely got a ways until I've got a slab I like enough to actually use, but maybe that's an excuse to practice on stuff I don't like that much...
Post by: Crusarius on December 30, 2020, 04:10:11 PM
Thanks for the comment. The linear bearings worked great, nice and smooth. the 8020 that I was using for the other direction not so smooth. but the good news was that only move the little bits at a time while the linear bearings ran the length. it really would not take much to automate my setup either.
I am actually planning using what I learned from this experiment to build a 5x12 or at least a monster CNC for doing everything. Ultimate goal would be to cut anything and everything from wood to steel to whatever I want in between. Plus a 4th axis for doing round stuff.
Post by: busenitzcww on December 31, 2020, 08:38:40 PM
Lots of good info in this thread! I've had a 20" grizzly spiral head sitting in my shop for over a year with the intentions of building a 5hp 3 phs planer carriage to on my lt15 wide similar to the MP100. I debated wether to build something bigger but I can cut 36" on my mill, sand 36" with my widebelt so figured I'd just stay the same on my planer. Got bearings, pulleys, chain, acme rod, gears, etc coming in the mail and hopefully we put it all together soon.
Post by: Crusarius on December 31, 2020, 10:16:27 PM
that will be a fun build. I have toyed with making a planer for my mill bed as well. but the cost of materials is very prohibitive.
Post by: aigheadish on August 17, 2022, 12:43:01 PM
I posted elsewhere, I think, but this looks like the home for router sleds. This is mine after reading through all you's guy's stuff. I've only used it on a chunk of Ash I turned into my mantle but it worked well. It's just melamine board on melamine rails, width of up to around 40ish" and around 6' long, if I'm not mistaken. I've got a log laying in the yard that is due to be sliced up soon, so I'd imagine this will come down off the shelf for that.
(https://forestryforum.com/gallery/albums/userpics/63516/rsled.jpg?easyrotate_cache=1615833865)
(https://forestryforum.com/gallery/albums/userpics/63516/20211025_170320.jpg?easyrotate_cache=1640178881)
Post by: Walnut Beast on August 17, 2022, 04:02:55 PM
Very nice job 👍
Post by: trimguy on August 18, 2022, 07:10:54 PM
I need to build me one of those.
Post by: Geeg on September 03, 2022, 08:48:02 PM
I built one last year that I use on my sawmill bed, when I am not using it, it gets hoisted to the roof of the sawmill shed. Like the option of having it outside as this keeps the dust down in my shop. I offer his service and since the build it has paid for itself. It is capable of planing 5.5ft x 12ft. The whole frame comes from 80/20.
(https://forestryforum.com/gallery/albums/userpics/21627/IMG_20210301_130016.jpg?easyrotate_cache=1662252235)
(https://forestryforum.com/gallery/albums/userpics/21627/IMG_20210615_121659.jpg?easyrotate_cache=1662252211)
(https://forestryforum.com/gallery/albums/userpics/21627/IMG_20210814_155853.jpg?easyrotate_cache=1662252184)
(https://forestryforum.com/gallery/albums/userpics/21627/IMG_20210622_130757.jpg?easyrotate_cache=1662252161)
Post by: Crusarius on September 03, 2022, 10:04:47 PM
That is pretty slick. I like that.
I have since built a CNC slab flattener that is currently capable of 5'x12' surfacing.
Crusarius Home built CNC in Drying and Processing (forestryforum.com) (https://forestryforum.com/board/index.php?topic=118931.msg1905534#msg1905534)
If I had power near my sawmill I would probably have made it attach to the sawmill. But not having power out there is challenging. Especially as the sun is going down.
Post by: Larry on September 03, 2022, 10:11:09 PM
I like it.  Planning on something similar but not as big.
Which direction do you get the best cuts, length wise or across?
Post by: Geeg on September 04, 2022, 09:23:11 AM
Quote from: Larry on September 03, 2022, 10:11:09 PM
I cut length wise, this seems to give the best results. The original sled cut up to 8ft, I just add on the extension if needed for larger slabs.
Post by: Daburner87 on September 23, 2022, 09:08:42 PM
I envy some of your guys tools.  Anyway, I saw a router sled build on youtube for under $25.  I'll probably give it a try.
Post by: Crusarius on September 23, 2022, 11:31:56 PM
My router sled worked very well. especially since it was all from the scrap bin :)
But I like the CNC approach now :)
