Author Topic: Stihl MS 250 18" chain "sizing problems"  (Read 3352 times)
Offline woodguy65
« on: September 28, 2018, 11:59:24 AM »
Ok guys new to the forum, need your expert opinion.  Several months ago I got together with a buddy to cut firewood for his father (over 3 hours away for me).  I have 3 Stihl MS 250 18" chainsaws, my buddy also has 1 of the exact same Stihl saws - except his was purchased within the last year.   Upon leaving, somehow my buddies ended up in back of my truck and we did not figure out until I was almost home.  It was hard to tell which was "his" saw so picked the newest looking one, arranged to get it back to him that week.
Several months have passed and get a call from him stating I dropped off the wrong saw.  I'm puzzled how he is just now realizing - he said that when he went to change the saw blade, his new chainsaw blade that he purchased with the saw,  would not fit "this" saw.  He said while it was the same length - it would not fit in the grooves of the bar.  He said, the old chains will fit the new saws, but the new chains will not fit the old saws.  By "old" mine are only 3-5 years old.  I told him that does not sound right and can't believe Stihl would do that.
I even stopped at Big R today who sells them and went and spoke with a service department mechanic who works on them and posed the question.  He said that is not the case - an 18" stihl chain should fit any 18" regardless.
So can any body add anything else to this:  Did Stihl "change" anything with their new bars/chains so that they are no longer interchangeable?
Offline farmfromkansas
Re: Stihl MS 250 18" chain "sizing problems"
« Reply #1 on: September 28, 2018, 02:33:35 PM »
My old MS250 takes a shorter chain than my MS 290, even in 16", even with the 325 chain.  My MS250 takes a 62 link chain, and the MS290 takes 67 links.  Maybe something has changed to make the new ones take the same chains as the other models.
Offline dougand3
« Reply #2 on: September 28, 2018, 03:51:27 PM »
That describes gauge. 1.3, 1.5, 1.6 mm  AKA .050, .058, .063 in.
Yeah, an .063 chain won't fit in .050 bar. All this data is on the on bar - also pitch and DL. Check bar out.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #3 on: September 28, 2018, 05:33:05 PM »
Here is some more food for thought, my 024 with a 16" .325 runs 67 dl .063 & 16" 3/8p bar runs 60 dl .050 my 180 with a 16" 3/8p bar runs 55dl and a .043 chain if I had a 16" 3/8 for my 362 it would also run 60 dl. An old wildthing I was given, runs 3/8 low pro with an 18" bar 62dr .050.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: September 28, 2018, 08:31:39 PM »
I would think that the selling Stihl dealer(s) would have the serial numbers on file.
Offline realzed
  • Old Fart
« Reply #5 on: September 29, 2018, 01:16:35 AM »
OR for the same model of saw in close to subsequent years - the actual ascending serial number would I imagine should tell you which is the most recent version by logically greater sequence number..
Barring that, Willard (Hollmantree) showed us how the month, year, and somewhat version number of most Stihl saws could be identified by looking under the plastic shrouds at the injection molding date codes, in an earlier posting on his Stihl 261 thread I believe it was..
Offline woodguy65
« Reply #6 on: September 29, 2018, 07:21:20 AM »
OK thanks guys.
smallest stihl "0" series saw to run 3/8" chain
Started by 421Altered on Chainsaws
Last post November 08, 2019, 12:06:24 PM
by pine
any suggestions on a "full chisel" chain for stihl 310? what about bars???
Started by fury1973 on Chainsaws
Last post January 23, 2012, 05:10:56 PM
by tcrew
20", .325 Narrow Kerf Bar & Chain vs. Standard .063" Set-up on Stihl MS 261
Started by RFK on Chainsaws
Last post June 13, 2019, 09:18:31 PM
by RFK
"New" Stihl .325 NK chisel chain.
Started by HolmenTree on Chainsaws
Last post June 22, 2020, 08:40:47 AM
by Magicman
