Author Topic: Ford 540 vs 445... Now 545 D  (Read 4080 times)
Offline Andries
  • Making buildings out of big curvy logs
Re: Ford 540 vs 445... Now 545 D
« Reply #60 on: October 14, 2021, 09:36:53 PM »
Sounds like you're going after it, good work.
Couple things things;
- The 134 oil you have should be marked as suitable for wet brakes. If not, some chatter and noise will let you know that the oil isn't the right formula.
- I've checked for four wheel drive action by lifting the front of the loader on the heel of the bucket, then driving forward with the 4wd engaged. The front tires will rotate while they're up in the air as you move forward. Not a complicated check, but proof positive, and no slippery slope needed.  :D
- Be sure to check the front tire final drives for oil level. They each take about 1 litre of the hydraulic oil used everywhere else on the machine. The level is marked on the wheel hub.
- when you're on steep slopes, low range and 4 wheel drive engaged is your friend. Engine braking is smooth and super strong. I realize you're in California, but that'll prevent toboggan slides in a big way.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline ljohnsaw
« Reply #61 on: October 15, 2021, 01:02:20 AM »
On the oil, the manual says to use 134 C or D.  The bucket says it is compatible with 134 A, B and C.  So, we'll see how it goes.  I had the front end lifted up (on the bucket) when I was sliding the coupling back into place.  I could turn one wheel and the drive line would spin so the gears are there.  Just want to make sure they are quiet/not ground up.  I did notice if I'm in a low gear that it will slow my decent down a steep section of my drive quite well.  When I get back up there to do the front diff, I will be checking all the levels in every nook and cranny and shoot all the zerks while I'm at it.
I don't have any manual for how the chains should be installed on the 3pt but do see rigid supports in the Accessories section.  They show connecting to this:
Is that what you were talking about?  My Gannon box has three tabs on each side to connect the lower 3pt arms.  Right now, they are between the inner set and it looks pinched.  I'm going to move them out when I change the chains to the outside.
John Sawicky
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline newoodguy78
« Reply #62 on: October 15, 2021, 09:12:15 AM »
Yes those are the attachment points for the stabilizer bars, youre only missing the bolt on stud. Ours has bars that go from there to the tip of the 3ph arms. Theres a left and a right, shaped like a hockey stick with 2 holes in one end and one in the end that attaches to the tractor.
When youre greasing theres 4 zerks on the coupler between the crank and hydraulic pump under the radiator,not the handiest place to get at.
FWIW Ive talked to several older ford mechanics all of them recommended using coolant system treatment in the antifreeze. Apparently this generation engines are known for having potentially porous blocks and are an unsleeved engine. The treatment is supposed to stop issues that create problems.
I use Napa Kool part number 4058
Offline ljohnsaw
« Reply #63 on: October 20, 2021, 01:08:49 AM »
10) Coolant - I added some NAPA Kool to the radiator.
9) Battery - Soldered on some heavy lugs to the battery wire and now snugly attached to the battery.  The "Thermostat" pre-heater works pretty well.  Took two tries at 30F this morning.  You hold the switch on for 15 seconds then, still holding, crank the engine for no more than 30 seconds.
3) Gannon rams - Really need to rebuild the two on the arms.  The left side does not hold - a real PITA.  Hoping its the ram and not the valve.
2) 4wd -  Definitely works.  Made good use of it scraping the snow from my driveway today.
1) Front left tire - flat and off the rim this morning.  Had to ratchet strap it and run up the air to 75 psi.  At the end of the day, the front tires had ~70 on the left and ~73 on the right.  I'll check it next time I go up and pull the left one if it needs to go to the shop for repair.  I don't see anything in the tread.
Before:
After:
Edit:
I picked up a box of 10 dash bulbs for $10.99 at O'Rielys auto parts store (order online).  Didn't have time to pull the dash today.
One other issue - the PTO runs all the time.  I change the lever but does not stop.  What should I look for?
John Sawicky
Offline thecfarm
« Reply #64 on: October 20, 2021, 05:38:49 AM »
I would put tubes in the tires.  ;)
Offline Andries
« Reply #65 on: October 20, 2021, 09:21:30 AM »
You had mentioned an issue with the 4wd. drive shaft. This pic shows the skid plate on mine, from front diff looking back.
Newwoodguy78 wrote about the 3pt. hook up to the box blade. It's tough to describe so I took a pic.
You can see the pto has a screw-on cover, just below the lift up shield. Check the linkages from the lever on the left side seat to the actuator arm in front of the diff. A pin may have come off, disconnecting the linkages.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline ljohnsaw
« Reply #66 on: October 20, 2021, 10:50:47 AM »
Yeah, I'm definitely in need of the 4wd shaft cover!  That may be a tough one to find.  Probably have to make something.  I need to check the linkage but didn't want to crawl around in the mud.  I saw the 3pt side supports online.  I have some metal and might make up my own but I forgot to measure.
John Sawicky
Offline newoodguy78
« Reply #67 on: October 20, 2021, 12:08:29 PM »
I like those stabilizer bars , different than ours much better design.
As was said I d definitely check the linkages first. Id have to check the book to see how that one works. Possible the brake band is out of adjustment or broken.
I had that problem on our 6600 Ford was a broken band, thats a split it in two job to fix.
Offline Andries
« Reply #68 on: October 20, 2021, 05:05:23 PM »
That style of stabilizer is nice 'cause they can be adjusted for a left or right offset.
Road crown with a land plane is dead simple when you can set tilt with the arm adjuster (black knob on the right arm) and offset with the stabilizers to reach over to beyond the rear tire.
But then I've got a few miles of old gravel road to dress up a few times per year. That chore will make a guy fussy about what's dragging on the ground behind him . . . . 😆
LT40G25
Ford 545D loader
Stihl chainsaws
Offline chevytaHOE5674
« Reply #69 on: October 20, 2021, 08:38:22 PM »
Does the PTO spin with power all the time of when in the off position can you stop it with a 2x4 or something? Could be a bad brake, or warped clutch disc's and friction plates.
Offline ljohnsaw
« Reply #70 on: October 20, 2021, 09:26:12 PM »
Seems to have power all the time.  I just used my hand at low idle - it is engaged.  Next time up the hill, I'll look at the linkage.  Problem is the 7 day forecast is calling for SNOW.
John Sawicky
Offline newoodguy78
« Reply #71 on: October 20, 2021, 09:54:09 PM »
Do you know if that brake can be adjusted externally or is that an inside job ?:D
Not to tell you your business @ljohnsaw but please dont make a habit of grabbing those pto shafts with your hands they have no conscience at at all. Like Chevy said wedge a 2x or a stick off the drawbar against it.
Not sure if the 545 is the same as our 445 but there is no linkage on ours it goes directly into the rearend on a splined shaft. Curious what you find in case ours ever has a problem
« Reply #72 on: October 20, 2021, 10:10:05 PM »
There is no brake adjustment and don't think any linkage to adjust. The handle goes directly into the valve inside the transmission if its like its Ag counterparts.
The brake is kind of a turd of a design. If the clutches are warped at all the brake has no chance of holding anything. Heck even cold oil can cause enough drag to overcome the brake. If it spins but can be stopped with a wedged block of wood then suspect a brake issue. If it spins with power and can't be stopped then its usually a clutch issue. Servicing requires a split between trans and rear axle.
On the large frame fords (9700, TW, 30 series, etc) there is an updated PTO clutch pack to give more holding power and longer life. Unsure if the same is out there for the small frame machines.
I usually don't tear into them unless the PTO doesn't stop with something heavy like a brush hog hooked to it.
Offline newoodguy78
« Reply #73 on: October 20, 2021, 10:37:21 PM »
Gotcha was looking at ours and the only thing I could see to adjust it was possibly take the handle off and rotate it on th splined shaft to apply more pressure to the band.
Never messed with the bigger Fords but had the 6600 apart to fix the pto issues one of which was it wouldnt stop. Wasnt exactly what Id call a rugged setup. Its worked well ever since but try to keep it on lighter pto duty.
« Reply #74 on: October 20, 2021, 11:18:41 PM »
The 545D doesn't use a band like some of the smaller ford AG tractors. It uses a spring applied, hydraulic released little brake arm. The braking surface is fairly small and zero adjusments.
With the tractor not running can you spin the PTO shaft? If you can then I'd suspect the brake has failed. If doesn't turn then id suspect clutches.
Hook something big and heavy to the PTO and see if that stops it.
Offline ljohnsaw
« Reply #75 on: October 26, 2021, 11:54:08 PM »
If you end up wanting a quick tach that accepts standard bobcat attachments let me know theres a company that makes them.
ohhh, and btw, a quick attach on the fel will bring a smug smile to your face every time you change attachents.
Can you guys post some picture of your quick attach setups?  Newoodguy78, can you send me some info on who you used?
Thanks!
John Sawicky
Offline Andries
« Reply #76 on: October 27, 2021, 12:21:18 AM »
Does your setup look like this?
LT40G25
Ford 545D loader
Stihl chainsaws
Offline Andries
« Reply #77 on: October 27, 2021, 12:25:23 AM »
Weld on a 'universal skid steer mounting plate' onto the back of the bucket.
I got a pro to weld mine - I didn't trust my little buzzbox welder, or myself, to hang 5000 lbs on that.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline Andries
« Reply #78 on: October 27, 2021, 12:27:32 AM »
Pin the Quick Attach adapter to the FEL arms.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline Andries
« Reply #79 on: October 27, 2021, 12:30:58 AM »
This is the tag on my adapter.
I'd estimate that model # on mine will fit on yours.
LT40G25
Ford 545D loader
Stihl chainsaws
moved
MOVED: Old track vehicle,model T ford,model A ford ,antique snowmobile meet
Started by chet on General Board
Last post January 09, 2015, 11:19:20 PM
by chet
Started by loggah on Shows, Events and Places to meet
Last post August 24, 2015, 07:55:27 PM
by coxy
6.7 ford
Started by snowstorm on Forestry and Logging
Last post January 07, 2016, 07:10:33 PM
by bushmechanic
ford 7.3
Started by coxy on Forestry and Logging
Last post January 12, 2015, 05:40:46 AM
by coxy
