Author Topic: Beware of rotting frames on 2011 to 2021 Chevy Silverados  (Read 1718 times)
Offline beav
  • got any logs?
Re: Beware of rotting frames on 2011 to 2021 Chevy Silverados
« Reply #20 on: September 26, 2021, 05:00:38 PM »
Road salt also teaches drivers it's ok to go 70mph when it's raining and 29 outside.
Online Southside
    • White Oak Meadows
« Reply #21 on: September 26, 2021, 08:31:03 PM »
There is nothing wrong with going 70 in the rain at 29 degrees. Stopping or turning on the other hand...  ;D
White Oak Meadows
Offline snowstorm
« Reply #22 on: September 27, 2021, 08:40:39 AM »
with enough salt and traffic it will stay lucid. down into the 20,s
Online moodnacreek
  • Sawin by the notches
« Reply #23 on: September 28, 2021, 08:36:27 PM »
Once the rust starts you have to spray on some kind of oil at least once a year to slow down the rust. I have been doing this and more on a '71 and a '91 f 350's for years and they are both sound.
Offline farmfromkansas
« Reply #24 on: September 28, 2021, 09:52:25 PM »
The frame on my 04 Chevy 2500 is rusty, has no coating at all.  Seems driving it down a gravel road keeps the rust worn off.  Knew about the older Tacomas having rust problems on their frames, so bought a newer one, 14 as well as all the others on the forum.  Have not noticed any frame rust yet.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #25 on: October 01, 2021, 09:32:18 AM »
Sometimes you get to go 70 in the rain at 29 degrees, turning and turning and finally abruptly stopping whether you want to or not! ;D  Freezing rain is the worst here.  We get more freezing rain than snow most winters.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online moodnacreek
« Reply #26 on: October 02, 2021, 07:52:16 AM »
Wrong.  That's 80 mph here.
Wrong. That's 80 mph around here.
Offline 21incher
« Reply #27 on: October 02, 2021, 08:32:56 AM »
Well 2 weeks later  it's still sitting  at the dealer.  Sounds  like they have a employee shortage  and keep pulling the guy off it to do other big jobs. They  had no one trained  to do the TSB and it's  the worst rusting they have ever  seen on a new truck frame. I still have the brand new Silverado  loaner and don't  know why anyone would  buy one with  the 5.3 and auto stop. The 5.3 is a dog compared to my 6.2 and a gas guzzler.  They also put a pin through the hitch so I can't use my trailer with the loaner. Hopefully next week I will hear more.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline snowstorm
« Reply #28 on: October 02, 2021, 08:55:33 AM »
i know someone that bought a 20 last year with the 5.3 he is claiming 20 tp 24 mpg seems a bit high
Offline 21incher
« Reply #29 on: October 02, 2021, 06:50:08 PM »
I found the sticker they scraped off in the dash and it says 16 / 23. My 6.2  is between 19.1 and 19.6 local driving per tank calculated out. It drops to about  18.5 towing my 8k dump trailer. Hits about 23 to 24 Highway.  There is a big difference between them.  My 6.2 going  along at 55 mph is usually just running  on 4 cylinders.  If you step on it a little  to pass someone It switches to 8 cylinder  and smoothly takes off with no drama . This 5.3 if I step on it a little at 55 it kicks down 2 gears and screams like a sewing machine motor. I never  realized  there would  be a noticeable difference between the 2 because I only test drove the 6.2. I can't  imagine what those little  4 cylinders they are putting in them now sound like.
Online Tacotodd
  • To learn and help
« Reply #30 on: October 02, 2021, 08:19:14 PM »
Screaming for their life.
Trying harder everyday.
Offline barbender
« Reply #31 on: October 02, 2021, 08:47:50 PM »
Wow, that is incredible fuel mileage!👍🏻👍🏻
Offline HemlockKing
« Reply #32 on: October 03, 2021, 06:20:09 AM »
I had the 5.3 and noticed the same, falling on its face then screaming like crazy 2 gears down. I imagine is even worse with the 4.8
Offline Hilltop366
« Reply #33 on: October 03, 2021, 09:29:42 AM »
I used a 2014 (I think) truck with the 6.2 in it to tow my tractor home from the camp, I was rather impressed with the power and milage. I had towed the tractor to the camp with a 1995 dodge with a 5.2, talk about a difference! twice the power and used less than  the gas.
Offline Hilltop366
« Reply #34 on: October 03, 2021, 09:33:46 AM »
On the other hand I was throwing some wood in the back of the Dodge and a block slipped out of my hand and hit the rear fender hard .... never left a mark, if that had been the newer GM it would have stove the side in at least a couple inches.
Offline snowstorm
« Reply #35 on: October 03, 2021, 10:28:42 AM »
We were out west last spring and rented a new youkon the most I saw was 17 mpg for the week. What is up with the transmission in those things? Coming down the mountains of co. It would drop 4 or5 gears at once with a Big Bang
Offline 21incher
« Reply #36 on: October 03, 2021, 11:15:26 AM »
That's why  I bought the dump trailer
That's what this one does. Drops a couple gears at a time but I think it's  because it's still in the learning mode.
Mine always shifts extremely smooth and you don't notice them during normal driving. Put it to the floor or in the trailer mode the shifts stiffen up but don't skip any up or down. I have the 8 speed but I think they changed to a new 10 speed last year. When they change transmissions there always tsb's to improve them That one probably was not treated nice during learning  period being a rental or could need an update.
Those numbers I gave are for 2wd mode and drop slightly when I  go out in the winter using 4wd auto but we usually wait for the snow to melt and I haven't run a full tank in 4wd to do the calculation.
I test drove one of the new RAMs and that felt like something ran into the back of it everytime I stopped. It would  ban down 3 gears after  stopping shaking the truck.  I quickly took RAM off my list because of the tranny.
Offline Ianab
« Reply #37 on: October 03, 2021, 06:26:05 PM »
If it's downhill it will be for engine braking. Dropping one gear in an 8+ speed isn't going to do anything to hold you back as the ratios are so close together.
With an old 4 speed you might drop one gear and get the same effect as 3 gears on an 8 speed. Doesn't mean the have the shifting program perfect of course, but downshifting one gear would be pointless.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #38 on: October 03, 2021, 08:05:11 PM »
I like my 06 6.0 5 speed standard 2500 4x4 oiled every year, goes like a hot rod. Just turned 100,000 miles.
I hope you do well with your truck in the end.
A&P saw Mill LLC.
License NH softwood grader.
Offline 21incher
« Reply #39 on: October 04, 2021, 02:21:49 PM »
Thanks  Peter still no word on when it will be done.
I guess you haven't driven one of these 6.2s. I have a button to drop one gear at a time when going down a hill loaded and each gear does make a big difference at holding the truck back. Cruise control could probably overreact and drop a couple gears if you are using that.  The biggest cause of low gas mileage on them is usually under inflated tires and that's why there is a reading of the pressure  in each tire on the display.
I just read the 2022s will have the ability  to run on from 2 to 8 cylinders pushing the mpg of these engines even higher. It's my favorite engine of any trucks I have ever owned and gets over 3 times the gas mileage of the 460 I had with  much less hp and torque than this.
Tree Rotting Out ?
Started by sr73087 on Tree, Plant and Wood I.D.
Last post July 27, 2014, 08:41:13 AM
by stumpmakerr
Tree rotting at base, cut it down?
Started by sr73087 on Urban and Community Forestry
Last post January 23, 2015, 02:54:19 PM
by Engineer
Rotting tree, dulling chain?
Started by bendjoseph on Chainsaws
Last post August 05, 2011, 08:53:33 PM
by Al_Smith
Keeping porch posts from rotting
Started by BrentRobinson on Timber Framing/Log construction
Last post December 23, 2015, 10:28:12 AM
by fishfighter
