Couple of things I noticed. On your opening cut it looks like you split the taper. I might have taken all the taper out on that first face. That would have given you even width boards when you went to the third face. Might have missed something in the video.The second thing is when you sawed the third face. I would have sawed two flitches never moving from the console. Than I would have used the clamp or the turner to tilt the cant to slide the flitches onto the loading arms, again not moving away from the console. Finally turn the cant and start on the fourth face. This one sequence would have saved a bunch of time and steps.I have a two step rule....I never want to take more than two steps away from the console when sawing. When edging I often break that rule.I've filmed myself a few times and it really helped me develop. I studied the clips and found things I could have done easier or faster. I still have lots of room for improvement.Thanks for taking the time to make and share your video.
Nice video, you explain things well. I like your setup. What was interesting to me was that the controls are mounted so that the head passes beside the operator and that involuntarily made me cringe a little. I assume the band isn't turning full speed when it goes by you, but it still caught my attention because I've had bands pop and send shrapnel and shards out perpendicular to the head, on both the drive and idle side of the head, when in the log or not.
Started by Swedo on Chainsaws
Started by richhiway on Sawmills and Milling
Started by woodman58 on Sawmills and Milling
Started by redneckman on Sawmills and Milling
