Has a squirrel taken up residence in your air cleaner?
Unhook the hose or line between the filter and injection pump
Quote from: ladylake on May 25, 2022, 04:31:35 AMUnhook the hose or line between the filter and injection pumpYou will likely need to bleed the IP after doing that.
Started by jovol on Sawmills and Milling
Started by just_sawing on Sawmills and Milling
Started by Glenn1 on Sawmills and Milling
