Author Topic: Help in identifying this tree  (Read 582 times)
Offline Jarrett
« on: January 30, 2020, 11:30:13 AM »
I have several of these on my fence line in Virginia and I知 not sure what they are. Any clue from the experts? Thanks!
Offline wisconsitom
  • Deep in the larch
Re: Help in identifying this tree
« Reply #1 on: January 30, 2020, 11:58:50 AM »
It's am elm of one type or another, no doubt.  Off the bat, I'd say American elm.
Far as I can tell, it's 6 of one, half a dozen of the other...
Offline Jarrett
« Reply #2 on: January 30, 2020, 01:07:59 PM »
I was guessing elm by the way it splits but wanted to be sure. Here it is cleaned a bit to reveal the grain.
Offline Jarrett
« Reply #3 on: January 30, 2020, 02:51:13 PM »
I致e read that elm has a distinctive 僧anure soaked in urine smell when cutting, however this has no real odor, definitely not a terrible smell.
Offline Southside
    • White Oak Meadows
« Reply #4 on: January 30, 2020, 03:42:54 PM »
I can't see any wavy lines in the end grain, which is a dead give away for Elm, my vote is Sweet Gum
White Oak Meadows
Offline Jarrett
« Reply #5 on: January 30, 2020, 05:58:08 PM »
I might have prematurely ruled out sweet gum...I have a lot of them nearby, but they have the gum balls still hanging on the tree.  This one had none, and it was probably 20 inches at chest height.  I will compare the bark and twigs tomorrow and see if I can definitively rule it out.
Offline Woodpecker52
« Reply #6 on: January 30, 2020, 06:44:10 PM »
Looks like elm to me.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: January 30, 2020, 07:55:52 PM »
It is ring porous.  Elm is ring porous.  Sweetgum is diffuse porous.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Southside
    • White Oak Meadows
« Reply #8 on: January 30, 2020, 08:08:21 PM »
Ok. Are the worms not always there?
White Oak Meadows
Offline wisconsitom
  • Deep in the larch
« Reply #9 on: January 31, 2020, 08:00:12 AM »
Look at the buds.  Elm.
Offline Jarrett
« Reply #10 on: January 31, 2020, 08:01:30 AM »
Does this not so great closeup pic of the end grain help anything?
Offline Southside
    • White Oak Meadows
« Reply #11 on: January 31, 2020, 08:29:08 AM »
The worms came back!  :D
White Oak Meadows
Offline WDH
« Reply #12 on: January 31, 2020, 08:32:51 AM »
Yes, confirms elm.
Offline Jarrett
« Reply #13 on: January 31, 2020, 09:09:32 AM »
Thanks. So the 層orms are the wavy lines in the closeup? Are we still thinking American Elm or is there a way to tell which elm it could be? Thanks so much!
Offline wisconsitom
  • Deep in the larch
« Reply #14 on: January 31, 2020, 09:20:48 AM »
The species most likely to be confused with American elm is the red, or "slippery" elm.  Both are native trees that can inhabit roughly the same forest types, both have dark reddish-brown rounded buds, but on the slippery, there will be tiny hairs covering most of the bud surface, whereas on American elm, hairs will only be seen at ends of bud scales.
But I don't really use these features to id this tree. The bark, wood, and yes, buds, all say elm, and I think it most likely an American elm.
Used to line streets all over northern half of North America.  Non-fussy tree, able to easily grow through a crack in a sidewalk somewhere, these elms formed canopies over American streets that are all but gone now.  People who never saw this cannot possibly understand how American cities used to look when the elms were still alive.
Offline WDH
« Reply #15 on: January 31, 2020, 10:32:24 AM »
Leaves of american elm are smooth.  Leaves of slippery elm are scabrous (like rubbing sandpaper on your cheek).  Bark is a bit different to, at least down here.  Slippery elm is more scaly.
Help identifying a tree
Started by Full Circle on Sawmills and Milling
Last post September 20, 2012, 03:29:42 AM
by SwampDonkey
need help in identifying this tree
Started by alsayyed on Tree, Plant and Wood I.D.
Last post January 03, 2015, 04:14:42 PM
by wdmn
Need Help Identifying Tree
Started by ewhite2316 on Tree, Plant and Wood I.D.
Last post June 25, 2018, 07:54:09 AM
by WDH
Help Identifying this Tree
Started by EOTE on Tree, Plant and Wood I.D.
Last post January 19, 2020, 04:48:55 PM
by EOTE
