Author Topic: Chinese Elm?  (Read 576 times)
Offline b1
Chinese Elm?
« on: April 25, 2021, 10:32:19 AM »
Hi, I've been trying to up my tree identification skills. I came across several of these in the woods near me (MD). Most of the other trees in the woods are Tulip Poplars.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Chinese Elm?
« Reply #1 on: April 25, 2021, 08:20:49 PM »
Slippery elm.  Ulmus rubra.  The surface of the leaf should be very scabrous (like rubbing on 80 grit sandpaper).
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline b1
Re: Chinese Elm?
« Reply #2 on: April 26, 2021, 02:51:19 PM »
Oh ok. What's throwing me is the bark? I can't find any examples of slippery elms that have bark even close to this, always that kind of vertical running ridge look? But every specimen I found in the area had this same rounded scale look. Is this typical?
Offline WDH
Re: Chinese Elm?
« Reply #3 on: April 27, 2021, 07:11:25 AM »
Yes, at least here in the South it can have the tongue-depressor-like-scales on the older trees.  Very distinctive.  Your leaves are also too big for Chinese elm.  Are the leaves sandpaper-scabrous?
Offline b1
Re: Chinese Elm?
« Reply #4 on: April 27, 2021, 08:56:05 AM »
Cool thanks! I need to head back over there and double check the texture of the leaves but If I remember correctly I think you may be right they were rough.
Offline kantuckid
Re: Chinese Elm?
« Reply #5 on: June 02, 2021, 10:44:23 AM »
American Chestnut? Leaf size and specifics not real easy from the picture, but that bark doesn't remind me of any elm I've seen. I grew up around lots of elms in KS-slippery elms-we called them pith elms, Dutch elms and Chinese elms mostly as yard trees in hot/dry areas.
Offline WDH
Re: Chinese Elm?
« Reply #6 on: June 02, 2021, 09:13:18 PM »
Chestnut does not have a doubly serrate leaf margin.  The elms do.  Chestnut does not have an inequilateral leaf base.  The The elms do.
Chinese Elm?
Started by Kevin_H. on Sawmills and Milling
Last post May 14, 2004, 12:54:08 AM
by LeeB
question
Chinese Elm?
Started by EOTE on Forest Education
Last post March 24, 2020, 05:20:17 PM
by btulloh
Chinese elm
Started by trapper on Firewood and Wood Heating
Last post February 02, 2021, 08:35:20 PM
by Downstream
Chinese yam
Started by postville on Ask The Forester
Last post November 26, 2020, 11:35:16 AM
by Clark
