Author Topic: Self-releasing snatch blocks, made in USA  (Read 2925 times)
Offline llsathens
    • Stewardship Suppliers
« on: October 09, 2020, 01:56:58 PM »
6-ton pulling capacity.
$225
Price is for 1 but picture shows 2 so you can see a side view.
(I HAVE READ, UNDERSTAND AND AGREE TO THE TERMS OF POSTING AN AD ON THE FORESTRY FORUM)...5% will go to the Forestry Forum.
Offline ljohnsaw
Re: Self-releasing snatch blocks, made in USA
« Reply #1 on: October 11, 2020, 12:30:27 AM »
Nice!  What is the pulley made out of?  Stainless?
John Sawicky
Offline llsathens
« Reply #2 on: October 14, 2020, 11:20:46 AM »
Zinc plated
Offline John Mc
« Reply #3 on: October 15, 2020, 10:12:45 PM »
Are these the same snatch blocks that member APM was selling 5 or 6 years ago? I have one. It works well and had great reviews from members here. (I did end up making one minor modification, suggested by another member.)
Offline llsathens
« Reply #4 on: November 28, 2020, 11:02:23 AM »
Yes, made by APM in Tennessee.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #5 on: November 28, 2020, 11:12:38 AM »
I usually see these used with steel lines.
Has anyone tried them with synthetic line?
Would a different design on the snatch block be needed for a 'soft line' to release?
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline Walnut Beast
« Reply #6 on: November 28, 2020, 11:57:43 AM »
How many k are they. Do they make a 8k and higher
« Reply #7 on: November 28, 2020, 12:00:09 PM »
I see the previous. Do they make anything bigger?
« Reply #8 on: November 28, 2020, 12:03:44 PM »
If everything is smooth and it looks like it is with that block. There should be no reason you couldn’t use synthetic with it
Offline John Mc
« Reply #9 on: November 28, 2020, 03:39:17 PM »
Does anyone know what bearings are used in the APM block? Mine got messed up when my 3/8" cable pulled down between the pulley and the frame. I'm not finding any identifying numbers on the old bearing.
Offline John Mc
« Reply #10 on: December 15, 2020, 12:06:52 PM »
I just wanted to let everyone know that within 12 hours of making my post asking about the bearing ID, I heard back from APM, the manufacturer. He had seen the post, and contacted me via a private message to make sure I had what I needed to get the block up and going again.
I really appreciate how he supports his product and his customers (even though this was most likely operator error). Also, thanks to llsathens for picking up handling the distribution and sale of these blocks. They are well made, and a bargain compared to other, similarly rated self-releasing snatch blocks out there.
For anyone else who is wondering, the replacement bearing is a 6207 2RS. (Thanks to both @apm  and @A-z farmer for sending me that info in private messages.)
Offline Lostinmn
  • I was me, but now he's gone.
« Reply #11 on: December 18, 2020, 01:27:02 PM »
How much is shipping to Rosemount, MN 55068?
Offline DeerMeadowFarm
« Reply #12 on: February 01, 2021, 02:38:35 PM »
I have one of these. Very handy!
Offline PoginyHill
  • Gentleman logger
« Reply #13 on: February 01, 2021, 03:13:42 PM »
I have the same one - Works very well. Recently, I welded a piece of 1/4" key-stock bent to the same radius as the pulley to the frame to prevent the same issue that @John Mc had with cable wedging between frame and pulley. Had that happen to me at least 2X. In my case it did not ruin the bearing. Able to remove pulley and re-install.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline lmo506
« Reply #14 on: March 03, 2021, 03:23:05 PM »
These are awesome. I bought two from you. Ill tell you how strong these are. Last winter i was coming down a hill with my 440b towing  a forestry trailer with way too much of a load. the trailer pushed the skidder and jackknifed . I hooked the snatchblock on a tree behind me and ran the mainline under the trailer ,to the snatchblock and back to the end of the trailer. I was expecting the worst to happen but instead the whole rigging system held and got me out of that mess....twice. These things are made to last.
I have never pretended to be anything I'm not, except sober, I've pretended to be sober a few times
Made in USA Self-Releasing Snatch Blocks
Started by llsathens on For Sale
Last post July 14, 2014, 10:43:37 AM
by Northland Ontario
self releasing snatch blocks
Started by apm on For Sale
Last post December 10, 2014, 10:54:28 PM
by by677
Self releasing snatch block
Started by Seaman on Sawmills and Milling
Last post September 27, 2017, 07:49:20 AM
by moosehunter
looking for self releasing snatch block
Started by lirachamo51 on Sawmills and Milling
Last post January 01, 2015, 08:07:09 AM
by crowhill
