Author Topic: Nyloc nuts on husky bar - yes or no  (Read 521 times)
Offline Windy2
« on: July 16, 2021, 12:13:22 AM »
Anyone tried nyloc nuts on a husky bar. Just trying to get some colored nuts so they don't get lost as easy when in the field. Most non silver nuts are only available in nyloc. Pros and cons? Thanks
Offline Tacotodd
  • To learn and help
Re: Nyloc nuts on husky bar - yes or no
« Reply #1 on: July 16, 2021, 12:26:08 AM »
Even the nylocís are only going to have a tiny bit that is going to be either white or black (typical commercial made). I donít see where the big advantage is going to be, plus itís going to be a hindrance when it comes to removing or even the typical chain tension adjustment. That said, what am I missing?
What about some sort of chemical stain applied to the regular nuts, but I canít think of anything that would give you some sort of higher visibility nut in the end.
Trying harder everyday.
Offline Windy2
« Reply #2 on: July 16, 2021, 12:30:07 AM »
Might just be admitting to being lazy -  a good dip in some flouro paint would do a good job.
Offline Tacotodd
  • To learn and help
« Reply #3 on: July 16, 2021, 12:33:05 AM »
Itís just going to mostly chip off when you put your scrench on it.
Offline Windy2
« Reply #4 on: July 16, 2021, 12:42:04 AM »
back to the old solution of always carrying a few spares :)
Offline Tacotodd
  • To learn and help
« Reply #5 on: July 16, 2021, 12:56:39 AM »
Thatís why I keep 7ish (last time I counted) in my chainsaw tool box (50cal can).
Offline thecfarm
« Reply #6 on: July 16, 2021, 04:57:43 AM »
Windy2, welcome to the forum.
Spares is the answer. I try to keep spare bar and at least 2 chains all the time too.
Offline lxskllr
  • dummy with saw
« Reply #7 on: July 16, 2021, 07:03:52 PM »
Maybe you could rig up some captive nuts. My little echo has a wire captured nut that's attached to the cover, as opposed to the more "professional" builtin nuts on my Stihls. If that applies to the bigger saws also, you might be able to get a couple echo nuts, and glue a mount for them on your clutch cover.
Offline JohnW
« Reply #8 on: July 17, 2021, 12:44:31 AM »
I thought my eyes were getting bad, but I can still find the bar nuts.  Two spare is plenty for me.
Offline Real1shepherd
« Reply #9 on: July 17, 2021, 12:08:04 PM »
I've only occasionally had this problem over the long yrs. But I have lost all the little cool Husky jet adjustment screwdrivers over the yrs;first a orange one and then many black ones. Black is a bad handle color for anything dropped on the ground! Just say NO to black handled tools used in the field.....lol.
Kevin
Nuts
Started by Ironmower on Tree, Plant and Wood I.D.
Last post September 03, 2009, 04:57:30 AM
by SwampDonkey
AM I NUTS new guy
Started by paka on General Board
Last post February 01, 2008, 11:28:45 PM
by WDH
Wet nuts
Started by Frickman on FOOD! FOOD! FOOD!
Last post March 10, 2008, 03:25:46 PM
by Roxie
Are we nuts ?Ņ
Started by jim king on General Board
Last post April 13, 2007, 10:35:42 AM
by DanG
