Push-on nut removal?
Started by Ga Mtn Man, December 02, 2012, 06:42:19 PM
Ga Mtn Man
The plastic knob on the handle of one of my Bulldog leveling jacks was broken by a falling oak slab that got away from me. >:(  I've ordered a replacement that comes with a new push-on nut but I can't figure out what the trick is to getting the old one off.  Anyone had experience with one of these things. ???
NWP
Usually when I've removed a push on nut it is mangled by the time I get done.  If you're getting a new one with the handle, at least you don't have to be real careful with the old one.
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
hamish
Just pry it off, with either a pair of pliers or use the existing handle and a hammer and knock it off.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
They are usally distroyed on removal,sometimes you can use an awl or small screwdriver to pry a couple of the pedals out and remove almost unharmed. Frank C.
