Need a mill to slab 46" Walnut
Started by UID Wood Works, December 10, 2017, 02:28:58 PM
UID Wood Works
We're a custom furniture business and have (7) walnuts coming down in 2 weeks, one of which is 46" at the base and it poses a problem because I have been unable to find someone to slab the tree.
- Being dropped late December
- 46" at the base
- (2) 10' sections
- Intended use is single slab dining tables, need live edge both sides
- Located in Albany, NY
Can anyone recommend a mill? Most mills and weekend worriers are limited around 40"
Custom Furniture
www.uidwoodworks.com
WV Sawmiller
   Go to the Extras section here on the FF and look for a local sawyer close to you. Call them and if they can't provide that service ask them if they know anyone who can. They may be able to refer you. I could if you were here. If nobody on the FF try the Woodmizer site and look at their Pro-Sawyer network and ask same question.
   Good luck. Let us know how it works out for you.
dgdrls
FF member Terrific Timber,   he is in Conn
Crusarius
Posts like this make me want to make my mill mutli width capable. I made the bed 50" wide by mistake. Maybe this was not a mistake.
How soon are you looking to mill those? I have 0 experience milling so not sure I would want to jump into that kind of a job right away.
Blackhawk1
If you contact one of the site sponsors they can direct you to a person who has been sold a mill big enough to do your project. I have what you need I am just too far away
Doug Caroselli
512-738-1770
Brad_bb
First of all, where are you?  Go to your profile and add your location and then it will show up in each post you make.
Wherever you are, I recommend calling any local sawyers and ask them who they know can slab that big.  They are most likely to know who has that capability locally.
terrifictimbersllc
UID Wood Works
Thanks for all the info guys, really nice to see some of your more senior members chime in for a newer guy
After some digging I ran across http://www.berkshireproducts.com/ and had a good convo with a gentleman by the name of Matt. They're shutting down soon depending on the snow but I may be able to squeak the milling in before they close. Does anyone have a review about Berkshire Products in Sheffield MA?
Tree is still standing, tree service company should have it ready for transport by the end of next week.
Custom Furniture
terrifictimbersllc
No review except I've talked to them too. They have a Woodmizer 1000, it was $400/hr including two of their employees, and there was no dropping off of logs-they want your trucker to wait while they mill what you bring them.  Also I think they have a vacuum kiln available there.
Dave Shepard
UID Wood Works
So the tree is down! Beautiful on the inside, 48" x 9' section and another 44" x 11' section that will have a few leader knots in it
The next question is if we should slab this big guy when its frozen and/or half frozen? Temps in upstate NY have been in the low teens at night and mid 20s during the day, some warm rainy days recently. We would be using a portable lucas swing blade mill.
I did some searching around and it seems like mixed reviews, a lot depends on the blade and type of wood. Any input is appreciated.
Custom Furniture
redbeard
Call Hud-Son  forestry products in Barnville  NY see who has a Hud-Son 60 close by or maybe they can do it. It will slice it like butter no problem.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
farmfromkansas
 See in the latest sale catalog that Cooks have a wide cut mill now as well.  Call them, they will give you names of mill owners nearby.  That is the way I found a guy to sharpen my bands with a cat claw sharpener.
scsmith42
I find it interesting that everybody is talking about the capability of the mill, but not the quality of the miller....
To me, I would think that you'd want to find that person that knows how to set up and mill an oversize log in order to yield the most valuable slabs....
Tom's 3638D Baker band mill
Brad_S.
 I would think you would have to find a mill big enough to handle the log before worrying about finding a Sawyer. Presumably, if someone has a mill capable, they themselves are capable as well. Doesn't do any good to find a Sawyer if you can't find a mill.
