Can anyone recommend a book on building with green lumber?
Started by Modat22, April 28, 2006, 10:13:02 AM
Modat22
I'm looking for books on how to cope/plan for the problems with building with fresh cut green lumber (not timber frame). I did order one out of print book titled "The greenwood house" by Larry Michael Hackenberg.
Basically I want to stick build a 30 x 40 or 60 pole barn with board and batten siding and use it as a wood shop. Insulating and adding rooms inside as demand rises. I've outgrown my little 12 x 16 building and working in there has become an exercise in aggravation.
Any recommendations on reading books greatly appreciated.
Sam
remember man that thy are dust.
scsmith42
Steve Chappell, Jack Sobon and Ted Benson have written several books on timber frameing - all are good reads.
Steve Chappell's "A Timber Framers Workshop" is an excellent working book with detailed information.  You  may be able to find a deal on a used copy on Amazon.
Good luck.
Scott
Tom's 3638D Baker band mill
Modat22
Thank you sir. I don't think I'll be doing a timber frame though. I'd like to just use fresh cut 2x6's etc. I don't know how to plan for the shrinkage and warpage though not to mention that I don't have alot of experience in building buildings.
Modat22
I have an over abundance of red oak, poplar and 10inch dia cedar on my property.
I've heard red oak is brittle though (seems like my red oak sustain more damage from storms than other trees)
scsmith42
Modat, most of the timber frame books contain good information on planning for shrinkage, etc.  They also typically contain charts that list the percentages of shrinkage that you can expect across different axis, ect.
All in all, a wealth of information can be found in them in addition to timber framing techniques.
Good luck!
Scott
Modat22
I thought about that as well, the books would be a good investment Would give me some great dreaming material since I love timber framed buildings anyhow.
scsmith42
Chappell's book has about 15 pages devoted to working with green timbers and boards, planning for shrinkage, etc.
If you'll pm me with a fax number, I'll copy the pages later today and fax them to you.
Scott
Modat22
Don P
With any of those woods, if you're cutting and stickering 2x now, by late summer it'll be as dry as the framing stock at the building supply.
Jim_Rogers
Try and drive a nail through a 2x6 piece of red oak and you'll soon learn why softwoods are used for framing stock.....
I understand that you want to use your available types but you should choose which pieces are made out of which type depending on what they are.
Red oak boards will make strong roof decking, and could even make nice siding, door and window trim also.
Plan ahead.
Jim Rogers
Max sawdust
Mod,
Consider what Jim says.  Red oak or dry Popple/Aspen is hard as a rock.  Could get frustrating with a big stick frame project.
(Not saying I would not try it, cause I refuse to buy "store bought" stuff) ::) ::) ;)
Hence the reason I am teaching my self timber framing.  (Very steep learning curve ;D)
Either way just cutting and stickering for the summer as Don P mentions would get much of the wild movement out of the wood in my opinion.
Max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Buzz-sawyer
Hi there
I have built many a platform framed type building as well as trusses and such using mixed hardwood lumber....
you want to use it green, because it is much easier to work with ...the only real downside I have had , is when using sycamore and cottonwood, and sweet gum, twisting can be annoying some times....stay away from knotty logs and that will help a bunch....one word for you .....AIR NAILER...must have for what you are planning....it makes ALL the difference...I have even nailed seanoned hedge with it ;) ;)
    HEAR THAT BLADE SING!
Modat22
Hey guys thanks for the help, I'm researching using all the lumber green I've experianced the dried oak / nail phenoma before and don't want to experiance it again. Aye I believe in nail guns thought I tend to go a little crazy with it.
Thanks again
crtreedude
Most homes here are done with green wood - well, almost green. It is airdried for a few weeks (3 or 4) and then nailed up.
Since the climate is pretty much the same all year round, it works.
Since wood doesn't shrink much length ways, that they do is nail up the rafters, put the roof on it and let it dry a bit more. Then put up the interior stuff.
Works pretty well.
But understand, we don't really care if anything is air-tight.
So, how did I end up here anyway?
exssnelt
Here is a link to a Mother Earth article: Link
I have read the book "The Green Wood House" Listed in the article. It is very informative.
If something is worth doing, its worth doing it right!
submarinesailor
Exssnelt,
Followed your link and read the article.  Liked it, so I emailed Larry Michael for a PDF copy.  Had it in my computer in about 35 minutes – not too bad of a response I would say.  Now I just need to find the time to read it.
Bruce/subsailor
Modat22
Hey exssnelt
I bought that book listed in that web link. Its a great book and well worth picking up.
ThatGuyDuncan
Quote from: Modat22 on April 28, 2006, 10:13:02 AM... I want to stick build a 30 x 40 or 60 pole barn with board and batten siding and use it as a wood shop. Insulating and adding rooms inside as demand rises.
I think you've had about ten years to complete the project -- what direction did you take, and how did it all turn out??? I'm looking at a very similar project and share your interest in working with green wood. Thanks!
PC-Urban-Sawyer
You may be waiting for a while for an answers from Modat22. He hasn't been logged on in about a year...
Herb
fishfighter
Quote from: ThatGuyDuncan on March 26, 2017, 03:27:35 PM
Look at my thread building. That has been done with all green lumber. Oak and pine. Very little problems once things started to dry.
redbox13
Hi, I am in a similar situation that Modat was in, all those years ago.  I am looking for "The Green Wood House" and have seen it on Amazon for $750+.  I think that may be too high a price for me.  Any suggestions?
kantuckid
I used to have the book: "The Green Wood House" but can't say I really learned anything from it? General idea is "throw it up off the mill" and it dries in place. Knowing how to 'throw it up" is the crucial aspect :D
Prizl tha Chizl
We built our home with green wood fresh off the mill, and my advice is to use dry lumber for all stick built aspects. Timbers don't twist too much as they dry, but 2x stock moves all over the place as it dries, very annoying as you go back to adjust every door and window opening framed, and attempt to flatten walls, (unless you are plastering and don't need them flat.) i suspect 3-6 months stacked and stickered would let a lot of the movement out. Sawing  as much as possible on the radial plane might help also. Maybe not so much of an issue in a pole shed, though.
"The Woods Is My Church"
Prizl
What species of wood did you make into 2x green?
Prizl tha Chizl
White pine mostly, some red oak.
This can happen with the "kiln dried" stuff from the lumberyard as well, and almost all new construction involves lots of varying moisture/drying inputs that can make wood wiggle around. In the standard stick framing industry they've got speed working in their favor- the studs don't have a chance to move much before they're held in place by OSB and drywall. I've found this is hard to pull off for a do it yourselfer. I guess the main thing to remember is to double check all your openings before you start hanging doors and Windows, and buy a portable planer.
kantuckid
Having deconstructed many old homes and barns for the chestnut in them: I've seen every known species in use in all the parts.
But locally, here (E KY) and now, green rough sawed is used a lot for self-build or contractor built homes and EWP, SYP, "other" pine, hemlock and yellow poplar are easily the first choices for cost and nail ability for stick frames.
