Author Topic: cabin out of pine logs  (Read 1817 times)
Offline E fan
  • somewhere between here and there
« on: February 22, 2015, 01:10:52 PM »
I cut down 37 pine trees back in may - july of last year ( 2014 ). Their 12-18 inches in diameter and have been laying since they were cut. Now mind you I know their NOT the lumber one would reallt use but I just want to build one that grandson and I can play in and sit and watch wildlife from and maybe use as a ground blind. And I can learn a few log building technics in the process.
Is it worth the effort or just stack'em and burn'em?
Oh forgot their from 10 to 18 feet long , most being the longer
Offline LeeB
Re: cabin out of pine logs
« Reply #1 on: February 22, 2015, 01:32:20 PM »
I imagine the bugs have had a good feast, but I wouldn't just burn them. Make a couple of cuts and see how sound they still are.
Offline drobertson
« Reply #2 on: February 22, 2015, 01:41:12 PM »
I certainly would give them a chance,  a few years ago I sawed out some, some of which were older with slipping bark, which was a good thing. They wanted 6x7's D-logs, three sided.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #3 on: February 27, 2015, 08:22:52 PM »
There is a lot of beetle kill lodgepole not too far from my place in California.  We just let it stand there 'till the bark falls off, then we cut'em down and take them home.  The wood is well cured and still quite solid great for log cabins.  I guess that's why they call them lodgepole pine.
1992 LT40HD
pine logs (radiata pine, German sylvestris pine, & Pinus maritime)
Started by mikewong808 on Forestry and Logging
Last post August 06, 2009, 07:21:25 PM
by MDLogging
Help with red pine log cabin
Started by chasenabby on Drying and Processing
Last post April 16, 2012, 10:30:35 PM
by samandothers
Red Pine/Log Cabin
Started by Draco on Drying and Processing
Last post March 24, 2010, 03:24:41 PM
by jander3
Pine log cabin
Started by pineywoods on Timber Framing/Log construction
Last post February 22, 2009, 10:51:57 PM
by jerry-m
