Just another day in Paradise
Started by PAmizerman, July 18, 2018, 11:51:57 PM
PAmizerman
Quote from: moodnacreek on March 30, 2024, 08:01:05 AM
Quote from: PAmizerman on August 07, 2018, 09:45:04 PMYep plenty of room. But 4x4 told me it will fill up fast :D
You must put a circle mill there. That is what 4x4 and others who got serious did. you can come up and try mine and be convinced.
If I needed to produce more volume I would consider it.
I like how I can pattern down through a can't and make a stack of boards and remove the entire pile without touching it with my bandmill
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
melezefarmer
Quote from: PAmizerman on March 29, 2024, 08:34:17 PMBusiness has been really slow the last couple of months. Tons of backyard sawmills have popped up around me. They are basically sawing just to have beer money.
Things are picking back up again here in Canadaland. However, hemlock logs prices are making me question if I should just switch to milling white pine. I wouldn't have to deal with shake and it certainly cuts faster than hemlock.
