Sliding Barn Door Header - with exterior insulation
Started by John P., September 15, 2016, 09:18:09 AM
John P.
I have a somewhat unconventional construction going on right now. I've posted on it before. One thing I did not figure out ahead of time (my bad) was how to handle the sliding door header. I figured it would be easy to figure out once I got to it, but honestly, I don't know what to do now.
The description below describes my situation, but basically if anyone knows of any resources that I can use, I'd appreciate it.
Up to this point everything I've done has either relied on prescriptive tables or engineering reports, but this header is uncharted territory.
This is a simplified view from the inside:
And a view from outside:
The ugly repeating pattern is 1/2" OSB, pink is 2" of foam. An air/water/vapor barrier goes on top of the OSB:
I want to put 1 or 2" of foam between the header board and the structure, so that the thermal envelope is unbroken there. Additionally, I don't want a through-bolt - I would like to use structural screws or lags so no fasteners show on the inside. This view shows a side view:
Any ideas? Also, I would like to lower the door 12", but then the beam would only have a few attachment points.
Brian_Weekley
The easiest would be to just build tall doors so the track could be mounted at the same location of the existing beam on the inside.  On my barn, I framed around the doors and windows with 2 inch thick nailers to match the thickness of the foam.  Just cut the foam to fit and add your choice of siding.
I used swing-out doors on mine.  However, if I had installed sliding doors, I would definitely add a sloped rain cover over the door track something like this:
e aho laula
DDW_OR
