Bar Recommendations Stihl MS461
Started by kyjondeere, October 12, 2024, 06:57:20 PM
kyjondeere
I have a MS461 that requires a new bar. It currently has the stock bar, 3003 000 9431 (3/8, .063, 25"). I was wondering if there's a current better alternative (light weight, aftermarket), or just go back with the original?  Thoughts?
Norwood Lumbermate 2000, John Deere 5083e, John Deere 5075e, Kubota L3240, Stihl MS 461, Stihl MS261CM, Load Trail 16' Dump Trailer
lxskllr
IMO, Stihl makes the best oem bars in the business. You might want to consider the same bar, but ES Light. It'll shave some weight at the cost of durability. Normal cutting, it should last as as long as an ES bar, but it won't tolerate getting tweaked around as much; eg twisted when a tree doesn't behave as you think it should.
Otherwise, you might want to consider going to a smaller gauge. .050 is pretty much standard here, and it makes getting chains a bit easier. I could run to walmart of homedepot to get something that would fit in an emergency. I'd have to go to a Stihl dealer to find a .063 chain, but it may differ in your location.
doc henderson
I have the 046 mag and run the 3/8th pitch 25-inch bar as well.  works well, why change.
