General Forestry => Forestry and Logging => Topic started by: Evandine on April 27, 2022, 10:12:02 AM
Hi all, I have a 2004 1710D timberjack forwarder, I've lost all power to the boom and steering. I've changed the crane module, the hub module and the harness between the two. Still nothing any ideas?
Where do you have power to?
When you say you lost power, is it an actual power loss or is it just not working? You need to be careful switching modules as they are not all the same, different programing. The steering and the boom is run off the one valve on those machines, so you may have a hydraulic issue. Could be as simple as a seat switch. Does it have a blade and does that still work?
