This wood is HARD !
Started by DR Buck, January 18, 2019, 10:34:25 AM
barbender
Quote from: Southside on July 28, 2019, 12:56:09 PM
Santeria and sacrificial chickens have their place too..  :D
K-Guy
@Southside
@YellowHammer
You two seem to have a real chicken fetish. ;D :D
Nyle Service Dept.
- D. Adams
YellowHammer
Actually, I have a real soft spot in my heart for Guinea Hens, even though I believe they are the stupidest animals ever created.  I swear I had one laying eggs on my roof, because I'd find cracked eggs in the gutter downspouts.  I like chickens, though.  Fried, baked, and roasted.
Definately, the best time to finish plane a board is after it's done moving.  There was some information I've read in the past that planing green would slightly reduce the amount of potential surface checking, but after trying it once, and only once, never again.
Planing green wood was a disaster the one time I tried.  The chips wouldn't clear and go into the dust collector.  The wet chips would would jam under the feed rollers and cause stalling.  The boards would jam and have to be pulled by hand.  The worse thing was when I came back the next day and my planer was a huge pile of rust, as if I had sprayed everything with a water hose, which is basically what I did when the dripping wet chips went all through the planer.  For me, it was a royal mistake.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Old Greenhorn
Quote from: YellowHammer on July 29, 2019, 05:48:35 PM
YH, given your hands on experience, what would you say is the highest MC you would consider planing?
YellowHammer
13%-15% or roughly air dried would be the max I would bother with.  I've hit wet spots of 20% in some wood and it's too wet for the planer, it rips and tears.  As a matter of fact, that's a good way to tell if you are getting wet spots, especially in walnut.
Air dried will move when brought down to kiln dried.
YellowHammerisms:
Old Greenhorn
Yeah, 15% is the number I had in my head too, but given your experience I wanted to hear if I was too high. I don't have a planer and don't want to mess up anybody else's that I might put wood thorough. I have some slabs I will be planing in a week or two but they are at or below 12% last I checked.
Southside
Quote from: YellowHammer on July 29, 2019, 10:36:59 PMAir dried will move when brought down to kiln dried.
Oh yes it will!!  Learned that lesson the hard way trying to run some reclaimed oak flooring cut from beams for a customer.  He sawed them, ran them through a SLR, then sent them to me to dry and run through the moulder.  Talk about a MISERABLE experience....
White Oak Meadows
