Author Topic: solar power  (Read 365 times)
Offline sawwood
solar power
« on: May 27, 2021, 10:02:02 PM »
I have a solar kiln and need to run the fans on  solar power and may be a dehumifer to help the drying time. How big of a system would i need
to power  two fans and the dehumifer ? I sort of understand the system but need to know how big of a inverter i would need. Thanks for any help.
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline bannerd
  • Madman
Re: solar power
« Reply #1 on: June 04, 2021, 12:46:22 PM »
What type of battery bank will you have?  Might be worth looking into window vents.
Offline sawwood
Re: solar power
« Reply #2 on: June 04, 2021, 09:52:47 PM »
From what i have read i will just need one battery. The YouTube guy had just a solar panel one
battery. A controller for the solar panel and a inverter. Didn't show how many out lets it had. I
am going to look more into to it. Looks like it may be coast about 800 to 1000 to set it up.
18" planer/molder
Offline Brian_Rhoad
Re: solar power
« Reply #3 on: June 05, 2021, 12:12:54 AM »
You don't need a battery to run the fans. If you connect the correct size solar panel directly to the fan, the fan will run during the day and shut off at night.
Offline Ianab
Re: solar power
« Reply #4 on: June 05, 2021, 01:43:52 AM »
This.
In the standard solar kiln plan you only operate the fans when the kiln is hot (the sun is shining). At night the kiln cools off, the humidity in there goes up and you get a daily "reconditioning" cycle. The wood "rests" and the moisture gradient inside to boards evens out. Ready for another burst of hot air the next day. Although this is slower, it's safer than simply drying as fast as you can. Other kilns can dry faster, but they need more precise control (humidity / temp / airflow) to ensure good results.
If you need more throughput, then build another simple kiln and/or partly air dry the wood first. It might take 4 weeks to dry a load from green, but only 1 week of kiln time if the wood has air dried for a couple of months first. End result is 4X the amount of dry wood coming out of the kiln.
Solar Power
Started by Tom Sawyer on General Board
Last post June 30, 2005, 07:00:29 PM
by Robert_in_W._Mi.
Future of Solar Power
Started by Gary_C on Alternative methods and solutions
Last post July 26, 2016, 02:56:43 AM
by Ianab
Solar Power in the Islands
Started by Ianab on Alternative methods and solutions
Last post October 14, 2015, 07:16:04 AM
by Ianab
Solar power generator
Started by woodweasel on Alternative methods and solutions
Last post March 17, 2014, 10:15:13 AM
by Thehardway
