Author Topic: Large Beams  (Read 640 times)
Offline boonesyard
  • I've got a little sawdust in my pocket
Large Beams
« on: May 28, 2021, 10:12:59 AM »
 A local historical society is working on a large scale project and contacted us about cutting some large beams, 6"x12"x10' out of white pine. They requested them kiln dried, I told them kiln drying green pine that big and fast isn't realistic and would have a lot of degrade in them. I said I could sterilize, set the pitch and then they could install. My question, how long would it take to sterilize and set the pitch on large beams like that? Also, should I ramp it up to 160 right away, or slowly work my way up? I was thinking if I just set it at 160 right away, 6 days should get it done? Any advice would be greatly appreciated.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Online Don P
    • Calculator Index
Re: Large Beams
« Reply #1 on: May 28, 2021, 09:22:46 PM »
Can you set pitch in a green timber?
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Southside
    • White Oak Meadows
Re: Large Beams
« Reply #2 on: May 29, 2021, 06:32:19 AM »
@scsmith42 has dried large beams, perhaps he can offer some advice.
White Oak Meadows
Offline boonesyard
Re: Large Beams
« Reply #3 on: May 29, 2021, 07:22:40 AM »
Well that was silly of me, timber would have to be dry to set the pitch. Then I guess the question is, how dry before the pitch can be set? And what's the best way to go about that?
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline scsmith42
    • Whispering Pines Farm
Re: Large Beams
« Reply #4 on: May 29, 2021, 07:11:01 PM »
We dried several thousand bd ft of 7 x 14 x34 SYP beams from green in an L200. It was a three month kiln run, but they dried down to 16% and passed grading by SPIB.
They had a couple of weeks of air drying first so as to minimize mold development during the first part of the kiln run.
Tom's 3638D Baker band mill
Offline boonesyard
Re: Large Beams
« Reply #5 on: May 30, 2021, 08:20:27 AM »
How did you handle your kiln run?
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline scsmith42
Re: Large Beams
« Reply #6 on: May 31, 2021, 01:01:14 PM »
I'm not sure what you're asking....
Offline boonesyard
Re: Large Beams
« Reply #7 on: June 01, 2021, 08:41:15 AM »
What kind of temp for how long? when and how much do you turn it up and for how long? I know you said it was about a 3 month kiln charge, was a low temp run for 3 months?
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline scsmith42
Re: Large Beams
« Reply #8 on: June 03, 2021, 08:54:46 AM »
I started the kiln run at 90F and 95% RH. Kept it there for around 2 weeks, then dropped to 90% RH for four weeks.  After that I started following Nyle's schedule for Group 4 hardwoods based upon MC% readings taken 2/3 of the way from the core to the shell with a slide hammer.
The beams were treated with Premier fungicide to retard mold development.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Large Beams
« Reply #9 on: June 03, 2021, 09:38:09 AM »
I dry beams all the time, pine 4x4 up to 8x8 10x10,
The 4x4 took 4 weeks and came out at 7%
The 8x8 and larger never really dried, (4 week) The pine will show 10% on the surface 2" in with the probe. but when you cut them open they still 30%+ in the core.
 hardwood and pine mantles ( fireplace mantles) I mainly do it for sterilization. My customers like it, it also starts the drying process in that checking develops, especially in the pine. I just dried some 4" cherry FP mantles and they came out looking great. Still 20% with a full probe. I'll leave them in the shop to sell this fall/winter.
I only run them  1 cycle (2 weeks) at full power and most of my customers are happy with it.
They like that I sterilze them. NO BUGS
Offline boonesyard
Re: Large Beams
« Reply #10 on: June 03, 2021, 11:20:13 AM »
Thanks guys, I've been doing some large hardwood beams for mantles as well. Everything I've done had air dried for a good time, although a 6x9 mantle doesn't dry much in the core. We just finished a large black walnut mantle that turned out well, was in the kiln for 3 weeks but was still 25% when it was finished, owner was happy. Almost all of the big heavy stuff ends up with cracks/checks. I've tried low power for a couple weeks (125-130 deg) and then run it at 155-160 deg for a week and still get checking. I've decided that's just the nature of the beast when dealing with the heavy stuff, 4"+. The good thing is the customers I have looking for the heavy stuff are also looking for weathered, natural, and high contrast, so it works. Every day is like a big giant science project, love this stuff.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Large oak beams
Started by Horselog on Timber Framing/Log construction
Last post October 13, 2010, 10:57:27 PM
by Mad Professor
resawing large fir beams
Started by richard lane on Sawmills and Milling
Last post October 12, 2010, 08:08:52 AM
by Magicman
Newbie need to saw large poplar beams 4x12's
Started by Doug_D on Sawmills and Milling
Last post August 10, 2010, 09:43:48 PM
by Todd Tittle
Processing (planing & jointing) large beams
Started by Biocmp on Timber Framing/Log construction
Last post August 01, 2012, 04:25:07 PM
by frwinks
