Author Topic: Can a 18" sq SYP post be kiln dried for a short period of time to help set sap ?  (Read 1135 times)
Offline florida
I've built dozens of piling houses with 8 X 8 and 12 X 12 treated pine posts. I've never noted any serious bleeding from any of them and never had a customer complaint about it either. I think it's a non-issue.
General contractor and carpenter for 50 years.
Retired now!
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
You're my friend....... ;D
@doc henderson I really don't have anything to recut something this big and 18" sq take a pretty big log to begin with
@K-Guy don't the more beat up and twisted the better to a point, but don't want to ruin the integrity of the post either. i'll just leave it like Don and florida mentioned
Necessity is the engine of drive
Offline doc henderson
I did say "if possible".  and I agree you can just go with it.  If you do not plan to mill your own, then not sure you can find that "theoretical 18 x 18 anyway.  good luck!  :)
Offline Southside
    • White Oak Meadows
Ok - but treated posts are dried down to below 26% MC before being placed into a vacuum chamber, being drawn down more, then having treatment applied under pressure into the now dry wood fiber.  Not really the same comparison.
White Oak Meadows
Offline Sedgehammer
Yup, you did
Already found it..... ;D
Offline Don P
    • Calculator Index
Basically with any drying, if surface tension perpendicular to grain, caused by shrinkage of the shell over the swollen green core, exceeds tensile strength of the wood perp to grain (which is the weak direction in wood) checking begins. In a radical drying scenario like this one surface checking begins all over the timber. There would be many "tears" in the fabric of the wood. They wouldn't necessarily be all that apparent immediately, the core moisture would rise, swell the shell and close them but the tear has occurred. Later as the timber continues to dry those tears continue to enlarge and severe checking shows itself. Remilling won't cure that. Too aggressive a drying schedule or mishandling wood early on bites you later.
I sawed some white oak one time in early June. Clear, dry conditions, a highly refractory (check prone, low tension perp strength) species. I stickered onto my trailer then drove uncovered about 10 miles to deliver the wood. When I arrived it was all checked. I acknowledged my mistake to the farmer and luckily he was fine with it saying it was just fence boards. By the time we had unloaded, the moisture rose from the wet core to the dry surface. The checks closed and the wood appeared fine. No, the tears were there and just like the initial tear in fabric, hard to start but once begun it runs easily. I had ruined that lumber by mishandling it at high moisture.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline cabindoc
  • I'm new ish
    • cabin doctor site
that said, you can make them oversized, and saw down to size after.  if possible.
Definitely!  even an inch bigger.
Scott  aka cabindoc  aka logologist at large
Woodmiser LT35 hyd
Kabota MX5400
Offline K-Guy
    • http://www.nyle.com/
That character you are talking about often weakens the wood.
Nyle Service Dept.
- D. Adams
Offline Sedgehammer
Yes it does. I like some of that, but not too much due to what you mentioned
so what did you find in an 18 inch square size?  any pics of these beams.
Offline Sedgehammer
SYP. Picking up in a couple of weeks or so
Offline cabindoc
  • I'm new ish
    • cabin doctor site
Since it has not been brought up, ask the seller of your big beams when the tree was felled.  If cut down in winter months, sap will be down and will be minimal.  If cut down summer months, sap will be plentiful and you will likely get sap all over yourself just handling the beam.   We expect pics when u pick it up.....just sayin.....
Woodmiser LT35 hyd
Kabota MX5400
Finally bought "my" mill, after a 3 year trial period!
Started by Piston on Sawmills and Milling
Last post March 29, 2013, 08:28:10 PM
by WDH
Login time period Default
Started by fencerowphil (Phil L.) on Technical Support Topics
Last post June 20, 2008, 03:48:38 PM
by Jeff
Kiln dried lumber vs air dried
Started by Wisconsintimber on Drying and Processing
Last post December 01, 2014, 12:34:56 PM
by Jemclimber
Kiln dried, air dried, MCs and EMCs
Started by GeneWengert-WoodDoc on Drying and Processing
Last post February 20, 2013, 07:22:22 AM
