Author Topic: Drying Pine 2"×4"s in my KD150  (Read 189 times)
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« on: July 06, 2021, 08:56:47 AM »
I'm going to be drying some pine 2 x4"s in my KD150. I am noticing some mold on them setting around in my shop prior to drying in the kiln.Can I spray them with Bora care prior to going in the kiln? It's kind of pricey so I didn't want to waste it. I had the KD in a not so good chamber and I'm starting all over again trying to get things right from the ground up because my previous results were terrible.
Offline K-Guy
    • http://www.nyle.com/
Re: Drying Pine 2"×4"s in my KD150
« Reply #1 on: July 06, 2021, 09:14:37 AM »
If you can't put it in the kiln get fans blowing through the stickered pile to get the surface moisture of it. That will prevent mold and blue stain.
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: July 06, 2021, 09:28:56 AM »
As long as you don’t overload the kiln and you set the dry bulb and the wet bulb so that the compressor runs 100% of the time, the mold will be killed by the drying and you do not need to spray the lumber. In my L53 (which I believe is the same as the WM KD150), from green or air dried pine, I set the dry bulb at 120° and the wet bulb at 75° with a load of 400 bf and let her rip.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
"Vacuumterm" drying of a bar a pine, a fur-tree
Started by nick on Drying and Processing
Last post March 08, 2007, 11:12:36 AM
by serg
Drying "Cookies" or "Rounds"
Started by Greg Cook on Drying and Processing
Last post September 21, 2008, 09:51:57 PM
by woodbowl
Microwave drying small Maple. 8" X 8" X 12"
Started by Jim Spencer on Drying and Processing
Last post February 28, 2007, 05:15:38 PM
by low_48
Re: Drying 2" pine in a nyle L 200
Started by Don_Lewis on Drying and Processing
Last post August 30, 2004, 04:22:19 PM
by Don_Lewis
