SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Certificate errors  (Read 1566 times)
Offline slider32
Certificate errors
« on: January 20, 2022, 05:15:28 PM »
Seeing a security warning in firefox that the SSL cert is issued to forestryforum.com not www.forestryforum.com  Likely a common name missing from the certificate, or a redirection issue from www.forestryforum.com to forestryforum.com.
Offline Jeff
  • Fearless Leader
  • Hi Ren
    • Behind the  Forestry Forum YouTube channel
Re: Certificate errors
« Reply #1 on: January 20, 2022, 05:41:24 PM »
This probably means a bookmark entrance that is over 2 years old.
Offline Southside
    • White Oak Meadows
« Reply #2 on: January 20, 2022, 07:14:02 PM »
I do not understand the words coming out of your mouth.  :D
White Oak Meadows
Offline Jeff
  • Fearless Leader
  • Hi Ren
« Reply #3 on: January 20, 2022, 07:23:04 PM »
Well, that's simple! It's because you were watching me type. :D
Offline Jeff
  • Fearless Leader
  • Hi Ren
« Reply #4 on: January 22, 2022, 09:45:34 AM »
@slider32 , can you verify if this issue as it appeared on your end is now cleared.
Thanks, Jeff
SPACE AVAILABLE
