SPACE AVAILABLE
The pvg32 is a load sense control valve. The load sense happens in the valve itself not the valve sending a signal to a variable displacement pump. I found the technical info on that valve on line. The pilot pressure or standby as danfoss calls would be measured at the M port on the inlet section. This should be 450 psi when in neutral. This is the same port you would measure main relief pressure. There are also load checks for each sections. Will another function work properly while you have the boom traveling. Like jib and main up at the same time?
Kiko is right on about the valve being a load sensing one and those pumps are gear pumps. You said there is no issue with the steering or blade functions and I think it's because they are manually operated valves. The older 230A had only one hydraulic pump bolted to the side of the Cummins 4Bt, the later and 610 models also had another pump driven from the crankshaft in the front of the engine, still gear pumps. You said manually operated it works fine, so the issue may not be hydraulic but electric. If it has Danfoss joysticks then you will have IPS boxes and those can certainly give you the jerky functions. By all means check your pressures, but if you still can't see anything wrong you best check your electrics.
Started by Horselog on Forestry and Logging
Started by ehp on Forestry and Logging
Started by Nemologger on Forestry and Logging
