SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: TJ 230-gsg hub seal  (Read 653 times)
Offline enen
TJ 230-gsg hub seal
« on: August 29, 2023, 10:36:17 AM »
Ive checked this forum and googled online but no luck. The hub seal ive read about here seal against a machined flat on the stub axle. This area is often worn. Mine doesnt seal against the stub axle. It seals against a metal cone pressed on the axle.  Anyone familar with this?
Thank you
Offline enen
Re: TJ 230-gsg hub seal
« Reply #1 on: August 29, 2023, 03:31:55 PM »
I cleaned up the seal and found CAT 435002 cast into the metal ring of the seal. Could this be original?
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #2 on: August 29, 2023, 04:07:28 PM »
Does THIS look like yours?
Offline enen
« Reply #3 on: August 30, 2023, 05:11:41 AM »
No, seems I have a CAT Duo seal. Not sure if this is OEM
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #4 on: August 30, 2023, 05:44:46 AM »
That is original for a Eaton WR series rear end, a duo cone seal. Looks like it backwards in the pic.
Offline enen
« Reply #5 on: August 30, 2023, 06:24:25 AM »
Ive looked all over the axle but cant see any part or serial number. Logo on the planetary cover plate is Rockwell, so i assumed the axle is rockwell. This is the front axle on the TJ
Offline enen
« Reply #6 on: August 31, 2023, 07:10:28 AM »
Well, I've figured out about these axles if anyone is interested.
They are Rockwell PR75 axles. They came OEM with Duo Cone Seals. Probably sourced from Cat.  These parts are still available through aftermarket suppliers
Share via delicious Share via digg Share via facebook Share via linkedin Share via pinterest Share via reddit Share via stumble Share via tumblr Share via twitter Share via whatsapp
SPACE AVAILABLE
