Author Topic: Grizzly Planer: G0544 20" Pro Spiral Cutterhead Planer  (Read 17951 times)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« on: December 29, 2008, 09:49:48 AM »
http://www.grizzly.com/products/20-Pro-Spiral-Cutterhead-Planer/G0544
Anybody here seen/used/owned one of these things?  I'm pretty close to pulling the trigger, but i'm concerned that i'm going overkill, and wonder if a G1033X would be sufficient.
lots of dull bands and chains
Offline Norm
Re: Grizzly Planer: G0544 20" Pro Spiral Cutterhead Planer
« Reply #1 on: December 29, 2008, 10:41:02 AM »
Dan I've got the G1033X and went through the same thoughts as you are when I bought mine. I will say I'm very happy with the model I bought. Since I didn't get the bigger one can't say much about it other than for the money and my usage I fell like I made the right decision.
Offline Dan_Shade
« Reply #2 on: December 29, 2008, 10:49:26 AM »
Thanks, Norm.
You have the spiral cutter head model?  I've done some research on that, and there seems to be some debate as to if they are worth the trouble.  Any thoughts on  yours?
Also, how hard can you push the planer, what's the most you've fed through it at once, and did you wish you had a larger machine afterwards?
Offline ADAMINMO
  • Today is gonna be another one of those days!!
« Reply #3 on: December 29, 2008, 12:35:25 PM »
Looks like the old style Baker planer . Just in green and not blue. They are good planers. Grizzly gets theirs from the same manufacturer we get ours. You wont go wrong with it thats for sure.
Offline Dan_Shade
« Reply #4 on: December 29, 2008, 12:40:12 PM »
the  g0544?
Offline ADAMINMO
« Reply #5 on: December 29, 2008, 12:50:51 PM »
Yup .... same one.The one we now have has a thicker max height.I sent you a pm with the link to the one we have that took the place of the Grizzly style one. 1/8" min to 7 " max I think. (You can squeeze it to 7.75" max)
Offline Norm
« Reply #6 on: December 29, 2008, 02:23:27 PM »
Dan I have the spiral cutter head and would not go back to straight knives no matter what. It is so quiet I don't even have to wear hearing protection with it. I had a jet before and even with headsets on it was louder then this one without them.
I'm not sure how many bd ft I've done in one run but have never felt like I was lacking for power even when doing white oak with it. One thing though is you really need a heavy duty dust collector for it. My biggest constraint is having to empty mine because it's just plain too small. I finally got it hooked up in the new shop over on the farm and my Christmas present to myself is a bigger better collection system.
Now don't let me talk you out of the bigger one though. The only reason I didn't get it was my budget. :D
Offline IL Bull
  • Thank God I'm A Country Boy
« Reply #7 on: December 29, 2008, 04:41:49 PM »
I have the 15" Grizzly with the spiral cutting head.  Just like Norm says, it is very quiet.  i have trouble with the out feed roller leaving little lines in the wood.  Anyone else have this problem?  i also don't like the location of the reset button.  You have to take a panel off and then the top of the relay box to reset it.   That should have been designed differently from a guy that probably crowds it a little too much.
Joe
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
Offline Dan_Shade
« Reply #8 on: January 01, 2009, 09:37:12 AM »
while I was goofing off making up my mind they got more expensive, I should have seen that coming, though....
Offline Gilman
  • !eliforp ym tide ot deen I
« Reply #9 on: January 01, 2009, 02:47:07 PM »
ADAMINMO,
I was surprised to see that Baker's AN-20 5HP AUTOMATIC PLANER (5105) is $600 less than the Grizzly.  Is the difference the spiral knives?
David
http://www.baker-online.com/Categories5.aspx?Category=dc23ac56-3a7c-478b-97be-293a237cc57e
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Offline ADAMINMO
« Reply #10 on: January 05, 2009, 11:37:30 AM »
The difference that I can find is that theirs has variable feed speed and the Baker don't. It is an option on the Baker for $500.00 I think.
Offline TexasTimbers
    • Dovetail Spline Jig
« Reply #11 on: January 05, 2009, 07:53:45 PM »
Dan,
I always buy the most I can afford. The few times I have not I have regretted it. But when it comes to planers, "most" to me means width more than anything else, as long as it isn't going to be under-powered etc.
In this case, since they are both 20" planers and the 1033x gets such great reviews, I believe I would have to save the $1500 to use on a DC upgrade or whatever other need is most pressing in your shop.
The carbide cutterhead is a must-have. I have one on my Woodmaster and it is S-U-P-E-R   Q-U-I-E-T.
But of course if I were planer shopping I would probably buy the Baker unit from Adam after seeing this thread.
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #12 on: January 05, 2009, 10:56:27 PM »
Norm,   how much use have you gotten before you had to rotate the cutters on your spiral head?  And.... have you had to replace them?  I notice they are very expensive to replace.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline Norm
« Reply #13 on: January 06, 2009, 07:41:35 AM »
Boy that's hard to say as I really have never kept track of it and I'm still on the originals. They are kind of pricey but I still feel that they last longer and do a better job so it's still cheaper than straight knives. Just a gut feeling as I don't have any idea of what I've run with them.
« Reply #14 on: January 06, 2009, 07:58:54 AM »
Chris,
The inserts have 4 sides so divide the cost of each by four. Because you just rotate them to get a "new insert".
Offline metalspinner
« Reply #15 on: January 06, 2009, 08:03:52 AM »
Has anyone rotated their carbide inserts yet and kept track of the time?
« Reply #16 on: January 06, 2009, 09:25:13 AM »
I have not kept track of anything like that MS. I get lucky to find the time to even rotate them. There are 164 of them on my head and it takes more than an hour to remove the ducting, remove the  planer cover, loosen each nut, spin the insert 1/4 turn, tighten the nut, do the next one times 164, then replace the cover and ducting.
The trade-off is sure worth it though. I can't believe how much mileage I got out of that first side. I don't know how much it was but it was a bunch.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #17 on: January 06, 2009, 09:29:43 AM »
I assume that when you turn one cutter, you turn them all in tandem rather than turn them in a random manner?  Is there any way to know which cutter has been turned and which has not been turned?
« Reply #18 on: January 06, 2009, 09:42:27 AM »
At first I started out marking the used edge with a red sharpie, but after one row I realized it wasn't necessary. You can see the wear on the leading edge compared to the other 3 sides clearly. Just pick a direction and stay with it. I chose CW. I started at one end, and followed that helical row. I rotated the head as I needed to keep my driver in a near upright position.
For those considering a caride cutter, make sure it is helical (the rows of cutters do not all enter the wood at the same time, they are staggered) & offset. Offset means the leading edge of the inserts themselves do not enter the wood at a 90 angle, but a little less so that it has a better cutting ability. I don't know the angle on my cutters but I would guess they are about 2 to 3 off of 90.
Don't buy a cutterhead that does not have these three important features:
1)Helical rows of cutters
2)Cutters that are offset from 90
3)Inserts have four cutting sides
You are spending too much money to get *almost* there.
Offline Dan_Shade
« Reply #19 on: January 08, 2009, 10:01:20 PM »
well, I pulled the trigger
I'll report back when I get the new circuit wired and run a test board.
My wallet is recovering.
Grizzly 15 inch spiral head planer. Is 3 hp enough?
Started by 21incher on General Woodworking
Last post February 07, 2017, 01:01:00 PM
by 21incher
Grizzly z series 24" planer, 14" table saw, 12" jointer, 37" sander
Started by Piston on General Woodworking
Last post August 28, 2013, 02:29:44 PM
by Piston
H.P. for Grizzly 20" Planer
Started by highpockets on Sawmills and Milling
Last post January 03, 2006, 08:44:38 PM
by Ironwood
It's here! It's here! (Grizzly 20" Planer)
Started by metalspinner on General Woodworking
Last post April 29, 2008, 01:51:00 PM
by TexasTimbers
