Author Topic: 55Gal. Wood stove house heater  (Read 5882 times)
Offline BowHunter58
« on: January 03, 2015, 03:24:24 PM »
Hi All, I'm new here. Thought I'd start of with a question.
I just built a 55Gal. wood stove. And I'll be using it for Heat in my house.
And I was looking for some input, pros and cons, from anyone experienced with these type of stoves.
I put aprox. 1-1/2" of sand on the bottom, and then put fire brick on top of the sand.
Should work ok.
Any info would be helpful.
Steve
Offline outlawcowboy
Re: 55Gal. Wood stove house heater
« Reply #1 on: January 03, 2015, 03:35:16 PM »
sounds like it should work good like that just remember to put a damper in to shut it down so it is not just a rawring fire all the time. Ive have some buddy's that have build them like that and it would burn them out of there houses or shop or whatever they had it in.
1999 ford F-350 7.3 diesel
1961 Massey Ferguson 65: 50hp diesel
Stihl MS391
Stihl MS192
Offline beenthere
« Reply #2 on: January 03, 2015, 06:21:39 PM »
Welcome to the Forestry Forum.
Would help if you would go to your profile and add your location. Answers may be more forthcoming that way.
Such stoves can get very hot and very fast, and sometimes can last a very long time. However there are exceptions. :)
Offline loghorse
« Reply #3 on: January 03, 2015, 07:09:00 PM »
To be alittle safe ,once a week shut off the lights in the room with the stove and see if you can see the light of the fire through the wall of the barrel.first time you see a pin hole throw it out.this is from experience .
« Reply #4 on: January 03, 2015, 07:16:08 PM »
i was thinking about building one for my shop but then i found a old sears wood stove that has a blower on it so i went with that instead just for safty reasons as my shop will be for wood working. That is a good idea tho loghorse to keep up on the maintaine
Stihl MS391
Stihl MS192
Offline BowHunter58
« Reply #5 on: January 03, 2015, 07:24:39 PM »
I added my location, and avatar. My 1st Pa deer.
Thanks for the advice, keep'em coming.
Offline goose63
« Reply #6 on: January 03, 2015, 07:39:46 PM »
I have built several of them with 3 inches of sand or clay but you should be ok with the sand and fire brick. when I get to my B I Ls I will take a picture of his
goose
thank you to all the vets
Offline thecfarm
« Reply #7 on: January 03, 2015, 07:55:02 PM »
BowHunter58,welcome to the forum.
I never built one,but I always liked them double ones.
Offline dave_dj1
« Reply #8 on: January 03, 2015, 08:26:18 PM »
I know someone is going to say it so let it be me, your insurance company might not approve of it!
That being said, as with any wood stove there are inherent dangers. Be sure and keep safety a number one concern! We don't want to read about you losing your home or a loved one. If you can control the air intake you can control the fire, make it as tight as you can. Did you buy a kit? I built one for my garage last year, I used the Volgazang kit I bought at TSC. I love it, I made a couple of modifications that allows me to control the air intake, I don't use the damper that came with the kit, I put my own in the pipe about a foot up. It heats great and I can get it to go all night if I want it to. I used 1" firebrick in the bottom.
Take care,
dave
OH yeah, welcome to the sight!
Offline Mn woodchuck
  • I'm old but still going.
« Reply #9 on: January 04, 2015, 12:15:16 AM »
I used one to heat my house 4000 square feet for 20 years   Keep it away from the walls cause that girl will throw HEAT  I am using OWB and forced air. Not as nice of warm feeling but I guess it's safer and is cleaner
to soon oldt to late schmart!
3 husky 350xps 340xp 362 346. 372xp McCullough 710.and a jonsered 2150 sopped up..
Cat D6 D2
Offline gspren
« Reply #10 on: January 04, 2015, 09:05:59 AM »
  If you didn't put it in the house yet make at least one good hot fire in it OUTSIDE to burn off the paint, it will smoke and stink.
Offline DMcCoy
« Reply #11 on: January 04, 2015, 09:12:04 AM »
Like mentioned above - insurance.
I use one to heat my shop - and it works very well.  An old SOTZ door, and homemade rack to hold upper and lower barrels.  Like mentioned above they throw alot of heat.  I just let the ashes build up to protect the bottom.  Frequent use keeps it dry inside, 2nd set of barrels in 30 yrs.  I never let them get red hot either.
Don't quote me but I believe it is 36" min to any combustible surface for an un registered wood heater.
Offline Swatson
  • Arkansas born and raised
« Reply #12 on: January 04, 2015, 12:21:38 PM »
I second this motion...there is a ton of crud that burns off.  I even had some of the paint on the outside of the barrel flaming.
I cant figure out which one I like better: working with wood or making the tools to work with wood.
Offline goose63
« Reply #13 on: January 04, 2015, 02:48:08 PM »
This is what I did
  we had the local machine shop role the sheet metal for us the we welded the seam cot holes in the barrel then welded the tube in but a box fan behind it on low works good and don't use a lot of wood
goose
Offline thecfarm
« Reply #14 on: January 04, 2015, 04:23:02 PM »
goose63,never saw one like that. But I can see why it would work good. Looks like that brown heater is an old one too. Seem like I was somewheres and some guy told me these are best heaters ever.
Offline BowHunter58
« Reply #15 on: January 05, 2015, 05:46:14 AM »
Thanks for all the great tips.
I'm in process of burning the paint off the barrel now.
The insurance thing, is on my mind. But so is, there not paying my bills, they are one of them.
I'll check into it.
Thanks for all the help.
Offline BowHunter58
« Reply #16 on: January 05, 2015, 05:24:38 PM »
Goose63, That's a great looking stove.
DMcCoy, I think it's 36" to 40" clearance.
Offline r.man
« Reply #17 on: January 05, 2015, 07:33:09 PM »
The door needs to be reasonably rigid. I ran an one for a season 25 yrs ago, it was homemade and old when it was given to me. The door was just a piece of the end of the barrel with hinges on one side and a latch on the other. I still remember the woof woof noise it made when I had too much dry lathe in it and it was sucking in the door to get another gulp of air. I think it was glowing before I got a pail of water into it to slow it down. I have always heard great things about double barrel stoves but that one with the Dyson fan hole in the top barrel looks like a great design.
Offline drobertson
« Reply #18 on: January 05, 2015, 08:00:50 PM »
I've known of two that were used like you have,  and they work, work good.  Not sure on the insurance issue, but careful attention covers a lot of ground. Moisture is the biggest killer to the thin walls of barrels.
Offline WmFritz
« Reply #19 on: January 05, 2015, 08:17:10 PM »
I fabbed one up in my first shop (wow... thirty some years ago) from two 30 gallon grease drums. It kept that 25' x 25' garage toasty.  A friend of mine has 55 gallon drums in the same size building at his cabin and we're down to our t-shirts with a window open when we're out there working. It can cook us out.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
wood stove water heater
Started by 47sawdust on Firewood and Wood Heating
Last post March 03, 2021, 07:41:02 PM
by Technoid
question
Lil' House outdoor wood burning heater. ??
Started by Bibbyman on General Board
Last post October 13, 2010, 08:23:13 PM
by poolman
Whole house wood stove suggestions
Started by Slab Slicer on Firewood and Wood Heating
Last post October 19, 2012, 10:24:39 PM
by PaAnkerbalken
Anybody using a lil house heater?
Started by Handy Andy on Firewood and Wood Heating
Last post September 09, 2010, 06:02:45 PM
by CX3
