Author Topic: kiln dried Walnut  (Read 1901 times)
Offline Cazzhrdwd
kiln dried Walnut
« on: October 30, 2015, 08:39:53 PM »
I finished drying some Walnut yesterday, all seem to go well. I mixed some green with air dried, both came down to 8 % but the air dried boards were much heavier than the green ones. I had to put the meter back on them more than once just to make sure I wasn't missing something.
Has anyone experienced AD walnut being heavier than Walnut dried from green?
96 Woodmizer LT40Super  Woodmizer 5 head moulder
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
Re: kiln dried Walnut
« Reply #1 on: October 30, 2015, 09:23:17 PM »
That does seem to be strange.  I have a __ pin meter but I don't put too much faith in it.  I weigh my samples and then try the test samples in the microwave.  That method seems to be the most accurate.
Have you cut a cross section of the walnut and used your meter in the middle of the boards?
Are you familiar with the method of weighing the wood based on dried samples and the actual sample in the kiln?.  If not, there are many members here that can help.
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline beenthere
« Reply #2 on: October 30, 2015, 09:54:22 PM »
How did you determine that the air dried boards were much heavier than the green ones?  and how much heavier were they?
Offline Cazzhrdwd
« Reply #3 on: October 30, 2015, 10:08:49 PM »
No, the meter reads the same on several different boards.
Offline Cazzhrdwd
« Reply #4 on: October 30, 2015, 10:11:18 PM »
Only by handling them
Quote
Not sure, almost twice as much, but can't say for certain.
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #5 on: October 30, 2015, 11:47:11 PM »
My guess is that the wood still has a wet core, walnut is prone to trap core moisture, even if the outer case reads dry.  I've had it happen to me.  As Glenn1 says, oven dry technique is the definitive answer.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
« Reply #6 on: October 31, 2015, 07:11:55 AM »
I would say the air dried boards are much drier. Water is about the only thing gonna make the others heavy. Cut cross sections and check again. The meter is not reading deep enough into the wood to be accurate.
FRank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline Cazzhrdwd
« Reply #7 on: October 31, 2015, 09:45:32 PM »
That would be my guess, but the air dried ones are the heavier ones. I use the Delmhorst j2000 with the slide hammer, it has the 1 1/2 pins on it and usually gets decent readings on the core. But I agree the core has to be the culprit. It seems to be about five 9' boards that are 12 inches wide that are the heavier ones. 45 bdf out of 400 that seems to be different.
YH I'm used to Walnut being difficult, this load was at 160į for 3 days and I do believe these heavier boards have moisture in them still.
Offline bkaimwood
  • Life's too short to sweat the small stuff
« Reply #8 on: November 01, 2015, 06:51:00 PM »
I've run into the same...air dried, in the kiln FOREVER, still showing high core MC...not much more I can do, except keep waiting...it ties up another full load...time to sell it advising the buyer accordingly, needs time yet...move it,  discount it, and move on...keep + cash flow
bk
Offline GeneWengert-WoodDoc
« Reply #9 on: November 01, 2015, 11:22:48 PM »
You have the perfect meter for checking MC.  The density of wood changes about 10% due to shrinkage, when drying, but there is no difference between air dry-kiln dry and straight kiln drying.  So, if there is a difference, it is due to growth difference, not drying.
FOR SALE 5/4 4/4 Red Oak clear/#1 Air Dried/Kiln Dried
Started by hillbillyhogs on For Sale
Last post February 21, 2013, 07:48:20 PM
by hillbillyhogs
Kiln dried lumber vs air dried
Started by Wisconsintimber on Drying and Processing
Last post December 01, 2014, 12:34:56 PM
by Jemclimber
Kiln dried, air dried, MCs and EMCs
Started by GeneWengert-WoodDoc on Drying and Processing
Last post February 20, 2013, 07:22:22 AM
Air Dried Walnut
Started by firefighter ontheside on Drying and Processing
Last post April 07, 2018, 09:17:03 PM
