SPACE AVAILABLE
What kind of ATV should I get and why? (I'll ask a trailer specific question once I'm done with my initial research).Purpose: Cut wood to build log cabin, sheds, fences, etc. + own firewood over the first 1-2y week-ends. Then sell some wood, again over the week-ends when I feel like it I'm not looking for another full-time job.Land : 322 acres. I've attached a topo map below. Elevation in meters, so elevation gain on the land is approx. 550'. There's no forest roads as per say. The ATV needs to be able to climb with a good load.Wood : Mostly mature forest, 80 acres is old growth but I'll not touch these trees until they hit the ground.Thanks all
Yesterday at a sportsman show I saw a Hustler MDV, which is a UTV with a bed that lowers or dumps and I thought of this thread. I have no experience with this brand, just saw it at a show.
...I also have a plastic tub ( reused paddle boat bottom) which I use when I want to junk up firewood at "the stump"...
I think you need to narrow your choices down to side by side UTV or regular ATV. A regular ATV is not nearly as wide as a UTV and will be more nimble in the woods. A UTV will have more load capacity, be more stable, and tow more.My suggestion? Get a 6x6 ATV. We use them at work for maple tubing installations. They don't turn as tight as a 4 wheeler, but are very nimble in the woods, and you would be amazed how much more stable they are, and the places they will go. They have a rear cargo box that dumps as well.We have used polaris sportsman big boss 800's in the past, I think they have a new 570 big boss that is supposed to be improved a bit (power steering, 2up seat)We did also just get a Can am outlander 6x6 as well, with a track kit for deep snow. It's geared lower than a regular outlander and is wider.If you really want to work an ATV hard and also keep the width and agility of a 4 wheeler, get a 6x6. You can recreation-ally ride a 6x6 just fine atv accessories, but the regular 4 wheelers will outdo them trail riding generally. Although a 6x6 will go some pretty foolish places
Started by dundee on General Board
Started by Dave Shepard on General Board
Started by SBarret23 on General Woodworking
Started by Typhoon on Ask The Forester
