Author Topic: Cutting firewood in the brush and thorns.  (Read 863 times)
Offline cutterboy
  • Sometimes trees fall where they want to.
« on: March 24, 2021, 07:08:40 PM »
Yes, there are trees behind that brush.
Yesterday I started cutting in the grown up pasture I was cutting in last spring. To get to this area I have to go through a field that is too wet for the tractor so the Cub Cadet had to do the job. This old pasture has grown up into a mess of multiflora,(wild rose)bittersweet vines, grape vines and other bushes. This morning I went to cut the trees behind that mass of brush in the above picture. There was a clump of six ash trees, nice sized firewood trees. It took me 20 minutes to clear the brush and thorns but I got some good firewood.
Then it was load up the dump trailer and take several trips up to the barn. I didn't load the trailer too heavy because the ground there was pretty rough.
   Happy cutting.....Cutter
Online SwampDonkey
  • Large Tooth
Re: Cutting firewood in the brush and thorns.
« Reply #1 on: March 25, 2021, 03:02:07 AM »
Nice to have ground without pits and mounds for the lawn mower to traverse. ;D
No amount of belief makes something a fact. James Randi
Offline thecfarm
« Reply #2 on: March 25, 2021, 08:09:11 AM »
Yes, nice land you have there. I would have a hard time taking a picture of my grown up pastures and not showing a bunch of rocks.  :(
  I do have one place, maybe a acre, that is not all that bad for rocks and being level. But that is only about acre too. Lots of white pine that is not much good except for firewood. Very crooked and 2-3 leaders per tree. It's making more firewood every year.  :D  I do keep the ground mowed with a bush hog. Maybe someday I will get to that project, after I get the other projects done.  :D  Note the "s" after projects.   :D
I have a lot of grown up pastures. Lots of stone wall in the woods to prove it. Lots of rocks and uneven ground to work around. But that was when most of the hay was cut by hand or one horse and a short cutter bar.
There was at least 3 homes, farms, on the land that I own now.
Offline upnut
  • Wood Tick
« Reply #3 on: March 26, 2021, 05:03:20 PM »
In the racing world that's called " run what ya brung"... :D...I would think the weight distribution on the Cub Cadet would make it ideal for those conditions! Where there's a will there's a way, or in this case a zero turn...hope you have differential lock!
Scott B.
I did not fall, there was a GRAVITY SURGE!
Offline KEC
« Reply #4 on: March 26, 2021, 07:25:26 PM »
I have a similar lawn tractor and wagon to haul wood to the house and it works out real well. It is usually mid-summer before it's dry enough to get out back. I cut some firewood on my neighbor's property and mow and clear trees from the trails.
Offline cutterboy
« Reply #5 on: March 27, 2021, 07:12:46 AM »
My poor Cub Cadet. When I brought him home he thought he was just going to mow lawns in the summer and rest in the barn all winter. Was he in for a surprise! :o smiley_devil :D :D :D
Offline mike_belben
  • Pulp Friction
« Reply #6 on: March 27, 2021, 10:59:37 AM »
ATV tires go a long way in helping a zero turn or ride on mower in the mushy season.  I was unable to mow much of my place on turf tires.
Isaiah 63:10
Offline Old saw fixer
  • Grumpy old man!
« Reply #7 on: March 28, 2021, 11:59:00 AM »
     Is that a 520H Mike?  I have a 416H and a 314-8 in active use.  Good machines.
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M
Echo CS-2511T
Logrite Cant Hook (with log stand), and Hookaroon
Offline mike_belben
  • Pulp Friction
« Reply #8 on: March 28, 2021, 01:11:36 PM »
I'll have to look when im home.  Its one of those horses that calls itself a toro and only has a model number on a tiny data plate. Great machine but finally needs fixin.
Id say i got my $40 worth
Isaiah 63:10
Offline Sauna freak
« Reply #9 on: March 28, 2021, 10:03:37 PM »
Makes me appreciate the frozen North.  Sure it gets 50 below in the winter, and the mosquitos, deer flies and gnats will have a turf war over your blood for the 2 months of summer, but not much grows thorns or tries to burn your skin off up here.
About the worst I have to contend with is tag alder that likes to grow sideways, and moss covered stumps and rocks that look like the 5000 clumps of moss covered moss you've just powered over until you ram them with your suspension or snag a log on one while chaining it to somewhere dry enough to handle.
Sauna... like spa treatment, but for men
Stihl FS130 brush cutting (review)
Started by bmill on Chainsaws
Last post June 08, 2010, 02:33:30 AM
by SwampDonkey
R1 or R4 on tractor for clearing thorns
Started by FiddlinForester on Forestry and Logging
Last post April 25, 2019, 09:36:07 PM
by krusty
A day cutting firewood
Started by mrselfreliance on Firewood and Wood Heating
Last post August 28, 2016, 01:54:09 PM
by loggerman1959
firewood cutting
Started by Quartlow on General Board
Last post December 21, 2007, 01:37:54 PM
by rebocardo
