Author Topic: Firewood Table Build  (Read 3128 times)
Offline Walnut Beast
Re: Firewood Table Build
« Reply #40 on: May 03, 2021, 03:05:39 PM »
You might have copied it but you probably saved a substantial amount of money. Good job 👍
Offline Tacotodd
  • To learn and help
« Reply #41 on: May 05, 2021, 02:52:55 PM »
@711ac barndominion , thats hilarious. Im gonna use THAT term for some of my friends places.
Trying harder everyday.
Offline 711ac
« Reply #42 on: May 05, 2021, 05:09:59 PM »
No storage, but on my list. We have what's come to be called a "barndominium". Just enough house on the end of the generous shop. I really don't want to give up the floor space in either the shop or house. In my view if I add storage, it'll be meaningful (1000 gallon) and that will take another fairly big tank for expansion adding up to a good bit of floor space even if I put the 1000g tank in a vertical position. Then there's the price of used LP tanks, it wasn't too long ago that we'd pick them up easily and make smokers out of them 😆 not anymore!
Have you ever heard of American Solartechnic? It's a Mainer company that offers products for solar and wood hydronic heating. The company offers a pretty interesting solution to thermal storage.
American Solartechnics, LLC. - Heat Bank Storage Tanks
I listen to Tom every Saturday on the radio 👍but I want pressurized storage.
Offline PoginyHill
  • Gentleman logger
« Reply #43 on: May 24, 2021, 08:51:55 AM »
Frame is painted. Began applying wood to the top. The end is near. Excited to cut my first cord on it.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline mike_belben
  • Pulp Friction
« Reply #44 on: May 24, 2021, 10:43:25 AM »
Fine craftsmanship.  Im eager to see what you make of it.
Isaiah 63:10
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #45 on: May 30, 2021, 02:11:43 PM »
Looking good. Nice location you have up there. Pretty view with lots of trees.
Offline doc henderson
« Reply #46 on: May 30, 2021, 06:47:51 PM »
time to get a few scratches in the paint soon.  nice. ;)
Offline jmur1
  • Wood is King
« Reply #47 on: May 31, 2021, 11:22:59 AM »
I like it.  Nice Solid build.  How do you like the Kubota loader?  Ive got an old JD 1030 and its about to get the boot.  Ive being looking at the different Kubotas.  Keep us posted to how the table works out.
jmur1
Easy does it
Offline PoginyHill
  • Gentleman logger
« Reply #48 on: June 01, 2021, 09:08:11 AM »
jmur1
The loader works fine. My only complaint with the M7060 is hydraulic flow. I have the 8 speed, which comes with a lower hydraulic flow rate. The 12 speed version has higher gpm (can't recall the exact numbers, but easily obtained online). The loader can be slow at times. I've used a neighbor's New Holland. Generally I don't like the tractor, but the hydraulics are better than mine. The loader itself if rugged enough and mounts/dismounts easily.
Firewood table is done. Not used it yet, but should see a scratch or two before the week is out.
Offline PoginyHill
  • Gentleman logger
« Reply #49 on: June 01, 2021, 09:21:40 AM »
Last step was 5/4" PT boards for the off-bearing table and 2X4s for the cutting table. All mating surfaces and end-grain got a heavy dose of used motor oil. First stem is an ugly "pasture spruce". Table is designed for 16" and 24" cuts. Wasn't able to cut anything yet with family visiting over the holiday weekend. Should see some action this week.
Offline PoginyHill
  • Gentleman logger
« Reply #50 on: June 01, 2021, 09:24:37 AM »
Thanks, and yes, very lucky to have stumbled upon this drug house being sold by the Federal Marshall 25yrs ago. It's been a non-stop, but fun project ever since.
« Reply #51 on: June 01, 2021, 10:55:03 AM »
well with family visiting, you would of had some helpers.   :)  are the top boards considered sacrificial?  will have to replace occasionally in your plan?  may depend on who is running the saw.
Offline PoginyHill
  • Gentleman logger
« Reply #52 on: June 01, 2021, 11:11:06 AM »
are the top boards considered sacrificial?  will have to replace occasionally in you plan?  may depend on who is running the saw.
Yes. Top two layers of 2X4's are fastened with common deck screws. I will cut the top 2X4 to match the firewood length as needed. I hope I'd need to work hard to hit any metal with the saw, but ya never know....
« Reply #53 on: June 01, 2021, 11:22:36 AM »
with it setting by your wood pile, will the splitter have a spot there also?  I see a red chunk of iron in the back ground, but does not look like a splitter.
Offline PoginyHill
  • Gentleman logger
« Reply #54 on: June 01, 2021, 12:26:06 PM »
Loader/trailer on one side and splitter/firewood pile on the other side. Haven't put all the pieces together, but will get a pic or two when I do. The red thing is my Wallenstein tractor winch.
Offline PoginyHill
  • Gentleman logger
« Reply #55 on: June 07, 2021, 08:57:12 AM »
Maiden voyage of the firewood table and new-to-me All-Wood splitter. Did about 1.5 cords with the wife. Hot day. Us northerners don't do well with the 80's. Overall worked well. Biggest complaint is the splitter. For a 24" stroke, opening was exactly 24". No room for variation in the 24" pieces I cut. So I cut back the wedge point to give about 3/4" extra room. Much better, but still a PITA on those occasional 25" pieces. May cut back the wedge point some more or cut off the 6 tangs on the push plate and weld a bunch of small beads - a little less standout distance from the plate.
Offline mike_belben
  • Pulp Friction
« Reply #56 on: June 07, 2021, 09:19:45 AM »
Boy thats a tidy jobsite.  Looks great.
 I hope youre chaining all that beautiful iron up with a camera on it at night.
Isaiah 63:10
Offline PoginyHill
  • Gentleman logger
« Reply #57 on: June 07, 2021, 09:31:49 AM »
Thanks, Mike. Although wife still warns me "don't make our yard look like a junk yard!" Thankfully, theft is not much of a problem in our area. At least big stuff. Still have drug-induced break-ins, occasional bank or convenience store stick-up, and theft of hand-tools.
Offline mike_belben
  • Pulp Friction
« Reply #58 on: June 07, 2021, 09:57:21 AM »
I broke mine in early.  Our maternity pictures were literally in a junk yard.  Came out really good too actually. Her idea.
Isaiah 63:10
I want to build a table
Started by Brad_bb on General Woodworking
Last post February 02, 2012, 09:10:05 PM
by Ironwood
FireHouse Table Build
Started by Jimmysmill13 on General Woodworking
Last post December 19, 2015, 08:18:48 AM
by caveman
River Table Build
Started by boonesyard on General Woodworking
Last post April 21, 2021, 10:38:07 AM
by firefighter ontheside
Farm Table Build
Started by 123maxbars on General Woodworking
Last post October 24, 2016, 10:59:09 PM
by opticsguy
