Author Topic: Flue pipe design for wood stove  (Read 1203 times)
Offline DaveMueller
« on: September 05, 2021, 08:09:36 PM »
Is there a heating benefit to having a long vertical run (6 to 8') of single wall flue pipe in the living space (ie stove to ceiling) versus going through the wall as soon as practical? I'm thinking there's a lot of radiated heat to be gained.
Total vertical height stove to cap will be about 20'.
Dave
Offline Tacotodd
  • To learn and help
Re: Flue pipe design for wood stove
« Reply #1 on: September 05, 2021, 08:21:45 PM »
Youíre not the only person that I know thatís wondered THAT EXACT THING!
Trying harder everyday.
Offline newoodguy78
« Reply #2 on: September 05, 2021, 08:50:21 PM »
I canít answer that exact question but Iíve added the blowers that install in the pipe and the heat gain was impressive. Not sure of the make Heat-mor? Maybe
Sounds like you have the room for one might be worth looking into.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #3 on: September 06, 2021, 01:51:47 AM »
If you cool the hot gasses in that vertical run you can get back drafts and corrosive condensations.
Offline doc henderson
« Reply #4 on: September 06, 2021, 03:28:29 AM »
If you make a 90į turn from vertical, that will heat up the wall of the pipe as the hot air contacts it to be forced around the corner.  it will get very hot and be the first to rot through.  our stove in the living room goes 16 feet straight up and through the ceiling and roof.  that will give it the best draft.  and we used double wall pipe to keep the temp up so the gas and water vapor do not condense on the walls of the flue.  ( creosote ... flammable).  you will get the most heat from the stove, and should not need it from the pipe.
Offline Don P
    • Calculator Index
« Reply #5 on: September 06, 2021, 08:12:31 AM »
On what Gary was mentioning, you will get more heat, however each setup and fuel is different. If you cool too much that is a problem. The heat extractors work well but are not recommended for that reason. This is the referenced standard;
NFPA 211: Standard for Chimneys, Fireplaces, Vents, and Solid Fuel-Burning Appliances
Offline mike_belben
  • Pulp Friction
« Reply #6 on: September 06, 2021, 08:49:23 AM »
The more pipe you can have in the living space the better.  Less chance youll light the wall at a short 90 too.  Thimbles can only do so much.
If its just an old open chamber stove, baffling the block the flame from flying up the flu can about double heat in the burn box.  Done it a few times.  Have built a few stoves too.  Only backdrafting ive ever had was from short lengths of flue in high winds. Add a stack section and it goes away.
Isaiah 63:10
Offline Don P
    • Calculator Index
« Reply #7 on: September 06, 2021, 10:01:51 AM »
I have about 6' of insulated where it passes through the roof and up. The vertical flue is about 25' total, the rest is single wall inside. I burn small, dry, with undamped air in a small stove and clean the pipe once a decade out of boredom. A very clean burn, most of the time after startup just heat waves out the stack. How you burn within each setup makes a tremendous difference.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: September 06, 2021, 12:02:00 PM »
Oh yeah.. A hot stack is maintenance free, i dont care what you burn in it.  Ive run pure pine, pure vegetable oil, sawdust and waste vegetable oil, motor oil, you name it.  700f and up youll stay clean.  I'd routinely get ripping and watch the sparks fly up into the night sky.  The only brushing ever done (2x in 10 years) was just verifying that brushing was not needed.
I built one stove that is fed sawdust and wvo by an adjustable auger into a modified rocket with a swirl riser inside the main body. with secondary hot air injection along the riser axis and a 3 foot drop to reach the exit.  In testing itll run 500avg on the body, 900-1200 in the 4" burn pipe and below 300 put the stack.  Im anxious to put it into full time service and see if the stack temps cause any adversity.  There is no ash to clean out and no smoke once its ripping so i dont think there will be a lot of unburned gasses.
Isaiah 63:10
Offline mike_belben
  • Pulp Friction
« Reply #9 on: September 06, 2021, 12:08:24 PM »
A safety btw here.  If you ever have a stove take off and the flue glowing in the basement DONT damper it down.  Open the flue wide open and open the door wide open.  Yes the flame will really get howling but the flue will draft tremendous volume of cool air.  In a tight house youll need to crack a window or door because its huge CFM coming through.  This cool air will cool the flue.  If you want it to settle down faster keep a roll of toilet paper or paper towel near your laundry sink.  Soak it and toss that in.  The water converting to steam will rapidly suck heat out of that firebox and get it under control.  As will misting it with a spray bottle.  Just dont flood it with a bucket and crack a cast iron casting.
If you wanna fiddle with stoves sooner or later one will run away.  Never load up one thats new to you and leave or go to bed until you are really in tune with its dynamics.
Isaiah 63:10
Offline DaveMueller
« Reply #10 on: September 06, 2021, 12:31:49 PM »
Thanks everyone for the tips and suggestions.  I'm aware of the issue with cooling the pipe too much, that's why I asked.
Offline curved-wood
« Reply #11 on: September 06, 2021, 03:06:18 PM »
If you decide to go through the wall use 2x 45 degree elbow instead of a 90 degree, less turbulence.
If you have a chimney fire , open a crack in the door and empty your fire extinguisher, the strong draft will pull it up inside the chimney
Offline 21incher
« Reply #12 on: September 06, 2021, 04:20:15 PM »
I went straight with double wall in the house because of code requirements. Check with your stove shop to see what they recommend for your installation and code enforcement officer when you apply for the permit. He will have the final say to get the certificate of compliance so your insurance will cover it.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Nathan4104
« Reply #13 on: September 06, 2021, 06:12:18 PM »
I run a wood cook stove (Elmira Fireview), straight up stovepipe, single wall about 10í, then 6í or so of insulated through the ceiling/attic.  Dry wood, hot fires, rarely any soot.  I clean it a few times a season just to be sure, never any more than a couple cups of dust.
Mike, you have such great advice, rhe toilet paper roll trick is one that would never occurred to me!   Years ago We had a stove run away (Tamarack/larch wood, burns hot) and that advice would have helped!  We ended up burning the paint off double wall pipe in that oneÖ..
Offline newoodguy78
« Reply #14 on: September 07, 2021, 12:04:47 AM »
Thatís good to know about the cooling effects of those blowers . The ones Iíve helped put in were both in shop stoves that pretty much ran wide open heating quite a large space. Creosote wasnít an issue with either of them will certainly keep it in mind for the future though.
Offline mike_belben
  • Pulp Friction
« Reply #15 on: September 07, 2021, 12:05:53 PM »
glad to help nathan.  i havent had paint on a stove part in a long time.  i have seen lava orange 3 foot up the single wall pipe a few times and thought for sure, its about to drip open and spew flame onto the floor joists above it.
  ive spritzed water on sheetrock from a windex bottle to keep it from lighting while a runaway winds down, and watched it flash to steam.  lots of excitement to be had when youre stupid!
Isaiah 63:10
Offline DaveMueller
« Reply #16 on: September 07, 2021, 06:58:07 PM »
Good tip, I never thought to check with the township. Not exactly a metropolis here, we're lucky to actually have a township building.
wood stove install and flue pipes
Started by rebocardo on General Board
Last post September 30, 2006, 07:55:13 PM
by SwampDonkey
question
E-Classic 2400- Question regarding double-walled flue pipe outside temperature
Started by garret on Firewood and Wood Heating
Last post August 04, 2014, 10:43:04 AM
by garret
Stove Pipe
Started by brendonv on Firewood and Wood Heating
Last post September 12, 2011, 07:02:30 AM
by Al_Smith
Stove pipe Douglas fir
Started by redbeard on Sawmills and Milling
Last post July 15, 2012, 11:14:35 PM
by barbender
