Stihl MS250
Started by GE, June 16, 2017, 12:48:29 PM
GE
Having trouble with my saw. It will start momentarily then dies. I have replaced the fuel line, fuel filter, air cleaner and plug with the same results., any suggestions?
dougand3
Next would be clean and rebuild kit the carb OR buy a new carb. They cost ~$10 online and have Hi & Lo screws to adjust.
GE
Thanks, that's the direction I was headed!
blueberrymuzik
Before you get too deep into the carb, take a look at the impulse line running from the engine to the back side of the carb mount. That impulse is what causes the carb to pump fuel when you are not in the choke position. It may be cracked or have simply come off at either end.
