Recent
278 Guests, 4 Users
ladylake, KJ42, doc henderson, twar
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Im new on this forum. Don't trow me rocks plz. I just purchase a John Deere / Timberjack Forwarder 1010D 2005. I do have persistent issue. I would like your help to diagnostic.
At the beginning I had crane speed / control issue. Changed one of the joystick / calibrate / adjusted by the dealer. Now run as new corect speed and all movement works.Read More
1 Comment
I have a Timber Harvester mill and when any of the hydraulic levers (taper, turner, log lift etc) are moved the head creeps toward the front/operators station. It moves maybe 6" or so.The hydraulic fluid level is where it should be and I have changed the filter. Any ideas as to why this is happening?...
Read More
2 Comments
Would appreciate some help with finding the gremlins or whatever.
I have a 2005 WM LT40HDD34 with a factory installed blade lube system.
The problem I have is that when using the blade lube system with the switch in the pulse position sometimes it works the way it is designed too and sometimes it is continuous. Read More
2 Comments
If your tract is to be logged, are you supposed to mark the 'take' trees or the 'leave' trees? Is there a certain color or does it vary a lot?
Do you favor using flagging or paint and what is most common? If paint, how do you mark it and do you just use a brush or what? TIA!
8 Comments
After struggling with choosing the right lubricant for years, I finally upgraded my LT40 with a Lubemizer setup. Pine has always seemed to be the biggest offender and causes me the most issues with pitch build up. I have been able to deal with it using water and cotton picker spindle lube, but I would...
Read More
2 Comments
Pages: [1] 2 ... 40
