Author Topic: Cookies?  (Read 3370 times)
Offline kelLOGg
  • More is better but enough is best
Re: Cookies?
« Reply #100 on: October 29, 2019, 12:09:30 PM »
I cut cherry cookies for a wedding and used the denatured alcohol trick with no such luck. Cracks as usual. The wedding was called off. ;D Seriously, it was, but not due to the bad cookies.
Offline tule peak timber
  • The Wizard of Crap
    • tule peak timber
Re: Cookies?
« Reply #101 on: October 29, 2019, 12:13:44 PM »
I thought about the vacuum, but worried about the explosive mix being pumped out-yikes.....
Online doc henderson
Re: Cookies?
« Reply #102 on: October 29, 2019, 12:49:29 PM »
I was half joking, but I would pull a vacuum, then let the vacuum pull in the alcohol to go into the wood.  vacumm alone would boil the water at room temp as I am sure you know.  I watched a you tube on making foe gems from some twigs from bushes and dyed and then resin impregnated.  ground into jewelry.
Offline Hoopty5.0
Re: Cookies?
« Reply #103 on: October 29, 2019, 01:20:43 PM »
Lots of good and ...interesting pictures... in here, thanks all!
Sorry I've been quiet, had some medical stuff with the family last week I had to tend to.
Re: Cookies?
« Reply #104 on: October 29, 2019, 01:22:06 PM »
have not yet found the original I watched prob. 10 years ago.  use vacuum to dye the wood, then resin impregnate it and make a gem.  it would be a challenge to build a chamber for a 4 foot cookie.  you can see the air pulled from the wood, then resin goes in when vacuum released.
Offline alan gage
Re: Cookies?
« Reply #105 on: October 29, 2019, 02:02:43 PM »
I have never eaten a pig ear, pig foot, pig lips, nor pig tail.
You've never had a hotdog?
Alan
Offline alan gage
Re: Cookies?
« Reply #106 on: October 29, 2019, 02:13:50 PM »
I have no idea how denatured alcohol and acetone compare in terms of removing water from cookies but I do know that if given the option I'd much rather work with the alcohol. I swear I can feel my brain cells melting when I inhale acetone and I'm pretty sure it's able to penetrate your skin to some extent as well (not necessarily causing burning or anything but it can't be good). It also evaporates much quicker.
Alan
Offline KnottHeadcustom
  • Not new to sawing!
Re: Cookies?
« Reply #107 on: October 29, 2019, 02:22:59 PM »
Any of you guy's that know and follow us on IG, YT & FB know that we cut thousands of cookies every year for table decor, wall decor and people get them from us to make both small and large tables out of them... By all means as a way to make money we are going to continue to cut them things... They sell pretty well in our area for decorations and I'm one of the only local places to get them... We even set up to do them 400 at a time when they are small dia... and most of the time we cut them out of logs that would otherwise not yield much in the way of slabs or straight lumber...
This video shows how we go thru the process of cutting a rather big batch at once and in a hurry  ;D
DIY Cookie wall cutting on WoodMizer LT15 Wide Head sawmill, Cypress Cookies for wall decorations - YouTube
Re: Cookies?
« Reply #108 on: October 29, 2019, 04:11:27 PM »
not cookies but found what i was trying to describe.  looks right up your alley @tule peak timber
Long link fixed by admin
    • tule peak timber
Re: Cookies?
« Reply #109 on: October 29, 2019, 05:15:47 PM »
Two years ago I posted the fabrication of cookies made from grape vines. Similar idea.
    • tule peak timber
Re: Cookies?
« Reply #110 on: October 29, 2019, 05:18:21 PM »
We cut the same way !
Re: Cookies?
« Reply #111 on: October 29, 2019, 05:44:41 PM »
that is cool!  i am sure I missed it, cause I thought/think it is neat idea.  this is where I got the vacuum ideas.  thanks for fixing my link admin.!
    • tule peak timber
Re: Cookies?
« Reply #112 on: October 29, 2019, 07:11:47 PM »
Wall treatment cedar cookies.
Offline Nebraska
Re: Cookies?
« Reply #113 on: October 29, 2019, 09:34:38 PM »
To the above comments, I'm going to build a box and glass the inside with a gasket lid to keep the fumes in.This is really getting me thinking on the potential use down the road.
 Never had the chance to experience a still in operation, but I did have some formal training in petroleum cracking as it relates to spill cleanup.
  Best to keep me away from a still,,,,,as there would be no profit left ;D
I saw this and thought you might be able to find a second hand aquarium and create one easy enough. Maybe one of those big plexiglass  saltwater jobs. I can remember the name of the TV show where they built monster sized tanks. You  could do lots of stuff with one if tough enough and sealed enough to hold negative pressure. Just a thought...
Re: Cookies?
« Reply #114 on: October 29, 2019, 09:58:09 PM »
round is often used I think so it applies force equal in all directions, and I think alcohol will dissolve silicone adhesive, acetone is the antidote for superglue. so do not superglue your eye lids closed, cause then they have to just be separated with Vaseline on a q tip, ;)
    • tule peak timber
Re: Cookies?
« Reply #115 on: October 29, 2019, 09:59:05 PM »
Yes, very good thought.I need to do calcs on the number of gallons going into this. 4 foot diameter stumps.....
Ash Cookies
Started by kelLOGg on General Woodworking
Last post February 06, 2021, 07:20:41 PM
by rastis
exclamation
Cookies!
Started by Patty on FOOD! FOOD! FOOD!
Last post November 17, 2007, 12:26:17 AM
by beenthere
Cookies
Started by Good Feller on Forestry and Logging
Last post March 03, 2009, 10:58:06 PM
by rebocardo
COOKIES
Started by SAnVA on Sawmills and Milling
Last post December 03, 2014, 10:20:46 PM
by Magicman
